<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(2.1.0) Possibility to use the the calendar feed as the source for the weather location data.]]></title><description><![CDATA[<p dir="auto">Starting from version 2.1.0 (currently the develop branch) the default modules will add the following functionality: Possibility to use the the calendar feed as the source for the weather (currentweather &amp; weatherforecast) location data.</p>
<p dir="auto">When the <code>location</code> and<code> locationID</code> are both not set, the location will be based on the information provided by the calendar module. The first upcoming event with location data will be used.</p>
<p dir="auto">Since this feature is still in the develop branch, it’s not final and might change. Suggestions are welcome.</p>
]]></description><link>https://forum.magicmirror.builders/topic/813/2-1-0-possibility-to-use-the-the-calendar-feed-as-the-source-for-the-weather-location-data</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 21:52:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/813.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Oct 2016 15:45:47 GMT</pubDate><ttl>60</ttl></channel></rss>
