<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Wunderlist not updating]]></title><description><![CDATA[<p dir="auto">I have been using this module for some time now and its great, I keep our weekly menu on it.  I have noticed though it has stopped updating itself.  So when i add/remove items from the website or phone app it doesn’t reflect that in the module.  I need to start/stop MM2 in order for it to refresh.</p>
<p dir="auto">Anyone have any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/topic/782/mmm-wunderlist-not-updating</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 07:56:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/782.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Oct 2016 23:20:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Fri, 18 May 2018 16:00:08 GMT]]></title><description><![CDATA[<p dir="auto">This diffuse situation is the reason I stopped updating the module. Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/arnecl" aria-label="Profile: ArneCL">@<bdi>ArneCL</bdi></a> for still working on it!</p>
]]></description><link>https://forum.magicmirror.builders/post/39605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39605</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Fri, 18 May 2018 16:00:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Fri, 18 May 2018 14:15:05 GMT]]></title><description><![CDATA[<p dir="auto">The problem is based on the fact that MMM-Wunderlist currently uses the <em>official</em> (but deprecated) wunderlist-module to access the API. Looking around and finding no suitable replacement for Wunderlist, I created a fix for this, which seems to run stable (at least for the last two days). (I also recently created a PR which allows the use of multiple accounts and multiple instance with MMM-Wunderlist …)</p>
<p dir="auto"><strong>If you would appreciate a fix, give this post an upvote</strong> (As a PR still means work…)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schwoediauer" aria-label="Profile: schwoediauer">@<bdi>schwoediauer</bdi></a>  You are right, the situation about wunderlist is quite diffuse. According to <a href="https://6wunderkinder.desk.com/customer/en/portal/articles/2790249-what-s-next-for-wunderlist-" target="_blank" rel="noopener noreferrer nofollow ugc">them</a>, wunderlist will be discontinued in the long run :crying_face:  (talking <em>years</em>?). However, the IOs App has been updated quite recently (30th March 2018), so they still seem to keep it alive (?). For me Microsoft ToDo can not replace the <em>to-the-point</em>ness of wunderlist…</p>
]]></description><link>https://forum.magicmirror.builders/post/39601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39601</guid><dc:creator><![CDATA[ArneCL]]></dc:creator><pubDate>Fri, 18 May 2018 14:15:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Wed, 14 Feb 2018 19:18:17 GMT]]></title><description><![CDATA[<p dir="auto">I think wunderlis will merge or migrate to Microsoft To-Do. Maybe we should work on this solution instead of debuging the MMM-Wunderlist module</p>
]]></description><link>https://forum.magicmirror.builders/post/35711</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35711</guid><dc:creator><![CDATA[schwoediauer]]></dc:creator><pubDate>Wed, 14 Feb 2018 19:18:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Wed, 14 Feb 2018 15:15:27 GMT]]></title><description><![CDATA[<p dir="auto">This is in some way a problem of Wunderlist. :/</p>
<p dir="auto">So nothing u can do as far as i know. I searched long for a solution until i finally disabled the module. :(</p>
<p dir="auto">Maybe u try this: <a href="https://forum.magicmirror.builders/topic/566/mmm-todoist-your-todoist-tasks-on-your-mirror">https://forum.magicmirror.builders/topic/566/mmm-todoist-your-todoist-tasks-on-your-mirror</a></p>
<p dir="auto">i didn’t try it yet</p>
]]></description><link>https://forum.magicmirror.builders/post/35706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35706</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Wed, 14 Feb 2018 15:15:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Wed, 14 Feb 2018 06:28:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi community, I have the same problem and no solution is available until now?</p>
]]></description><link>https://forum.magicmirror.builders/post/35689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35689</guid><dc:creator><![CDATA[schwoediauer]]></dc:creator><pubDate>Wed, 14 Feb 2018 06:28:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Wed, 03 Jan 2018 18:46:18 GMT]]></title><description><![CDATA[<p dir="auto">Got the same problem.<br />
Runs for a few hours and then the module seems to freeze. Doesn’t update anymore.</p>
<p dir="auto">this morning i did a “pm2 flush”<br />
This evening i checked the “pm2 logs”</p>
<pre><code>0|mm       | there was a Wunderlist problem { error:
0|mm       |    { type: 'server_error',
0|mm       |      translation_key: 'api_error_unknown',
0|mm       |      message: 'An unknown server error occurred' } } 500
<p dir="auto">Maybe someone has an idea…</p>
]]></description><link>https://forum.magicmirror.builders/post/33278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33278</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Wed, 03 Jan 2018 18:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Thu, 07 Sep 2017 12:45:35 GMT]]></title><description><![CDATA[<p dir="auto">Guessing everyone gave up with this then?</p>
]]></description><link>https://forum.magicmirror.builders/post/27749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27749</guid><dc:creator><![CDATA[joela85]]></dc:creator><pubDate>Thu, 07 Sep 2017 12:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Mon, 21 Aug 2017 10:48:10 GMT]]></title><description><![CDATA[<p dir="auto">Did anyone find any solutions to this? I’m facing the same problem. Have not set up a crontab to restart yet. Was hoping for a different solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/26813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26813</guid><dc:creator><![CDATA[joela85]]></dc:creator><pubDate>Mon, 21 Aug 2017 10:48:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Wed, 31 May 2017 23:06:20 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem. Any one have a solution other than reboot cron job. Seems like a bandaid.</p>
]]></description><link>https://forum.magicmirror.builders/post/22242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22242</guid><dc:creator><![CDATA[Chiumanfu]]></dc:creator><pubDate>Wed, 31 May 2017 23:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Tue, 18 Apr 2017 18:35:40 GMT]]></title><description><![CDATA[<p dir="auto">Ok. I have problem with update lists.<br />
I use crontab to restart MM 12 times a day after 2hours work<br />
Pm2 reload not help.</p>
<p dir="auto">i don’t see any errors in log.<br />
The same issue i have with todolist plugin.</p>
<p dir="auto">Is any chance to solve this problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/19895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19895</guid><dc:creator><![CDATA[Ed]]></dc:creator><pubDate>Tue, 18 Apr 2017 18:35:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Sat, 12 Nov 2016 22:45:44 GMT]]></title><description><![CDATA[<p dir="auto">May its not enough if you make “pm2 reload &lt;<a href="http://magicmirrorscript.sh" target="_blank" rel="noopener noreferrer nofollow ugc">magicmirrorscript.sh</a>&gt;”? By then a reboot is not necessary.</p>
]]></description><link>https://forum.magicmirror.builders/post/7841</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7841</guid><dc:creator><![CDATA[tajno]]></dc:creator><pubDate>Sat, 12 Nov 2016 22:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Sat, 12 Nov 2016 14:45:33 GMT]]></title><description><![CDATA[<p dir="auto">Hey all,<br />
I had the same issue, there is a good troubleshooting thread here <a href="https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/85">https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/85</a></p>
<p dir="auto">I ended up setting up a cron job to restart the pi and mirror each night at 2am and increased the wunderlist update interval to 120.  That was about 2 weeks ago and so far so good.</p>
]]></description><link>https://forum.magicmirror.builders/post/7830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7830</guid><dc:creator><![CDATA[Sunburned]]></dc:creator><pubDate>Sat, 12 Nov 2016 14:45:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Thu, 10 Nov 2016 18:25:53 GMT]]></title><description><![CDATA[<p dir="auto">I have the same issue. I think it depends on the mirror is losing its wlan connection for some time. but I’m not sure… I can’t find anything in the logs.</p>
]]></description><link>https://forum.magicmirror.builders/post/7771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7771</guid><dc:creator><![CDATA[witschi87]]></dc:creator><pubDate>Thu, 10 Nov 2016 18:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Thu, 20 Oct 2016 05:45:43 GMT]]></title><description><![CDATA[<p dir="auto">I have the same issue. It gets updated for a few hours and then it just stops doing updates.<br />
The rest of the mirror like calendar and weather works fine. Changing the interval also doesnt seem to work.</p>
<p dir="auto">The same issue occurs with the news feed via rss.</p>
]]></description><link>https://forum.magicmirror.builders/post/6532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6532</guid><dc:creator><![CDATA[gverbist]]></dc:creator><pubDate>Thu, 20 Oct 2016 05:45:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Sun, 09 Oct 2016 00:22:19 GMT]]></title><description><![CDATA[<p dir="auto">Not that I have found, only logs I know about are under .pm2/logs</p>
]]></description><link>https://forum.magicmirror.builders/post/6016</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6016</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Sun, 09 Oct 2016 00:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderlist not updating on Sun, 09 Oct 2016 00:07:05 GMT]]></title><description><![CDATA[<p dir="auto">Are there any logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/6012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6012</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Sun, 09 Oct 2016 00:07:05 GMT</pubDate></item></channel></rss>
