<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mey's Mirror 1.5m x 0.67m]]></title><description><![CDATA[<p dir="auto">Hello fellow MirrorMaker</p>
<p dir="auto">I work in a city up on a mountain, but live near the see. The weather is different. I got to work with shorts and t-shirt, because it was really hot where i live, but It was very cold up where I work. That’s the reason why i made my MagicMirror. Just to see the weather and myself on the mirror and think about clothing decision.</p>
<p dir="auto"><img src="/assets/uploads/files/1527886241655-forumdsc_0115-resized.jpg" alt="0_1527886232562_ForumDSC_0115.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">But now to the interesting part. The components of my mirror:</p>
<ul>
<li>Rapsberry Pi Zero W (~10€)</li>
<li>mirror: Pilkington Mirropane Chrome Spy 1500x670x4 mm (~270€ with shipping)</li>
<li>screen: MEDION LIFE P12164 (TV nobody used, so i took the screen)</li>
<li>frame: custom made in Jumbo (~110€)</li>
</ul>
<p dir="auto">Modules:</p>
<ul>
<li>Clock</li>
<li>Compliments</li>
<li>News Feed (maybe i’ll remove this)</li>
<li>MMM-swisstransport</li>
<li>MMM-weatherchart</li>
<li>MMM-GoogleMapsTraffic</li>
<li>Planed: Google Calendar (and ad this)</li>
</ul>
<p dir="auto">I will change some things on the layout of my mirror. It annoys me a little, that it’s not that symmetric. The Google Maps Traffic will be bigger and more on the top. When I can find some space, I want to add my google calendar.</p>
<p dir="auto">Mirror:<br />
<img src="/assets/uploads/files/1527885845042-631501513313427266.jpg" alt="0_1527885842756_631501513313427266.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Frame:<br />
<img src="/assets/uploads/files/1527886313887-forumdsc_0081_1-resized.jpg" alt="0_1527886305606_ForumDSC_0081_1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">TV:<br />
<img src="/assets/uploads/files/1527886353024-forumdsc_0068_2-resized.jpg" alt="0_1527886345392_ForumDSC_0068_2.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">But i had real trouble while making the mirror. First i destroyed the mirror, on the second day. That was a real turn off and I couldn’t work for some weeks. I fixed it - it will never be perfect, but it’s still my baby.</p>
<p dir="auto"><img src="/assets/uploads/files/1527886968860-befunky-collage-resized.jpg" alt="0_1527886960807_BeFunky-collage.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then I realized, that the Raspberry Pi 3b won’t fit in my frame, because of it’s height. So i decided to take a Raspberry Pi Zero W. Sadly I didn’t work like on the 3b. Luckily I got help in this forum. The problem was midori in combination with ES6. So i installed Chromium. It boots really slowly, but it’s enough for it’s job.</p>
<p dir="auto">The height of the frame isn’t that much, so I had to deepen the mdf plate on the back. Some tv-parts were too thick. There was so much dust…<br />
It’s over two weeks, but there is dust everywhere. I don’t know if I can ever remove all of that.</p>
<p dir="auto"><img src="/assets/uploads/files/1527887926946-befunky-collage-1-resized.jpg" alt="0_1527887918360_BeFunky-collage (1).jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">My screen is on the top. The raspberry is powered by the tv usb-port. So i have just one cable going out of the mirror. For the control panel of the tv I cut a slot on the frame on the right hand side and for the usb slot on the left hand side. I will 3d print a cover for the control panel.<br />
I couldn’t  screw in the mdf plate, because there are just 3mm left. So my brother glued a nut on the plate and screwed the tv parts.</p>
<p dir="auto"><img src="/assets/uploads/files/1527889254358-forumdsc_0089-resized.jpg" alt="0_1527889246711_ForumDSC_0089.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1527889143330-forumdsc_0092-resized.jpg" alt="0_1527889135015_ForumDSC_0092.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1527889165929-forumdsc_0095-resized.jpg" alt="0_1527889149350_ForumDSC_0095.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Finally we could install it on the wall.<br />
<img src="/assets/uploads/files/1527888832236-forumdsc_0096-resized.jpg" alt="0_1527888824158_ForumDSC_0096.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/7299/mey-s-mirror-1-5m-x-0-67m</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 15:36:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7299.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Jun 2018 21:54:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mey's Mirror 1.5m x 0.67m on Sat, 02 Jun 2018 09:11:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/idoodler" aria-label="Profile: idoodler">@<bdi>idoodler</bdi></a> Thanks :) I needed a big mirror anyways. I’m glad that such a nice project exists.</p>
]]></description><link>https://forum.magicmirror.builders/post/40110</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40110</guid><dc:creator><![CDATA[meyraa]]></dc:creator><pubDate>Sat, 02 Jun 2018 09:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to Mey's Mirror 1.5m x 0.67m on Sat, 02 Jun 2018 09:08:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> yeah, that’s the best part. When it’s on your wall and you can finally plug it in to see your work :)</p>
]]></description><link>https://forum.magicmirror.builders/post/40109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40109</guid><dc:creator><![CDATA[meyraa]]></dc:creator><pubDate>Sat, 02 Jun 2018 09:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to Mey's Mirror 1.5m x 0.67m on Sat, 02 Jun 2018 07:32:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meyraa" aria-label="Profile: meyraa">@<bdi>meyraa</bdi></a> Hey, Mey! Thats a really big and nice mirror! Thanks for sharing your project:thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/40102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40102</guid><dc:creator><![CDATA[idoodler]]></dc:creator><pubDate>Sat, 02 Jun 2018 07:32:58 GMT</pubDate></item><item><title><![CDATA[Reply to Mey's Mirror 1.5m x 0.67m on Sat, 02 Jun 2018 01:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meyraa" aria-label="Profile: meyraa">@<bdi>meyraa</bdi></a></p>
<p dir="auto">Nice work, young lady! I think I had the same expression on my face after completing my first mirror. One of pure joy! :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/40097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40097</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 02 Jun 2018 01:03:42 GMT</pubDate></item></channel></rss>
