<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google Assistant]]></title><description><![CDATA[<p dir="auto">Hello, I have tried installing MMM-Assistant and it is failing the npm install part with an error on missing files:</p>
<pre><code>grpc@1.8.0 install /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc
&gt; node-pre-gyp install --fallback-to-build --library=static_library
node-pre-gyp ERR! Tried to download(403): https://storage.googleapis.com/grpc-precompiled-binaries/node/grpc/v1.8.0/node-v64-linux-arm-glibc.tar.gz
<p dir="auto">From there on it just a bunch or errors. The following is at the end of the log more or less.</p>
<pre><code>2085 verbose stack Error: grpc@1.8.0 install: `node-pre-gyp install --fallback-to-build --library=static_library`
2085 verbose stack Exit status 1
2085 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
2085 verbose stack     at EventEmitter.emit (events.js:182:13)
2085 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
2085 verbose stack     at ChildProcess.emit (events.js:182:13)
2085 verbose stack     at maybeClose (internal/child_process.js:961:16)
2085 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:5)
2086 verbose pkgid grpc@1.8.0
2087 verbose cwd /home/pi/MagicMirror/modules/MMM-Assistant
2088 verbose Linux 4.14.49-v7+
2089 verbose argv "/usr/bin/node" "/usr/bin/npm" "install"
2090 verbose node v10.4.1
2091 verbose npm  v6.1.0
<p dir="auto">Has anyone tried MMM-Assistant succesfully and if not, is there perhaps a better similar module that give you the ability to show and hide modules , play music, youtube etc?</p>
<p dir="auto">Thanks<br />
Paul</p>
]]></description><link>https://forum.magicmirror.builders/topic/7421/google-assistant</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 07:21:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7421.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jun 2018 02:13:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Google Assistant on Thu, 21 Jun 2018 11:04:27 GMT]]></title><description><![CDATA[<p dir="auto">I have MM and Google assistant running on one rpi.<br />
I used the original Goole AIY kit.<br />
So I do not use MMM-assistant.<br />
I can ask questions and get answers, but it is impossible to hide or show modules.<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/40717</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40717</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Thu, 21 Jun 2018 11:04:27 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant on Thu, 21 Jun 2018 03:51:03 GMT]]></title><description><![CDATA[<p dir="auto">Anyone out there using Google Assistant?</p>
]]></description><link>https://forum.magicmirror.builders/post/40714</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40714</guid><dc:creator><![CDATA[paul.aviles]]></dc:creator><pubDate>Thu, 21 Jun 2018 03:51:03 GMT</pubDate></item></channel></rss>
