<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can i remove the Logo of Magic Mirror In start?]]></title><description><![CDATA[<p dir="auto">Can i remove the Logo of Magic Mirror In start?<br />
I want to start the magic mirror as fast as possible like power on and boom. The modules can  take time but other than that no other extra time for magic mirror to start.<br />
is there a way.</p>
]]></description><link>https://forum.magicmirror.builders/topic/8385/can-i-remove-the-logo-of-magic-mirror-in-start</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 13:31:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8385.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jul 2018 11:39:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can i remove the Logo of Magic Mirror In start? on Fri, 13 Jul 2018 11:04:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/postremalone" aria-label="Profile: postremalone">@<bdi>postremalone</bdi></a> Fastest way to <em>show</em> MM is to have the RPi already running, then simply turn on the the display. Check out <a href="https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app">this thread here</a> for use with a PIR or other sensor/button. Apparently, because it already draws such little power, <a href="https://github.com/raspberrypi/linux/issues/1281" target="_blank" rel="noopener noreferrer nofollow ugc">there is no desire to implement suspend on RPi</a>.</p>
<p dir="auto">As for speeding up boot, as <a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> said, the issue is not the logo, but booting the OS. You can strip down the Raspbian boot for speed, but it will never be instantaneous (sub 1 sec). You can <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=25777" target="_blank" rel="noopener noreferrer nofollow ugc">apparently get down to 10 seconds</a> with a stripped down distro and Class 10 SD card.</p>
]]></description><link>https://forum.magicmirror.builders/post/42227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42227</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Fri, 13 Jul 2018 11:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to Can i remove the Logo of Magic Mirror In start? on Wed, 11 Jul 2018 12:24:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/postremalone" aria-label="Profile: postremalone">@<bdi>postremalone</bdi></a> There is an OS to be started first and that takes most of the time. You possibly can optimise that, just google something like “booting raspbian faster”.<br />
Then, if you use pm2 as the manager, from my experience it takes some time until it loads MM. Maybe there is some other faster way, e.g. starting electron directly after the booting process via rc.local</p>
]]></description><link>https://forum.magicmirror.builders/post/42184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42184</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 11 Jul 2018 12:24:42 GMT</pubDate></item></channel></rss>
