<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror not starting after upgrade on Raspberry Pi2]]></title><description><![CDATA[<p dir="auto">I upgraded MM today to version 2.4.1 on my raspberry Pi 2. I did the npm install but now getting the following error:</p>
<p dir="auto">0 info it worked if it ends with ok<br />
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]<br />
2 info using npm@1.4.21<br />
3 info using node@v4.8.2<br />
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]<br />
5 info prestart magicmirror@2.4.1<br />
6 info start magicmirror@2.4.1<br />
7 verbose unsafe-perm in lifecycle true<br />
8 info magicmirror@2.4.1 Failed to exec start script<br />
9 error magicmirror@2.4.1 start: <code>sh run-start.sh</code><br />
9 error Exit status 127<br />
10 error Failed at the magicmirror@2.4.1 start script.<br />
10 error This is most likely a problem with the magicmirror package,<br />
10 error not with npm itself.<br />
10 error Tell the author that this fails on your system:<br />
10 error     sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
10 error You can get their info via:<br />
10 error     npm owner ls magicmirror<br />
10 error There is likely additional logging output above.<br />
11 error System Linux 4.14.52-v7+<br />
12 error command “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
13 error cwd /home/pi/MagicMirror<br />
14 error node -v v4.8.2<br />
15 error npm -v 1.4.21<br />
16 error code ELIFECYCLE<br />
17 verbose exit [ 1, true ]</p>
]]></description><link>https://forum.magicmirror.builders/topic/7612/magic-mirror-not-starting-after-upgrade-on-raspberry-pi2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 23:11:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/7612.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Jul 2018 16:33:29 GMT</pubDate><ttl>60</ttl></channel></rss>
