<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Move Module to corner]]></title><description><![CDATA[<p dir="auto">How can I move a module more to the corner so i can get ride of the blank space ? <img src="https://s17.postimg.org/tswufgtpb/corner_CSS.jpg" alt="Corner Picture Will auto-remove after 30 days" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/752/move-module-to-corner</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:46:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/752.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Oct 2016 22:05:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Move Module to corner on Sun, 09 Oct 2016 17:17:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> Thank you! Now it works very well!<br />
Don’t know why i didn’t thought about height &amp; width before :D</p>
]]></description><link>https://forum.magicmirror.builders/post/6055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6055</guid><dc:creator><![CDATA[Patrick]]></dc:creator><pubDate>Sun, 09 Oct 2016 17:17:54 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Sun, 09 Oct 2016 17:07:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/patrick" aria-label="Profile: Patrick">@<bdi>Patrick</bdi></a> I would try this</p>
<pre><code>body {
  margin: 10px;
  position: absolute;
  height: calc(100% - 20px);
  width: calc(100% - 20px);
]]></description><link>https://forum.magicmirror.builders/post/6054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6054</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 09 Oct 2016 17:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Sun, 09 Oct 2016 17:05:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> sorry for my wrong explanation.<br />
I just want to reduce the whole margin because my display is to small for weather + clock.<br />
So i tried to reduce it with the tags:</p>
<ul>
<li>
<p dir="auto">margin: xxx</p>
</li>
<li>
<p dir="auto">margin-left: xxx in combination with margin-right: xxx<br />
both didn’t work.<br />
I had the problem that everything just moved to the left instead of providing more space.<br />
So i had at the right a huge blank space which wasn’t my plan… (Check the attached picture)<br />
Thank you for your help!<br />
<img src="/uploads/files/1476032703197-problem-resized.png" alt="0_1476032707196_Problem.png" class=" img-fluid img-markdown" /></p>
</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/6053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6053</guid><dc:creator><![CDATA[Patrick]]></dc:creator><pubDate>Sun, 09 Oct 2016 17:05:33 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Sun, 09 Oct 2016 16:34:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/patrick" aria-label="Profile: Patrick">@<bdi>Patrick</bdi></a> the correct css property is called margin-left not left-margin, maybe this was your mistake.</p>
<p dir="auto">you can post your css here so we can have a look on it</p>
]]></description><link>https://forum.magicmirror.builders/post/6046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6046</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 09 Oct 2016 16:34:45 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Sun, 09 Oct 2016 12:33:39 GMT]]></title><description><![CDATA[<p dir="auto">Did it work? I tried it aswell and have the problem, that i just adjust the left-margin?<br />
(tried it with custom &amp; main.css)</p>
<p dir="auto">Can someone help? :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/6035</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6035</guid><dc:creator><![CDATA[Patrick]]></dc:creator><pubDate>Sun, 09 Oct 2016 12:33:39 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Mon, 03 Oct 2016 23:07:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> @strawberry-3-141</p>
<p dir="auto">Thanks Guys</p>
]]></description><link>https://forum.magicmirror.builders/post/5758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5758</guid><dc:creator><![CDATA[andrewchumchal]]></dc:creator><pubDate>Mon, 03 Oct 2016 23:07:16 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Mon, 03 Oct 2016 22:36:31 GMT]]></title><description><![CDATA[<p dir="auto">Note that if you are trying to move it <em>down</em>, you won’t be able to because the newsfeed module takes up that space. Please look at the various regions on this post: <a href="https://forum.magicmirror.builders/topic/286/regions">https://forum.magicmirror.builders/topic/286/regions</a></p>
]]></description><link>https://forum.magicmirror.builders/post/5757</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5757</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 03 Oct 2016 22:36:31 GMT</pubDate></item><item><title><![CDATA[Reply to Move Module to corner on Mon, 03 Oct 2016 22:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andrewchumchal" aria-label="Profile: andrewchumchal">@<bdi>andrewchumchal</bdi></a> the body has a margin in main.css</p>
<pre><code>body {
  margin: 60px;
  position: absolute;
  height: calc(100% - 120px);
  width: calc(100% - 120px);
<p dir="auto">you could override that in custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/5756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5756</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Mon, 03 Oct 2016 22:17:34 GMT</pubDate></item></channel></rss>
