<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[B&W themed hallway mirror with 32” display]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I’ve been lurking in the forums and now I present you my mirror:</p>
<p dir="auto"><img src="/assets/uploads/files/1529756685336-50-mm.jpg" alt="0_1529756680981_50-mm.jpg" class=" img-fluid img-markdown" /><br />
You can find more pictures and details on <a href="https://photos.app.goo.gl/mYmKpFHBp7h55Se57" target="_blank" rel="noopener noreferrer nofollow ugc">Google photos</a><br />
(There’s comment on every photo)</p>
<p dir="auto">This mirror has been in the making for the last 6 months or so. I purchased Rpi 3 for 20 euros (25 dollars) on last black friday, 24th October 2017. At first I thought what to do with it. I was tempted to have some sort of screen where I could see what’s playing on Spotify while making food and such so I don’t have to unlock iPad or phone everytime for this. I didn’t have any suitable space in my living room. I remembered I had read about MagicMirror sometime earlier and that was it. I had hallway mirror in the hallway and that seemed to be the only place where I could ”hide” the display. Luckily while making the mirror MMM-NowPlayingOnSpotify module was released :winking_face: :headphone:</p>
<p dir="auto">This started search for display for at least 30” at around christmas time. The idea was to put it in vertical position at top of the mirror while covering the whole upper area and being wide enough so that I could see my whole upper body on the mirror. Of course it had to be as bright as possible while being thin at the same time. After about one month of search I found used 32” LG signage series info display, 32WL30MS-B.<br />
<img src="/assets/uploads/files/1529755724557-02-mm-resized.jpg" alt="0_1529755721306_02-mm.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Next I had to find suitable frame. I didn’t want the mirror to stand out really and the goal was to make it look as any standard mirror while hiding the thickness of the display, 3,56 cm. I found planing mill which seemed to have pretty perfect frame for my display and it just needed some cuts with circular saw at the back side to fit it in. Sorry, I don’t have any pictures for the cutting part. Yes, the frame is pretty massive, it’s 5,8 cm thick and 4 meters of frame weights 5,5 kg all alone!<br />
<img src="/assets/uploads/files/1529755757777-04.jpg" alt="0_1529755756258_04.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I’m from Finland and here we have sauna in almost every building. I thought it would be cool to have the temperature shown in the mirror. Luckily I found out that MMM-temp-ds18b20 module was perfect for this. DS18B20 sensors can handle 125C temperatures so I wired one of them to the sauna which is behind the mirror. The other one lies at the bottom of the mirror showing the hallway temperature.</p>
<p dir="auto">More pictures:<br />
<img src="/assets/uploads/files/1529759620526-51-mm.jpg" alt="0_1529759616895_51-mm.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1529759636090-52-mm.jpg" alt="0_1529759633098_52-mm.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1529759655569-47-mm.jpg" alt="0_1529759651135_47-mm.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1529759669237-48-mm.jpg" alt="0_1529759666284_48-mm.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">These modules are installed (at the time of writing):</p>
<p dir="auto"><em>top</em><br />
clock<br />
MMM-AlexaPi (AlexaPi as core)<br />
currentweather<br />
MMM-temp-ds18b20<br />
weatherforecast</p>
<p dir="auto"><em>mid</em><br />
compliments</p>
<p dir="auto"><em>bottom</em><br />
MMM-Carousel, switching the following<br />
1<br />
calendar_monthly<br />
MMM-NowPlayingOnSpotify<br />
MMM-quote-of-the-day<br />
2<br />
MMM-Formula1<br />
MMM-GoogleFit<br />
newsfeed</p>
<p dir="auto"><em>and</em><br />
MMM-PIR-Sensor</p>
<p dir="auto">Screenshots:<br />
<img src="/assets/uploads/files/1529757539122-sauna4.png" alt="0_1529757536994_sauna4.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1529757548910-sauna3.png" alt="0_1529757547107_sauna3.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Feel free to comment or ask questions!</p>
]]></description><link>https://forum.magicmirror.builders/topic/7449/b-w-themed-hallway-mirror-with-32-display</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 13:03:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7449.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Jun 2018 13:21:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Fri, 07 Sep 2018 10:12:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dmd" aria-label="Profile: dmd">@<bdi>dmd</bdi></a></p>
<p dir="auto">Oliko mitään ongelmia tuon MMM-PIR-Sensor:in kanssa, asennuksen yhteydessä?</p>
<p dir="auto">Itse en ole saanut toimimaan. Liitetty oikeaan gpio paikkaan ja asennettu ohjeiden mukaisesti.</p>
]]></description><link>https://forum.magicmirror.builders/post/44214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44214</guid><dc:creator><![CDATA[gashion]]></dc:creator><pubDate>Fri, 07 Sep 2018 10:12:53 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Tue, 07 Aug 2018 05:47:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dmd" aria-label="Profile: dmd">@<bdi>dmd</bdi></a> thx 4 the answer</p>
<p dir="auto">Zdeněk</p>
]]></description><link>https://forum.magicmirror.builders/post/43148</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43148</guid><dc:creator><![CDATA[zdenek]]></dc:creator><pubDate>Tue, 07 Aug 2018 05:47:54 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Mon, 06 Aug 2018 13:12:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zdenek" aria-label="Profile: zdenek">@<bdi>zdenek</bdi></a> There’s some hints on <a href="https://photos.app.goo.gl/mYmKpFHBp7h55Se57" target="_blank" rel="noopener noreferrer nofollow ugc">Google photos</a> if you look at the accessories photos. Best viewable with desktop browser or tablet for the info in them.</p>
<p dir="auto">These were found on Amazon: usb cable, microSD-SD extension cable, DS18B20 temperature sensors, PIR-sensor (HC-SR501), microwave motion sensor (RCWL-0516) and PS3 eye (stripped down to having only pcb with microphones).</p>
<p dir="auto">I mean, where to order USB cables?</p>
<ul>
<li>Amazon, search for “usb flush mount cable”</li>
</ul>
<p dir="auto">And the “white flat cable” - what is it?</p>
<ul>
<li>Amazon, search for “microSD SD extension extender cable”. Well, I guess the name says it all. You can use microSD microSD extension cable also if your mirror’s frame is smaller. The reason I wanted to use SD extension cable (I have SD-microSD adapter in it) :face_with_stuck-out_tongue_closed_eyes: is because I read somewhere that the reason it was removed from the Pi is because the springler in it was one of the most defective part. This way I can just slide the microSD card in it. Well, not that I change sd card every day but just in case. It was probably easier for me to glue it to the frame also.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/43126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43126</guid><dc:creator><![CDATA[dmd]]></dc:creator><pubDate>Mon, 06 Aug 2018 13:12:32 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Sun, 05 Aug 2018 10:16:39 GMT]]></title><description><![CDATA[<p dir="auto">great job. Can you please provide some info about additional HW/sensors? I mean, where to order USB cables? And the “white flat cable” - what is it? Is it a way, how to place SD card outside of RPi? Where to get it?</p>
<p dir="auto">Thanks, Zdeněk</p>
]]></description><link>https://forum.magicmirror.builders/post/43041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43041</guid><dc:creator><![CDATA[zdenek]]></dc:creator><pubDate>Sun, 05 Aug 2018 10:16:39 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Fri, 03 Aug 2018 17:48:43 GMT]]></title><description><![CDATA[<p dir="auto">very nice</p>
]]></description><link>https://forum.magicmirror.builders/post/43006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43006</guid><dc:creator><![CDATA[hayman]]></dc:creator><pubDate>Fri, 03 Aug 2018 17:48:43 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Mon, 16 Jul 2018 09:14:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anubisf" aria-label="Profile: anubisf">@<bdi>anubisf</bdi></a>  Peililasin ostin Maakunnan Lasi Oy:stä Lahdesta. Lasin paksuus on 4mm ja hintaa oli ~70e neliö ilman reunojen hiomista. Hiomisen tein itse hiekkapaperilla, mutta helpommalla pääsee kun tekevät sen liikkeessä. Myyjän mukaan valon läpäisyprosentti peililasilla on jotain välillä 8-12. Peilikuva on hieman tummempi verrattuna tavalliseen peiliin, vaikka sitä ei noista esimerkkikuvista helposti huomaakaan.</p>
<p dir="auto">Edit: Unohdin vielä mainita. “piilopeili” nimellä myyvät eli tavallinen peililasi ei tähän käyttöön sovellu.</p>
]]></description><link>https://forum.magicmirror.builders/post/42297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42297</guid><dc:creator><![CDATA[dmd]]></dc:creator><pubDate>Mon, 16 Jul 2018 09:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Sat, 14 Jul 2018 02:37:36 GMT]]></title><description><![CDATA[<p dir="auto">Excellent work! It looks great.</p>
]]></description><link>https://forum.magicmirror.builders/post/42235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42235</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 14 Jul 2018 02:37:36 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Fri, 13 Jul 2018 19:19:31 GMT]]></title><description><![CDATA[<p dir="auto">Moi,</p>
<p dir="auto">Mitä peiliä sinä käytit, tavalinen tai olet tilannut joku erikoista ?</p>
]]></description><link>https://forum.magicmirror.builders/post/42231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42231</guid><dc:creator><![CDATA[AnubisF]]></dc:creator><pubDate>Fri, 13 Jul 2018 19:19:31 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Tue, 03 Jul 2018 08:34:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gashion" aria-label="Profile: gashion">@<bdi>gashion</bdi></a> said in <a href="/post/41104">B&amp;W themed hallway mirror with 32” display</a>:</p>
<p dir="auto">Hieno peili!</p>
<p dir="auto">Onko ollut mitään ongelmia ohjelmiston asennuksen kanssa?</p>
<p dir="auto">Kiitos! MagicMirror asentui automaattiasennuksella ja kaikki modulit ongelmitta. Raspbian Strechin asennukseen käytin <a href="https://etcher.io/" target="_blank" rel="noopener noreferrer nofollow ugc">Etcheriä</a></p>
<p dir="auto">Perusasennukseen käytin tätä ohjetta:<br />
<a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial</a></p>
<p dir="auto">Strech päivittynyt hieman tuon jälkeen eli valikot löytyy hieman eri kohdista. OpenWeatherMap ei tietääkseni jaa enää ilmaisia api avaimia eli sääennusteen saamisesta toimimaan tällä hetkellä en osaa sanoa.</p>
<p dir="auto">*Same in English. Did you had any problems installing the software?<br />
No, MagicMirror software installed with automatic install. For Raspian Strech I used <a href="https://etcher.io/" target="_blank" rel="noopener noreferrer nofollow ugc">Etcher</a> image tool. All the modules installed with no problem. Not sure if you can get weather forecast working at the moment as OpenWeatherMap doesn’t provide free api keys anymore. *</p>
]]></description><link>https://forum.magicmirror.builders/post/41148</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41148</guid><dc:creator><![CDATA[dmd]]></dc:creator><pubDate>Tue, 03 Jul 2018 08:34:21 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Mon, 02 Jul 2018 17:28:49 GMT]]></title><description><![CDATA[<p dir="auto">Hieno peili!</p>
]]></description><link>https://forum.magicmirror.builders/post/41104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41104</guid><dc:creator><![CDATA[gashion]]></dc:creator><pubDate>Mon, 02 Jul 2018 17:28:49 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Tue, 26 Jun 2018 11:29:10 GMT]]></title><description><![CDATA[<p dir="auto">Great job!</p>
]]></description><link>https://forum.magicmirror.builders/post/40842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40842</guid><dc:creator><![CDATA[canadrian]]></dc:creator><pubDate>Tue, 26 Jun 2018 11:29:10 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Mon, 25 Jun 2018 22:27:35 GMT]]></title><description><![CDATA[<p dir="auto">Very Nice!!!  Love it!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/40824</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40824</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Mon, 25 Jun 2018 22:27:35 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Mon, 25 Jun 2018 01:55:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dmd" aria-label="Profile: dmd">@<bdi>dmd</bdi></a> said in <a href="/post/40781">B&amp;W themed hallway mirror with 32” display</a>:</p>
<p dir="auto">Not sure if I’m that young anymore but thank you Mykle1!</p>
<p dir="auto">I see your reflection in your mirror. You’re young. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/40793</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40793</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 25 Jun 2018 01:55:13 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Sun, 24 Jun 2018 12:09:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Not sure if I’m that young anymore but thank you Mykle1! :slightly_smiling_face:<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/kimzer" aria-label="Profile: Kimzer">@<bdi>Kimzer</bdi></a> Yes, the pir sensor was removed from the board and soldered to the wires. I didn’t want the wires to be too long however.</p>
]]></description><link>https://forum.magicmirror.builders/post/40781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40781</guid><dc:creator><![CDATA[dmd]]></dc:creator><pubDate>Sun, 24 Jun 2018 12:09:08 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Sun, 24 Jun 2018 08:43:49 GMT]]></title><description><![CDATA[<p dir="auto">Looks pretty damned awesome! Well done!<br />
Did u loosen the pir sensor from the board? Clever, havent thought of that!</p>
]]></description><link>https://forum.magicmirror.builders/post/40775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40775</guid><dc:creator><![CDATA[Kimzer]]></dc:creator><pubDate>Sun, 24 Jun 2018 08:43:49 GMT</pubDate></item><item><title><![CDATA[Reply to B&W themed hallway mirror with 32” display on Sun, 24 Jun 2018 00:32:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dmd" aria-label="Profile: dmd">@<bdi>dmd</bdi></a></p>
<p dir="auto">Well done, young man!</p>
]]></description><link>https://forum.magicmirror.builders/post/40773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40773</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 24 Jun 2018 00:32:20 GMT</pubDate></item></channel></rss>
