<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My 36" Mirror]]></title><description><![CDATA[<p dir="auto">Hey guys,<br />
thanks for all your great inspiration.<br />
I got an old 32" TV for free.<br />
Wood isnt my prefered material but i think it looks okay for the first mirror :)</p>
<p dir="auto">The main problem starts with the end.<br />
The mirror is quiet heavy (8mm | 80 x 53,3 cm) and because i wont holes in it i need to glue them in any way to the case:<br />
<a href="https://forum.magicmirror.builders/topic/7231/glue-mirror-for-wooden-case">https://forum.magicmirror.builders/topic/7231/glue-mirror-for-wooden-case</a></p>
<p dir="auto">Unfortunately my TV doesnt support HDMI-CEC or anything else that could bring him in standby.<br />
But in the end i do a dirty workaround (black screen) to prevent the to from beeing displayed “no signal” all the time.</p>
<p dir="auto">The mirror has following specs:</p>
<ul>
<li>Berechnung nach EN410 und EN673	Außen	Innen<br />
Lichttransmission	11 %	<br />
Lichtreflexion	42 %	42 %<br />
Energietransmission	13 %	<br />
Energiereflexion	34 %	<br />
Energieabsorption (1. Scheibe)	53 %	<br />
UV-Transmission	1 %	<br />
g-Wert	25 %	<br />
Farbwiedergabeindex Transmission (Ra)	93	<br />
Farbwiedergabeindex Außenreflexion (Ra)	95</li>
</ul>
<p dir="auto">The only remeaning problem is from the MMM-Formula1-Module that doesnt load the data reliable.</p>
<p dir="auto"><strong>Here are the Pics:</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1528979522046-1.jpeg" alt="0_1528979521583_1.jpeg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979545863-1_5.jpeg" alt="0_1528979545498_1_5.jpeg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979534555-2.jpeg" alt="0_1528979534165_2.jpeg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979537943-3.jpeg" alt="0_1528979537436_3.jpeg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979540035-4.jpeg" alt="0_1528979539670_4.jpeg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979543032-5.jpeg" alt="0_1528979542617_5.jpeg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1528979551716-img_20180614_141317.jpg" alt="0_1528979551484_IMG_20180614_141317.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979554057-img_20180614_141320.jpg" alt="0_1528979553759_IMG_20180614_141320.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979556267-img_20180614_141335.jpg" alt="0_1528979556086_IMG_20180614_141335.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1528979558483-img_20180614_141401.jpg" alt="0_1528979558292_IMG_20180614_141401.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/7401/my-36-mirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 19:30:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7401.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Jun 2018 12:42:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My 36" Mirror on Sun, 08 Jul 2018 19:41:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/solelo" aria-label="Profile: solelo">@<bdi>solelo</bdi></a><br />
:face_with_stuck-out_tongue_closed_eyes:  dont worry</p>
]]></description><link>https://forum.magicmirror.builders/post/41345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41345</guid><dc:creator><![CDATA[Gubert]]></dc:creator><pubDate>Sun, 08 Jul 2018 19:41:38 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Sun, 08 Jul 2018 17:42:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gubert" aria-label="Profile: gubert">@<bdi>gubert</bdi></a> after reading through I saw that… <em>face palms</em></p>
]]></description><link>https://forum.magicmirror.builders/post/41341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41341</guid><dc:creator><![CDATA[SoleLo]]></dc:creator><pubDate>Sun, 08 Jul 2018 17:42:50 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Sun, 08 Jul 2018 17:20:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/solelo" aria-label="Profile: solelo">@<bdi>solelo</bdi></a> said in <a href="/post/40945">My 36" Mirror</a>:</p>
<p dir="auto">Firstly, this looks great. I have a couple of questions. How did you get the mirror to be on the frame? Did you glue it or use some sort of two sided tape? Also; what did you use to hang it on the wall?</p>
<p dir="auto">“How did you get the mirror to be on the frame?”<br />
As is wrote in the initial post i glue it. Scroll up ;)</p>
<p dir="auto">“What did you use to hang it on the wall?”<br />
Simple hooks. Like this:<br />
<img src="/assets/uploads/files/1531070437063-d3457922-1d0b-4c08-ba84-e32f491fd357-image.png" alt="0_1531070423434_d3457922-1d0b-4c08-ba84-e32f491fd357-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/41340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41340</guid><dc:creator><![CDATA[Gubert]]></dc:creator><pubDate>Sun, 08 Jul 2018 17:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Thu, 28 Jun 2018 23:09:14 GMT]]></title><description><![CDATA[<p dir="auto">Firstly, this looks great. I have a couple of questions. How did you get the mirror to be on the frame? Did you glue it or use some sort of two sided tape? Also; what did you use to hang it on the wall?</p>
]]></description><link>https://forum.magicmirror.builders/post/40945</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40945</guid><dc:creator><![CDATA[SoleLo]]></dc:creator><pubDate>Thu, 28 Jun 2018 23:09:14 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Sat, 16 Jun 2018 14:47:08 GMT]]></title><description><![CDATA[<p dir="auto">looks pretty cool! Well done :)</p>
]]></description><link>https://forum.magicmirror.builders/post/40543</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40543</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Sat, 16 Jun 2018 14:47:08 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Thu, 14 Jun 2018 13:10:40 GMT]]></title><description><![CDATA[<p dir="auto">The quality of the samples are bad.</p>
]]></description><link>https://forum.magicmirror.builders/post/40489</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40489</guid><dc:creator><![CDATA[conkhidot]]></dc:creator><pubDate>Thu, 14 Jun 2018 13:10:40 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Thu, 14 Jun 2018 13:05:24 GMT]]></title><description><![CDATA[<p dir="auto">I dont have any other mirrors seen for projects like this. So i cant compare. But for me it looks great.<br />
The pictures are while very bright light taken and the tv is about ~60% brightness setting.<br />
Whats your problem with this mirrors?</p>
<p dir="auto">EDIT: for sure they are very heavy. but its okay for me</p>
]]></description><link>https://forum.magicmirror.builders/post/40488</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40488</guid><dc:creator><![CDATA[Gubert]]></dc:creator><pubDate>Thu, 14 Jun 2018 13:05:24 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Thu, 14 Jun 2018 12:59:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gubert" aria-label="Profile: gubert">@<bdi>gubert</bdi></a> uhmmm… I got 2 samples of them and I was disappointed. Whats ur opinion, would recommend it ? (but 8mm is very thick :/ )</p>
]]></description><link>https://forum.magicmirror.builders/post/40487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40487</guid><dc:creator><![CDATA[conkhidot]]></dc:creator><pubDate>Thu, 14 Jun 2018 12:59:00 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Thu, 14 Jun 2018 12:55:32 GMT]]></title><description><![CDATA[<p dir="auto">thanks!<br />
<a href="https://www.myspiegel.de/spionspiegel-pg-2102.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.myspiegel.de/spionspiegel-pg-2102.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/40486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40486</guid><dc:creator><![CDATA[Gubert]]></dc:creator><pubDate>Thu, 14 Jun 2018 12:55:32 GMT</pubDate></item><item><title><![CDATA[Reply to My 36" Mirror on Thu, 14 Jun 2018 12:54:50 GMT]]></title><description><![CDATA[<p dir="auto">Where did u get the mirror ? I’m looking for a good supplier. Its a very nice mirror btw :D</p>
]]></description><link>https://forum.magicmirror.builders/post/40485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40485</guid><dc:creator><![CDATA[conkhidot]]></dc:creator><pubDate>Thu, 14 Jun 2018 12:54:50 GMT</pubDate></item></channel></rss>
