<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-voice]]></title><description><![CDATA[<p dir="auto">After a long development process here is an offline voice recognition module</p>
<p dir="auto">[card:fewieden/MMM-voice]</p>
<p dir="auto">Features:</p>
<ul>
<li>
<p dir="auto">Turn HDMI on/off</p>
</li>
<li>
<p dir="auto">Hide/Show all modules</p>
</li>
</ul>
<p dir="auto">With this module, you’re also able to <strong>control other modules</strong> like:</p>
<p dir="auto">[card:fewieden/MMM-Fuel] [card:fewieden/MMM-NFL] [card:fewieden/MMM-ip] [card:fewieden/MMM-soccer]</p>
<p dir="auto">Complete list of supported modules can be found <a href="https://github.com/fewieden/MMM-voice/wiki/Supported-Modules" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
<p dir="auto">You want your module to be supported as well? Take a look on the <a href="https://github.com/fewieden/MMM-voice/blob/master/DEVELOPER.md" target="_blank" rel="noopener noreferrer nofollow ugc">developers guide</a></p>
<p dir="auto"><em>There is a hidden easteregg, who can find it?</em></p>
<p dir="auto">Thanks to all who helped me with this</p>
]]></description><link>https://forum.magicmirror.builders/topic/778/mmm-voice</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 13:10:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/778.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Oct 2016 19:48:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-voice on Thu, 19 Aug 2021 20:58:38 GMT]]></title><description><![CDATA[<p dir="auto">Just like MMM-Voice-Commands, annyang does not work when Magic Mirror is run using some browsers. In order to ensure that it works, use chrome or firefox if possible.</p>
]]></description><link>https://forum.magicmirror.builders/post/93812</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93812</guid><dc:creator><![CDATA[selina0001]]></dc:creator><pubDate>Thu, 19 Aug 2021 20:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Thu, 08 Jul 2021 10:56:54 GMT]]></title><description><![CDATA[<p dir="auto">sudo chmod 777 worked for me, thanks<a href="https://tomzpot.com/" target="_blank" rel="noopener noreferrer nofollow ugc">.</a> <a href="https://mdro.fun/mobdro/" target="_blank" rel="noopener noreferrer nofollow ugc">.</a></p>
]]></description><link>https://forum.magicmirror.builders/post/92631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92631</guid><dc:creator><![CDATA[ballzop]]></dc:creator><pubDate>Thu, 08 Jul 2021 10:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Sat, 25 Apr 2020 23:01:50 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 Hi, Having the error “spawn pocketsphinx_continuous ENOENT-2” right here. How can I replace the correct files?? Like you said earlier: “his problem was that somehow his ~/.bashrc file got overwritten and then he missed the path to pocketsphinx files”</p>
<p dir="auto">Thanks so far.</p>
]]></description><link>https://forum.magicmirror.builders/post/73576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73576</guid><dc:creator><![CDATA[bjorndegroot]]></dc:creator><pubDate>Sat, 25 Apr 2020 23:01:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Fri, 03 Apr 2020 13:57:18 GMT]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/778/mmm-voice">MMM-voice</a><br />
Hey<br />
Trying to run MMM-Voice on Windows. The manufacturer has blocked the option of uploading UBUNTU.</p>
<p dir="auto">I have such a mistake.</p>
<pre><code>[STEP 1/5] Installing Packages
dependencies.sh: line 36: sudo: command not found
[STEP 1/5] Installing Packages | Failed
dependencies.sh: line 36: apt-get: command not found
<p dir="auto">I tried to install packages one at a time but without much effect</p>
]]></description><link>https://forum.magicmirror.builders/post/71754</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71754</guid><dc:creator><![CDATA[marcinek__85]]></dc:creator><pubDate>Fri, 03 Apr 2020 13:57:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 26 Feb 2019 21:54:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: egnos">@<bdi>egnos</bdi></a> said in <a href="/post/53023">MMM-voice</a>:</p>
<p dir="auto">If I say “OPEN HELP” it understands “OPEN OF OF” or “OPEN THE”<br />
If I say “MAGIC MIRROR” he understands “MAGIC TO”</p>
<p dir="auto">The recognition is not as accurate a Google Home or an Amazon Alexa. Take into account that this is not cloud based recognition. You almost have to learn how to speak to MMM-voice correctly to minimize the false positives and negatives. I’ve been using MMM-voice(Hello-Lucy) for a long time. I’ve learned how to speak to her so that my success rate is more than acceptable.</p>
<p dir="auto">Also, I have a friend in Norway that speaks English perfectly. However, MMM-voice(Hello-Lucy) has some trouble with his Norwegian accent but his Google Home has no trouble at all. That’s the benefit of cloud based recognition.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: egnos">@<bdi>egnos</bdi></a> said in <a href="/post/53190">MMM-voice</a>:</p>
<p dir="auto">No advice for the purchase?</p>
<p dir="auto">The little usb microphone that you are using is <em><strong>behind</strong></em> the mirror? I think this will lessen your chances of success. Any sounds behind the mirror will certainly interfere and your voice commands will have difficulty reaching it. I don’t have a USB microphone recommendation but anything you do get you should expose somehow to the front of the mirror so that the user’s voice has the best chance of reaching the microphone unimpeded.</p>
]]></description><link>https://forum.magicmirror.builders/post/53245</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53245</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 26 Feb 2019 21:54:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 26 Feb 2019 08:49:26 GMT]]></title><description><![CDATA[<p dir="auto">No advice for the purchase?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/53190</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53190</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Tue, 26 Feb 2019 08:49:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Sat, 23 Feb 2019 00:26:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone!<br />
MMM-voice does not understand what I say!<br />
For example:</p>
<ul>
<li>If I say “OPEN HELP” it understands “OPEN OF OF” or “OPEN THE”</li>
<li>If I say “MAGIC MIRROR” he understands “MAGIC TO”</li>
</ul>
<p dir="auto">I think nobody has had these problems … correct?</p>
<p dir="auto">I’m starting to think that the problem is the quality of the microphone.<br />
I bought this microphone <a href="https://www.amazon.com/SunFounder-Microphone-Raspberry-Recognition-Software/dp/B01KLRBHGM/ref=sr_1_1?keywords=microphone+for+raspberry&amp;qid=1550880769&amp;s=gateway&amp;sr=8-1" target="_blank" rel="noopener noreferrer nofollow ugc">Microphone-Raspberry-Recognition</a>.</p>
<p dir="auto">I have recording a test and I hear a background noise…<br />
<strong>Can someone recommend a good microphone?</strong></p>
<p dir="auto">Thank you all.</p>
]]></description><link>https://forum.magicmirror.builders/post/53023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53023</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Sat, 23 Feb 2019 00:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Wed, 13 Feb 2019 01:12:00 GMT]]></title><description><![CDATA[<p dir="auto">Thank @strawberry-3-141 … he worked very hard on this and did a great job!</p>
]]></description><link>https://forum.magicmirror.builders/post/52245</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52245</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 13 Feb 2019 01:12:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 12 Feb 2019 15:49:13 GMT]]></title><description><![CDATA[<p dir="auto">Hey guys,<br />
first of all thank u so much for creating this module @strawberry-3-141 i love it!<br />
and <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> thanks for the solution it works perfect for me with</p>
<pre><code>LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
<p dir="auto">I wasted a half year ago a couple of weeks with this module because it does not work for me, till now!<br />
Yesterday i’ve reinstalled the Whole MM on a fresh Raspbian system and read all the comments here.</p>
<p dir="auto">But there is one question still alive, i am in struggle with the commands i am not sure if i say it right.</p>
<p dir="auto">MAGIC MIRROR -&gt; VOICE = (going to Voice Mode)<br />
(VOICE flashing) -&gt; HIDE MODULES, SHOW MODULES, GOING TO SLEEP, WAKE UP</p>
<p dir="auto">That works fine.</p>
<p dir="auto">But what should i do if (VOICE) don’t flashing?<br />
and are there different modes instead of VOICE?<br />
oh and last but not least if i say (in flashing voice mode) Open Help or Close Help nothing happens :/</p>
]]></description><link>https://forum.magicmirror.builders/post/52187</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52187</guid><dc:creator><![CDATA[Arzeg]]></dc:creator><pubDate>Tue, 12 Feb 2019 15:49:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Mon, 29 Oct 2018 00:15:56 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 Well i tried to install PulseAudio and use that instead of straight ALSA and configured it right according to the settings i found , i also removed and installed again MMM-voice but still the same error persists.<br />
I tired every which way to tweak it as much as i could to make it work, for what i know cause i am no expert, but still no luck.<br />
What can i do other than a fresh Rpi install that i dont want to do cause i have so many modules installed already??<br />
D</p>
]]></description><link>https://forum.magicmirror.builders/post/46046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46046</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Mon, 29 Oct 2018 00:15:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Thu, 25 Oct 2018 20:47:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> I’m sorry I can’t really tell you something other than what I find  googling myself, I never experienced sth similar other than couldn’t open device resource is busy.</p>
]]></description><link>https://forum.magicmirror.builders/post/45898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45898</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Thu, 25 Oct 2018 20:47:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Wed, 24 Oct 2018 22:06:21 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 I know i have ALSA on my system but i don’t recall ever having to install Pulseaudio on my system. Is it required by this module? pulse audio that is …can i install it??<br />
Denis</p>
]]></description><link>https://forum.magicmirror.builders/post/45861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45861</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Wed, 24 Oct 2018 22:06:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Wed, 24 Oct 2018 19:27:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> it looks like it is a problem between alsa and pulseaudio <a href="https://sourceforge.net/p/cmusphinx/discussion/help/thread/c39732a2/" target="_blank" rel="noopener noreferrer nofollow ugc">https://sourceforge.net/p/cmusphinx/discussion/help/thread/c39732a2/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/45850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45850</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 24 Oct 2018 19:27:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Wed, 24 Oct 2018 03:50:50 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 Hello there,<br />
I tested the mics following the steps on the above site and my microphone works just fine no errors the audio is good coming from the speakers and clear i do get a warning that does not affect anything that says:<br />
“Warning: rate is not accurate (requested = 44100Hz, got = 48000Hz)<br />
please, try the plug plugin”<br />
but it does not affect the audio or the command actually when i try another mic it does not give me that error at all however the audio is not nearly as good.<br />
So to recap the mic works it records a test file and gives no errors.</p>
<p dir="auto">D</p>
]]></description><link>https://forum.magicmirror.builders/post/45835</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45835</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Wed, 24 Oct 2018 03:50:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 23 Oct 2018 05:19:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> can you check the following to see if another program can access the mic <a href="https://scribles.net/voice-recording-on-raspberry-pi/" target="_blank" rel="noopener noreferrer nofollow ugc">https://scribles.net/voice-recording-on-raspberry-pi/</a></p>
<p dir="auto">Is there already another Programm running in the background which is accessing the mic?</p>
]]></description><link>https://forum.magicmirror.builders/post/45756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45756</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 23 Oct 2018 05:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 23 Oct 2018 04:29:45 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 Thank you so much for replying back to me :)<br />
Did what you asked and on the MM itself it says Error Undefined but on the debug log everything sems to go fine until the very last sentence that says this:</p>
<p dir="auto">“Error opening audio device plughw:1 for capture: Connection refused<br />
FATAL: “continuous.c”, line 245: Failed to open audio device”</p>
<p dir="auto">When i run “cat /proc/asound/cards” i get this<br />
“0 [ALSA           ]: bcm2835_alsa - bcm2835 ALSA<br />
bcm2835 ALSA<br />
1 [Set            ]: USB-Audio - USB Headphone Set<br />
USB Headphone Set at usb-3f980000.usb-1.5, full speed”</p>
<p dir="auto">And in the config.js file obviously i have selected the only mic i have right now number 1 USB headphone set and i know it is working just fine.</p>
<p dir="auto">Let me know how what does that tell you<br />
and again thank you<br />
Denis</p>
]]></description><link>https://forum.magicmirror.builders/post/45755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45755</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Tue, 23 Oct 2018 04:29:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Mon, 22 Oct 2018 05:38:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> can you please enable temporarily the more detailed debug log with <code>debug: true</code>?</p>
]]></description><link>https://forum.magicmirror.builders/post/45725</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45725</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Mon, 22 Oct 2018 05:38:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Sun, 21 Oct 2018 23:13:52 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 OK i am trying to install this module and i have read all forum posts on this thread.<br />
I did have AlexaPi installed and working previously and as i can tell from other users this installation ruins it but i could live with that. However MMM-voice keeps giving error 1 on its error log even after deleting node modules, pocketsphinx and sphinxbase and reinstalling again. The icon on MM goes briefly Ready Select Mode than back to Error how do i fix that like i said i have read everything all installations go perfectly all 1 through 5 out of 5.  what am i doing wrong??<br />
The other question is… I also want to use 2 microphones ideally and both apps… i was using AlexaPi flawlessly with one of the mics and i wanted to use a second mic for MMM-voice since it gives you the option to select which one you want to use do you think that is doable? is it meant for that??<br />
What can i do to use both AlexaPi and one of the MMM voice modules so i can control the display and show and hide certain modules both on the same Rpi.<br />
I tried MMM-MirrorMirrorOnTheWall already but i am stuck half way with no one to help me through the end and it is an extremely difficult module to fully install.<br />
Anyhow any help will be greatly appreciated<br />
Denis</p>
]]></description><link>https://forum.magicmirror.builders/post/45721</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45721</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Sun, 21 Oct 2018 23:13:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Wed, 06 Jun 2018 14:28:05 GMT]]></title><description><![CDATA[<p dir="auto">ok, got it… voice detection is sensitive…</p>
]]></description><link>https://forum.magicmirror.builders/post/40232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40232</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Jun 2018 14:28:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 05 Jun 2018 20:33:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I can tell you the same as I just told another user</p>
<p dir="auto">as the author of MMM-voice I can tell you, that my module doesn’t support a command called hide clock at all. You are probably using hello-lucy, at least that’s a mod I’m aware of which enhances the commands. You can see the command list here <a href="https://github.com/fewieden/MMM-voice#usage" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fewieden/MMM-voice#usage</a></p>
<p dir="auto">i also had problems due to my accent. you can also look into the dic file how the system expects you to pronounce it</p>
]]></description><link>https://forum.magicmirror.builders/post/40222</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40222</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 05 Jun 2018 20:33:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 05 Jun 2018 17:05:13 GMT]]></title><description><![CDATA[<p dir="auto">i have that, but the text ‘recognized’ is not what i said.</p>
<p dir="auto">if I speak slowly, i can get ‘magic mirror’<br />
then wake up is ‘wake go’ or ‘wake all’,</p>
<p dir="auto">hide calendar is ‘hide who’<br />
open help is ‘open go’</p>
<p dir="auto">the smart-mirror project also uses ‘go to sleep’ and ‘wakeup’</p>
<p dir="auto">‘hide newsfeed’ is ‘hide to show the’, ‘hide is the’</p>
<p dir="auto">none of the commands, when recognized, do anything…</p>
<p dir="auto">hide modules</p>
<p dir="auto">go to sleep (not on PI so the tvservice doesn’t exist), but no error is logged</p>
]]></description><link>https://forum.magicmirror.builders/post/40218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40218</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 05 Jun 2018 17:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Tue, 05 Jun 2018 05:27:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> set <code>debug: true</code> in the config and you will see what the mirror recognizes</p>
]]></description><link>https://forum.magicmirror.builders/post/40205</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40205</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 05 Jun 2018 05:27:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Mon, 04 Jun 2018 23:07:57 GMT]]></title><description><![CDATA[<p dir="auto">i am running MMM-voice on an ODroid Xu4, which is very fast.</p>
<p dir="auto">I also use another voice enabled smart mirror on this same device.</p>
<p dir="auto">with a Logitech webcam as the mic.</p>
<p dir="auto">MMM-voice gets the hotword correct every time, but almost none of the following words.</p>
<p dir="auto">the same hardware setup works correctly with arecord as the wav source, but uses google speech detection for everything after the hotword.</p>
<p dir="auto">it appears the system is using the default language model (lm) and dictation (dic) files.</p>
<p dir="auto">anyone have a suggestion on debugging this?</p>
]]></description><link>https://forum.magicmirror.builders/post/40202</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40202</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Jun 2018 23:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-voice on Thu, 26 Apr 2018 14:02:30 GMT]]></title><description><![CDATA[<p dir="auto">I wrote this in a different thread not too long ago actually, but I noticed a <em>vast</em> increase in detection/response rate when moving from a cheap USB mic to a decent webcam microphone. I would say the response now is on the order of 1-2 secs, with effectively no errors in voice interpretation. I’m sure this is helped immensely because the clarity of the audio into the rpi is much clearer - the cheap USB mic had terribly noisy audio in.</p>
]]></description><link>https://forum.magicmirror.builders/post/38934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38934</guid><dc:creator><![CDATA[joe84maiden]]></dc:creator><pubDate>Thu, 26 Apr 2018 14:02:30 GMT</pubDate></item></channel></rss>
