<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[24&quot; Frame Mirror]]></title><description><![CDATA[<p dir="auto">Hey All,</p>
<p dir="auto">First a big thanks to everyone.  Wonderful forum with tons of help.</p>
<p dir="auto">I’m building a mirror for my best friend for her birthday.  I need to keep it simple so I dont have to provide much support.  LOL.  I dont have real pictures to show yet, but below is a mock up of what it will hopefully look like.</p>
<p dir="auto"><img src="/assets/uploads/files/1527786449371-magicmirror_frame_2018-may-31_05-00-14pm-000_customizedview15504027614.png" alt="0_1527786218955_MagicMirror_Frame_2018-May-31_05-00-14PM-000_CustomizedView15504027614.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1527786470987-magicmirror_frame_2018-may-31_04-32-26pm-000_customizedview14217239980.png" alt="0_1527786240375_MagicMirror_Frame_2018-May-31_04-32-26PM-000_CustomizedView14217239980.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Hardware:</strong><br />
Raspberry Pi 3 Model B+ with 16GB<br />
<a href="http://www.lg.com/us/monitors/lg-24MP48HQ-P-led-monitor" target="_blank" rel="noopener noreferrer nofollow ugc">LG IPS LED Monitor (24MP48) with bezel removed</a><br />
<a href="https://www.twowaymirrors.com/smart-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">Two Way Mirrors 1/4" Smart Mirror with polished edges</a><br />
<s><a href="https://www.aliexpress.com/item/Free-Shipping-24-Infrared-Touchscreen-Frame-2-Points-touch-For-interactive-touch-screen-Touch-Wall-Kiosks/32839373105.html" target="_blank" rel="noopener noreferrer nofollow ugc">NECO-X 24" IR Frame</a></s><br />
<s><a href="https://www.adafruit.com/product/3367" target="_blank" rel="noopener noreferrer nofollow ugc">Mini USB Microphone</a> (probably wont work once in frame)</s><br />
PS3 Eye<br />
Dual fan for RPi (maybe)<br />
<a href="https://www.adafruit.com/product/917" target="_blank" rel="noopener noreferrer nofollow ugc">Chrome switches</a><br />
<a href="https://www.adafruit.com/product/3581" target="_blank" rel="noopener noreferrer nofollow ugc">Pimoroni On-Off Shim</a><br />
<a href="https://www.amazon.com/GE-Designer-Extension-Protection-40530/dp/B073R2D51S?th=1" target="_blank" rel="noopener noreferrer nofollow ugc">White braided extension cord</a></p>
<p dir="auto"><strong>Frame:</strong><br />
4 layers of 3/4" birch plywood.  Front will have a walnut stain.  The sides will be painted white.</p>
<p dir="auto"><strong>Modules:</strong><br />
Clock<br />
Calendar<br />
Compliments<br />
Current Weather<br />
Weather Forecast<br />
MMM-Cursor<br />
MMM-MyCommute<br />
MMM-newsfeedtouch<br />
<s>MMM-voice</s> MMM-Kalliope<br />
MMM-Wunderlist-Enhanced<br />
MMM-SystemStats (will probably remove, but good during dev)</p>
<p dir="auto"><strong>Misc:</strong><br />
<a href="https://www.remot3.it" target="_blank" rel="noopener noreferrer nofollow ugc">Remot3.it</a>  I have this set up for ssh and rdp.  Works great</p>
<p dir="auto">Cron job to reboot RPi every night at midnight.</p>
<p dir="auto">Two buttons on the side will be used to turn the RPi off completely using the Pimoroni On-Off shim and to power the monitor off completely.  I’m using MMM-voice to put the monitor in stand-by.</p>
<p dir="auto">Enabled the Open GL driver <a href="https://github.com/MichMich/MagicMirror/wiki/configuring-the-raspberry-pi" target="_blank" rel="noopener noreferrer nofollow ugc">fix</a>.  I had some issues with MMM-voice after doing this.  The usb mic and display would alternate device IDs after every reboot.  The fix is noted here:  <a href="https://forum.magicmirror.builders/topic/7232/mmm-voice-mic-number-changes">https://forum.magicmirror.builders/topic/7232/mmm-voice-mic-number-changes</a></p>
<p dir="auto"><s>I’m currently working on a custom version of MMM-voice that will show responses on the screen.  i.e. After detection of keyword a modal will pop up to display hello message and some tips on what commands can be used.  My first idea was to use MMM-TTS for the response, but I couldnt get it to work.</s></p>
<p dir="auto"><s>There was some questions on the forums about if and how well the IR frame would work when paired with a mirror.  I can report that it works great.</s>  Edit:  I’ve decided to not use the IR Frame.  The fingerprints on the mirror were annoying.  Now that I have Kalliope working well, there’s no need for the IR Frame.</p>
<p dir="auto">I’m hoping to get the frame done this weekend.  I’ll post pics of the process next week.</p>
]]></description><link>https://forum.magicmirror.builders/topic/7286/24-frame-mirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 10:10:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7286.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 May 2018 17:21:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Sat, 02 Jun 2018 09:00:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxbachmann" aria-label="Profile: maxbachmann">@<bdi>maxbachmann</bdi></a></p>
<p dir="auto">Touchfoil doesn’t work beneath the mirrorglass due to the metallic coating.</p>
<p dir="auto">Even the mirror supplier that was linked earlier says it has to be an overlay (i.e if you use a foil it should be on another layered glass over the mirror itself)</p>
<p dir="auto">Touchfoils are basically a sheet of transparent plastic with many really really thin wires running across the surface. Gives you around 98-99% transparency.</p>
]]></description><link>https://forum.magicmirror.builders/post/40108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40108</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sat, 02 Jun 2018 09:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:26:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sharmstr" aria-label="Profile: sharmstr">@<bdi>sharmstr</bdi></a> yes I thought that aswell especially because everyone uses the Frame</p>
]]></description><link>https://forum.magicmirror.builders/post/40079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40079</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:25:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxbachmann" aria-label="Profile: maxbachmann">@<bdi>maxbachmann</bdi></a> said in <a href="/post/40076">24" IR Frame Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sharmstr" aria-label="Profile: sharmstr">@<bdi>sharmstr</bdi></a> I see everyone using IR Frames. What makes them better than putting a touchfoil on the mirror? does that screw anything?</p>
<p dir="auto">I cant answer that.  Its just the route I went.  Maybe the foil gives the mirror a bit of a fun house effect?  I have no idea really.</p>
]]></description><link>https://forum.magicmirror.builders/post/40078</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40078</guid><dc:creator><![CDATA[sharmstr]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:25:46 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:24:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxbachmann" aria-label="Profile: maxbachmann">@<bdi>maxbachmann</bdi></a> I didnt even think about the dust.  Hmmmm.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bakuretsu" aria-label="Profile: Bakuretsu">@<bdi>Bakuretsu</bdi></a> Thank you.  I’ll post pics of the process.  I started messing around with MM last year.  At the time the voice stuff ran really slowly so that’s why I wanted the IR frame.  Now with the new RPi 3 model B+ that was just released, the voice integration is fairly quick.  Having fingerprints on the mirror gets to be annoying so I may remove it all together or at least make sure none of the touch related functions are in the middle of the mirror.  Stay tuned :)</p>
]]></description><link>https://forum.magicmirror.builders/post/40077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40077</guid><dc:creator><![CDATA[sharmstr]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:24:11 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:22:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sharmstr" aria-label="Profile: sharmstr">@<bdi>sharmstr</bdi></a> I see everyone using IR Frames. What makes them better than putting a touchfoil on the mirror? does that screw anything?</p>
]]></description><link>https://forum.magicmirror.builders/post/40076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40076</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:22:28 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:18:07 GMT]]></title><description><![CDATA[<p dir="auto">It looks like it’s going to be amazing. I just joined here and I keep coming back to your setup. I would really, really love to see a build process once you get it done. The IR frame interests me the most if it works reliably.</p>
]]></description><link>https://forum.magicmirror.builders/post/40075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40075</guid><dc:creator><![CDATA[Bakuretsu]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:18:07 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sharmstr" aria-label="Profile: sharmstr">@<bdi>sharmstr</bdi></a> No checked that then will contact them ;) in my build the frame would be bigger than the hole in the mid of my frame. So this gap does not fill with dust I would like to fill it but obviously should not filter the infrared ^^ Thought about pmma casting resin because that would fill it nicely and filters until around 400nm and then again above 2800nm. So I guess it should work :face_with_tears_of_joy:</p>
]]></description><link>https://forum.magicmirror.builders/post/40074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40074</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:03:45 GMT]]></title><description><![CDATA[<p dir="auto">I dont.  Might be listed here:  <a href="https://www.aliexpress.com/item/Free-Shipping-24-Infrared-Touchscreen-Frame-2-Points-touch-For-interactive-touch-screen-Touch-Wall-Kiosks/32839373105.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/item/Free-Shipping-24-Infrared-Touchscreen-Frame-2-Points-touch-For-interactive-touch-screen-Touch-Wall-Kiosks/32839373105.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/40073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40073</guid><dc:creator><![CDATA[sharmstr]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:03:45 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:02:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sharmstr" aria-label="Profile: sharmstr">@<bdi>sharmstr</bdi></a> do you know the wavelength of your IR Frame? ^^<br />
Yes Germany makes it over 100$ I like them because they are pretty much the only you could use with touch foils under the glass</p>
]]></description><link>https://forum.magicmirror.builders/post/40072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40072</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:02:27 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 13:00:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxbachmann" aria-label="Profile: maxbachmann">@<bdi>maxbachmann</bdi></a> I’m guessing you’re not in the states then :)   I paid $19 for shipping.  The mirror itself is expensive, but they are really really nice.</p>
]]></description><link>https://forum.magicmirror.builders/post/40071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40071</guid><dc:creator><![CDATA[sharmstr]]></dc:creator><pubDate>Fri, 01 Jun 2018 13:00:54 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 12:49:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sharmstr" aria-label="Profile: sharmstr">@<bdi>sharmstr</bdi></a> they have nice mirrors (wanted to buy one until I saw the shipping costs lol)</p>
]]></description><link>https://forum.magicmirror.builders/post/40070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40070</guid><dc:creator><![CDATA[maxbachmann]]></dc:creator><pubDate>Fri, 01 Jun 2018 12:49:49 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 12:46:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/buzztiger" aria-label="Profile: buzztiger">@<bdi>buzztiger</bdi></a> I measured the IR frame and ordered the same size mirror from <a href="https://www.twowaymirrors.com/smart-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.twowaymirrors.com/smart-mirror/</a>.  The size is 13.625" x 22.438" x 1/4"</p>
]]></description><link>https://forum.magicmirror.builders/post/40069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40069</guid><dc:creator><![CDATA[sharmstr]]></dc:creator><pubDate>Fri, 01 Jun 2018 12:46:32 GMT</pubDate></item><item><title><![CDATA[Reply to 24&quot; Frame Mirror on Fri, 01 Jun 2018 07:56:23 GMT]]></title><description><![CDATA[<p dir="auto">That looks beautiful. May I ask what mirror size you ordered from Goldjunge? Thinking about making this my parental leave summer project…</p>
]]></description><link>https://forum.magicmirror.builders/post/40061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40061</guid><dc:creator><![CDATA[buzztiger]]></dc:creator><pubDate>Fri, 01 Jun 2018 07:56:23 GMT</pubDate></item></channel></rss>
