<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing Custom Font Type Within Magic Mirror]]></title><description><![CDATA[<p dir="auto">I’m a bit new to the development involved regarding the Magic Mirror though an issue I haven’t been able to figure out, is changing font types  within the Magic Mirror. I am trying to install some very modernistic fonts: “Luxia” and “Alcubierre”, though when I follow the instructions <a href="https://forum.magicmirror.builders/topic/5505/change-font-of-modules-local-fonts/2">https://forum.magicmirror.builders/topic/5505/change-font-of-modules-local-fonts/2</a>  from this topic post, my Magic Mirror font doesn’t change to the desired fonts but to that shown in the image attached.</p>
<p dir="auto">Additionally, I had a few questions concerning this topic:</p>
<ol>
<li>
<p dir="auto">Do you only edit the Custom.css file and not the Main.css file?</p>
</li>
<li>
<p dir="auto">What formats/extensions do I need to have my font files in, when they’re located in “/home/pi/MagicMirror/fonts/”<br />
(People have mentioned .ttf, .woff, .woff2 but I am unsure how to proceed and which option(s) to implement in my code)</p>
</li>
<li>
<p dir="auto">What should a finished Custom.css file look like with these font additions? (I’m unsure of placement of the code concerning the body section:</p>
</li>
</ol>
<pre><code>body{
<p dir="auto">Any help on this topic would be greatly appreciated!<br />
<img src="/assets/uploads/files/1530918403215-img_5107-resized.jpg" alt="0_1530918399467_IMG_5107.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/7598/changing-custom-font-type-within-magic-mirror</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 00:11:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7598.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Jul 2018 23:07:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing Custom Font Type Within Magic Mirror on Mon, 09 Jul 2018 02:19:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> Ah, that seems to be what the problem was. Thank you so much for your help in solving this issue!</p>
<p dir="auto">As for the two different files I went ahead and removed the .woff file from the program.</p>
]]></description><link>https://forum.magicmirror.builders/post/41359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41359</guid><dc:creator><![CDATA[Winter]]></dc:creator><pubDate>Mon, 09 Jul 2018 02:19:32 GMT</pubDate></item><item><title><![CDATA[Reply to Changing Custom Font Type Within Magic Mirror on Sun, 08 Jul 2018 12:08:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winter" aria-label="Profile: winter">@<bdi>winter</bdi></a></p>
<p dir="auto">check you have the spelling correct for the filename, and use only the ttf file (I don’t know why there is two different format files for the same font anyways)</p>
]]></description><link>https://forum.magicmirror.builders/post/41333</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41333</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 08 Jul 2018 12:08:36 GMT</pubDate></item><item><title><![CDATA[Reply to Changing Custom Font Type Within Magic Mirror on Sun, 08 Jul 2018 09:14:46 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a>, I tried your edits and it seems that “Luxia” is now working, though when I try the exact setup for “Alcubierre”, it defaults back to the font shown in the first image I attached. Would you suggest trying to reinstall the font for Alcubierre and seeing if that works or would you have any further recommendations?</p>
]]></description><link>https://forum.magicmirror.builders/post/41330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41330</guid><dc:creator><![CDATA[Winter]]></dc:creator><pubDate>Sun, 08 Jul 2018 09:14:46 GMT</pubDate></item><item><title><![CDATA[Reply to Changing Custom Font Type Within Magic Mirror on Sun, 08 Jul 2018 07:24:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winter" aria-label="Profile: winter">@<bdi>winter</bdi></a></p>
<p dir="auto">Updates to the magicmirror software.<br />
You can keep the changes in the main.css, but you will get an error the day you try to update the magicmirror to a newer version.</p>
<p dir="auto">Try using this :</p>
<pre><code>	@font-face{
	  font-family: Luxia;
	  src: url("../fonts/Luxia-Display.ttf") format("truetype");
<p dir="auto">Note that the file path is based on where your css files is and where the fonts are.</p>
<p dir="auto">You can place the fonts directly in to the css folder, if you do that the file path (url) would be like this :</p>
	  font-family: Luxia;
	  src: url("Luxia-Display.ttf") format("truetype");
]]></description><link>https://forum.magicmirror.builders/post/41329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41329</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 08 Jul 2018 07:24:07 GMT</pubDate></item><item><title><![CDATA[Reply to Changing Custom Font Type Within Magic Mirror on Sat, 07 Jul 2018 20:36:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello Broberg,</p>
<p dir="auto">I have attached the code for both my custom.css and main.css files below:</p>
<p dir="auto">Also, addressing your mention of an “update”, is that an update in terms of the software or an edit by the user to the default main.css?</p>
<p dir="auto"><strong>Custom.css file</strong>:</p>
<pre><code>/*****************************************************
 * Magic Mirror                                      *
 * Custom CSS                                        *
 * By Michael Teeuw http://michaelteeuw.nl           *
 * MIT Licensed.                                     *
 * Add any custom CSS below.                         *
 * Changes to this files will be ignored by GIT. *
body {
	@font-face {
	  font-family: Alcubierre;
	  font-style: normal;
	  font-weight: 100;
	  src: url("/home/pi/MagicMirror/fonts/Alcubierre.ttf") format("truetype");
	  src: url("/home/pi/MagicMirror/fonts/Alcubierre.woff") format("woff");
	@font-face{
	  font-family: Luxia;
	  src: url("/home/pi/MagicMirror/fonts/Luxia-Display.ttf") format("truetype");
	  font-weight: normal;
	  font-style: normal;
	.calendar {
	   font-family: Luxia;
<p dir="auto">When I run the mirror, I keep either the Luxia or the Alcubierre section commented so only one runs. Though, as you can see here, I have the Luxia font in “.ttf” format and the Alcubierre font in both “.ttf” and “.woff” format, yet when I run the program neither file seems to achieve the desired result of changing my font to either “Luxia” or “Alcubierre”.</p>
<hr />
<p dir="auto">I have also attached my <strong>main.css</strong> file because I may have unknowingly made a few edits to it which might’ve caused the custom.css file to not run properly.</p>
<p dir="auto"><strong>Main.css:</strong></p>
<pre><code>html {
  cursor: none;
  overflow: hidden;
  background: #000;
::-webkit-scrollbar {
  display: none;
body {
  margin: 60px;
  position: absolute;
  height: calc(100% - 120px);
  width: calc(100% - 120px);
  background: #000;
  color: #aaa;
  //font-family: "Roboto Thin", sans-serif;
  //font-family: "Montserrat", sans-serif;
  //font-family: Luxia;
  font-style: normal;
  font-weight: 400;
  font-size: 2em;
  line-height: 1.5em;
  -webkit-font-smoothing: antialiased;
 * Default styles.
.dimmed {
  //color: #666;
  color: #fff;
.normal {
  //color: #999;
  color: #fff;
.bright {
  color: #fff;
.xsmall {
  font-size: 15px;
  line-height: 20px;
.small {
  font-size: 20px;
  line-height: 25px;
.medium {
  font-size: 30px;
  line-height: 35px;
.large {
  font-size: 65px;
  line-height: 65px;
.xlarge {
  font-size: 75px;
  line-height: 75px;
  letter-spacing: -3px;
.thin {
  //font-family: Roboto, sans-serif;
  font-weight: 100;
.light {
  //font-family: "Roboto Condensed", sans-serif;
  font-weight: 300;
.regular {
  font-weight: 400;
.bold {
  font-weight: 700;
.align-right {
  text-align: right;
.align-left {
  text-align: left;
header {
  //text-transform: uppercase;
  font-size: 25px;
  //font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
  //font-family: "Roboto Condensed";
  font-weight: 400;
  border-bottom: 1px solid #999;
  line-height: 15px;
  padding-bottom: 5px;
  margin-bottom: 10px;
  //color: #999;
  color: #fff;
sup {
  font-size: 50%;
  line-height: 50%;
 * Module styles.
.module {
  margin-bottom: 30px;
.region.bottom .module {
  margin-top: 30px;
  margin-bottom: 0;
.no-wrap {
  white-space: nowrap;
  overflow: hidden;
  text-overflow: ellipsis;
 * Region Definitions.
.region {
  position: absolute;
.region.fullscreen {
  position: absolute;
  top: -60px;
  left: -60px;
  right: -60px;
  bottom: -60px;
  pointer-events: none;
.region.fullscreen * {
  pointer-events: auto;
.region.right {
  right: 0;
  text-align: right;
.region.top {
  top: 0;
.region.top .container {
  margin-bottom: 25px;
.region.bottom .container {
  margin-top: 25px;
.region.top .container:empty {
  margin-bottom: 0;
.region.top.center,
.region.bottom.center {
  left: 50%;
  -moz-transform: translateX(-50%);
  -o-transform: translateX(-50%);
  -webkit-transform: translateX(-50%);
  -ms-transform: translateX(-50%);
.region.top.right,
.region.top.left,
.region.top.center {
  top: 100%;
.region.bottom {
  bottom: 0;
.region.bottom .container:empty {
  margin-top: 0;
.region.bottom.right,
.region.bottom.center,
.region.bottom.left {
  bottom: 100%;
.region.bar {
  width: 100%;
  text-align: center;
.region.third,
.region.middle.center {
  width: 100%;
  text-align: center;
  -moz-transform: translateY(-50%);
  -o-transform: translateY(-50%);
  -webkit-transform: translateY(-50%);
  -ms-transform: translateY(-50%);
.region.upper.third {
  top: 33%;
  top: 50%;
.region.lower.third {
  top: 66%;
.region.left {
  text-align: left;
.region table {
  width: 100%;
  border-spacing: 0;
  border-collapse: separate;
]]></description><link>https://forum.magicmirror.builders/post/41306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41306</guid><dc:creator><![CDATA[Winter]]></dc:creator><pubDate>Sat, 07 Jul 2018 20:36:02 GMT</pubDate></item><item><title><![CDATA[Reply to Changing Custom Font Type Within Magic Mirror on Sat, 07 Jul 2018 06:43:15 GMT]]></title><description><![CDATA[<p dir="auto">Yes, only the custom.css (anything written in the custom.css will override the same values in main.css)<br />
And if you edit the main.css and update your mirror the update will overwrite the main.css and your changes within. This doesn’t happen with custom.css.</p>
<p dir="auto">To see where you went wrong, pleas post your custom.css file.</p>
<p dir="auto">But common things to adress, search path to the font file, the font file sets the format, what does your files end with?</p>
<p dir="auto">place new css-code after body{}</p>
]]></description><link>https://forum.magicmirror.builders/post/41297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/41297</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sat, 07 Jul 2018 06:43:15 GMT</pubDate></item></channel></rss>
