<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Remote-Control warning in logs]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have some strange warning in the console log (npm or pm2 logs). As I don’t like that I investigate the origine by isolating all my modules one by one and the result is that it comes from MMM-Remote-Control.</p>
<p dir="auto">Here is the logs :</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
&gt; magicmirror@2.4.1 start /home/pi/MagicMirror
&gt; sh run-start.sh
Starting MagicMirror: v2.4.1
Loading config ...
Loading module helpers ...
Module helper loaded: MMM-Remote-Control
All module helpers loaded.
Server started ...
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control
Sockets connected &amp; modules started ...
Launching application.
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
(node:2669) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the      Node.js process with a non-zero exit code.
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
(node:2669) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
<p dir="auto">I had to say that the module itself is working fine, but this probably generate performance issues ?</p>
<p dir="auto">Is someone also experiencing it and with any explanations and/or solutions ?</p>
<p dir="auto">Thanks you all in advance,<br />
AgP</p>
]]></description><link>https://forum.magicmirror.builders/topic/8386/mmm-remote-control-warning-in-logs</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 22:40:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8386.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jul 2018 17:55:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Remote-Control warning in logs on Mon, 23 Jul 2018 06:55:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">no infortunatelly I didn’t find any solution yet.</p>
<p dir="auto">Bye,</p>
]]></description><link>https://forum.magicmirror.builders/post/42533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42533</guid><dc:creator><![CDATA[AgP42]]></dc:creator><pubDate>Mon, 23 Jul 2018 06:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control warning in logs on Sun, 22 Jul 2018 05:14:58 GMT]]></title><description><![CDATA[<p dir="auto">Hey did you ever find anything out about this?  I have been running this for a little over a week with it running solid.  Just last couple days its starting to just crash after a few minutes of running with the same errors in the logs.</p>
]]></description><link>https://forum.magicmirror.builders/post/42465</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42465</guid><dc:creator><![CDATA[darbos]]></dc:creator><pubDate>Sun, 22 Jul 2018 05:14:58 GMT</pubDate></item></channel></rss>
