<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Turn On&#x2F;Off Screen - LCD Screen]]></title><description><![CDATA[<p dir="auto">Hello :)</p>
<p dir="auto">I have an LCD Screen and I’d like to turn it off when I’m not using the magic mirror.<br />
My problem is that  the tv displays the brand’s name for 5 seconds when it is turned on.</p>
<p dir="auto">I can’t figure out a way to solve this problem…<br />
Do you let your screen On 7/24 ?</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/topic/820/turn-on-off-screen-lcd-screen</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 01:43:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/820.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Oct 2016 13:31:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Turn On&#x2F;Off Screen - LCD Screen on Fri, 18 Nov 2016 15:58:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billycallahan" aria-label="Profile: BillyCallahan">@<bdi>BillyCallahan</bdi></a> Based on what <a class="plugin-mentions-user plugin-mentions-a" href="/user/dom1n1c" aria-label="Profile: Dom1n1c">@<bdi>Dom1n1c</bdi></a> said: My screen does not show the brand when it wakes up from standby, sometimes you might be able to find an option in the internal menu of the screen.</p>
<p dir="auto">As for triggering the <code>tvservice</code> commands, there are modules that do it automatically based on a <a href="https://github.com/paviro/MMM-PIR-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">PIR-Sensor</a> or via <a href="https://github.com/alexyak/motiondetector" target="_blank" rel="noopener noreferrer nofollow ugc">a webcam</a>. They switch on the screen when someone is moving in front of the mirror, and switch it off after a fixed time (e.g. 60 seconds).</p>
]]></description><link>https://forum.magicmirror.builders/post/8187</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8187</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Fri, 18 Nov 2016 15:58:19 GMT</pubDate></item><item><title><![CDATA[Reply to Turn On&#x2F;Off Screen - LCD Screen on Fri, 18 Nov 2016 10:01:49 GMT]]></title><description><![CDATA[<p dir="auto">i also see the “brands name” when turning it on, but cant disable it.<br />
switching the monitor (standby/wakeup) on a Raspberry Pi:<br />
tvservice -o<br />
tvservice -p</p>
]]></description><link>https://forum.magicmirror.builders/post/8157</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8157</guid><dc:creator><![CDATA[Dom1n1c]]></dc:creator><pubDate>Fri, 18 Nov 2016 10:01:49 GMT</pubDate></item></channel></rss>
