<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pm2 erorr log full of errors]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">in error log in pm2  is cca each 30sec this error:</p>
<pre><code>TypeError: Cannot read property 'hash' of null
    at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31
    at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10)
    at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21)
    at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16)
    at emitTwo (events.js:106:13)
    at ChildProcess.emit (events.js:191:7)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
<p dir="auto">And every morning I need to restart my Raspberry because of the screen is blank. But webservice is running and If i open the MM via webservice it works properly.</p>
<p dir="auto">Have anybody some solution? Thank you!<br />
Tomas</p>
]]></description><link>https://forum.magicmirror.builders/topic/7438/pm2-erorr-log-full-of-errors</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 03:04:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7438.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Jun 2018 09:10:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pm2 erorr log full of errors on Mon, 04 Mar 2019 13:22:50 GMT]]></title><description><![CDATA[<p dir="auto">I recently seen that on my improvement machine. LE rectified: just the pm2 logs order will skip appearing/time on application invigorate.</p>
]]></description><link>https://forum.magicmirror.builders/post/53637</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53637</guid><dc:creator><![CDATA[nadhiji]]></dc:creator><pubDate>Mon, 04 Mar 2019 13:22:50 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 erorr log full of errors on Fri, 22 Jun 2018 12:05:07 GMT]]></title><description><![CDATA[<p dir="auto">I think, this is same problem as here: <a href="https://github.com/MichMich/MagicMirror/issues/1243" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/1243</a></p>
]]></description><link>https://forum.magicmirror.builders/post/40747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40747</guid><dc:creator><![CDATA[TomasZmuda]]></dc:creator><pubDate>Fri, 22 Jun 2018 12:05:07 GMT</pubDate></item></channel></rss>
