<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screen cannot rotate after upgrade to 2.4.0]]></title><description><![CDATA[<p dir="auto">Yesterday, after update to v2.4.0 and follow the <a href="https://github.com/michmich/magicmirror/wiki/configuring-the-raspberry-pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage" target="_blank" rel="noopener noreferrer nofollow ugc">wiki</a> Load normally with rotate-1</p>
<p dir="auto">Today, boot normally but the screen both on rp3 frontend and magic mirror didn’t rotate at all.</p>
<p dir="auto">Where do I need to re-correct this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/7594/screen-cannot-rotate-after-upgrade-to-2-4-0</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 05:41:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7594.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jul 2018 11:36:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screen cannot rotate after upgrade to 2.4.0 on Fri, 06 Jul 2018 12:13:00 GMT]]></title><description><![CDATA[<p dir="auto">Read and Read and found the solution regarding cannot upgrade to 2.4.0<br />
git reset --hard; git clean -df;</p>
]]></description><link>https://forum.magicmirror.builders/post/41286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41286</guid><dc:creator><![CDATA[Sun]]></dc:creator><pubDate>Fri, 06 Jul 2018 12:13:00 GMT</pubDate></item><item><title><![CDATA[Reply to Screen cannot rotate after upgrade to 2.4.0 on Fri, 06 Jul 2018 11:48:15 GMT]]></title><description><![CDATA[<p dir="auto">This time I try to upgrade another mirror got this</p>
<p dir="auto">pi@SAMUIMIRROR:~/MagicMirror $ git pull &amp;&amp; npm install<br />
Updating 60b9a5b…6aa156d<br />
error: Your local changes to the following files would be overwritten by merge:<br />
modules/default/alert/alert.js<br />
modules/default/calendar/README.md<br />
modules/default/calendar/calendar.js<br />
modules/default/calendar/calendarfetcher.js<br />
modules/default/compliments/README.md<br />
modules/default/compliments/compliments.js<br />
modules/default/currentweather/currentweather.js<br />
modules/default/newsfeed/README.md<br />
modules/default/newsfeed/fetcher.js<br />
modules/default/newsfeed/newsfeed.js<br />
modules/default/newsfeed/node_helper.js<br />
modules/default/weatherforecast/README.md<br />
modules/default/weatherforecast/weatherforecast.js<br />
package-lock.json<br />
translations/de.json<br />
translations/en.json<br />
translations/it.json<br />
translations/nl.json<br />
translations/pt_br.json<br />
translations/translations.js<br />
translations/zh_cn.json<br />
translations/zh_tw.json<br />
Please commit your changes or stash them before you merge.<br />
Aborting</p>
]]></description><link>https://forum.magicmirror.builders/post/41284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41284</guid><dc:creator><![CDATA[Sun]]></dc:creator><pubDate>Fri, 06 Jul 2018 11:48:15 GMT</pubDate></item><item><title><![CDATA[Reply to Screen cannot rotate after upgrade to 2.4.0 on Fri, 06 Jul 2018 11:44:54 GMT]]></title><description><![CDATA[<p dir="auto">After redo all the wiki step and reboot. Rotate correctly. Not sure if I have to set every time?</p>
]]></description><link>https://forum.magicmirror.builders/post/41283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41283</guid><dc:creator><![CDATA[Sun]]></dc:creator><pubDate>Fri, 06 Jul 2018 11:44:54 GMT</pubDate></item></channel></rss>
