<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Physical switch initiated with module in MM]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have a mirror to which RPI and Apple TV is connected - RPI to DVI, ATV to HDMI connector. I can switch between sources with switch on monitor (actually i extracted those switches and put them into mirror frame).<br />
But can I use RPI to “click the switch” using RPI’s GPIO?<br />
If so that it could be awesome to have a module for monitor steering - source selection or volume.<br />
Then module like MMM-Hover or any other button control module could be used to physically control display itself - there are always 5 or 6 buttons - so this module could just control push of those buttons…</p>
<p dir="auto">Can anyone build that kind of module? or maybe there is one already?</p>
<p dir="auto">Regards<br />
Mike</p>
]]></description><link>https://forum.magicmirror.builders/topic/8395/physical-switch-initiated-with-module-in-mm</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 20:43:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8395.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Jul 2018 12:08:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Physical switch initiated with module in MM on Mon, 16 Jul 2018 19:46:21 GMT]]></title><description><![CDATA[<p dir="auto">This one will be helpful anyway but I need to trigger a relay from a module using GPIO.</p>
]]></description><link>https://forum.magicmirror.builders/post/42308</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42308</guid><dc:creator><![CDATA[Gooral]]></dc:creator><pubDate>Mon, 16 Jul 2018 19:46:21 GMT</pubDate></item><item><title><![CDATA[Reply to Physical switch initiated with module in MM on Sun, 15 Jul 2018 17:40:16 GMT]]></title><description><![CDATA[<p dir="auto">If you want just to covert or relay notifications among several modules, check this.<br />
<a href="https://github.com/eouia/MMM-NotificationTrigger" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-NotificationTrigger</a></p>
]]></description><link>https://forum.magicmirror.builders/post/42270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42270</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 15 Jul 2018 17:40:16 GMT</pubDate></item><item><title><![CDATA[Reply to Physical switch initiated with module in MM on Sun, 15 Jul 2018 10:43:12 GMT]]></title><description><![CDATA[<p dir="auto">Yes, but still there is need for a module that will get payload from ex. MMM-Swipe (from ultrasonic sensor) and convert it into a GPIO signal sent to relay module or modules (if you want to click 6 physical buttons), right?</p>
]]></description><link>https://forum.magicmirror.builders/post/42260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42260</guid><dc:creator><![CDATA[Gooral]]></dc:creator><pubDate>Sun, 15 Jul 2018 10:43:12 GMT</pubDate></item><item><title><![CDATA[Reply to Physical switch initiated with module in MM on Sun, 15 Jul 2018 08:17:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gooral" aria-label="Profile: Gooral">@<bdi>Gooral</bdi></a><br />
One possibility is using a Relay module like this <a href="https://www.sunfounder.com/2-channel-dc-5v-relay-module-with-optocoupler-low-level-trigger-expansion-board-for-arduino-uno-r3-mega-2560-1280-dsp-arm-pic-avr-stm32-raspberry-pi.html" target="_blank" rel="noopener noreferrer nofollow ugc">Link</a>.</p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/42255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42255</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Sun, 15 Jul 2018 08:17:57 GMT</pubDate></item></channel></rss>
