<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems with installing the Mirror new]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
because I was not able to move to a sd card with bigger size, I tried a new Installation. This also did not worked.<br />
I took the actually raspian full streich, just like recommended. This works perfect. Then I used ssh and installed MM automatic with Code from michmich. Everything fine.Question about using pm2 I answered with y. I saw no errors. After starting with the command on the last line I got these errors After sockets connected &amp; modules startet.</p>
<p dir="auto">Whoops! There was an uncaught exception…</p>
<p dir="auto">{ Error: listen EADDRINUSE 127.0.0.1:8080</p>
<p dir="auto">at Object._errnoException (util.js:1024:11)</p>
<p dir="auto">at _exceptionWithHostPort (util.js:1046:20)</p>
<p dir="auto">at  Server.setupListenHandle [as _listen2] (net.js:1351:14)</p>
<p dir="auto">at listenInCluster (net.js:1392:12)</p>
<p dir="auto">at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)</p>
<p dir="auto">at GetAddrInfoReqQrap.onlookup [as oncomplete] (dns.js:97:10)</p>
<p dir="auto">code: ´EADDRINUSE´,</p>
<p dir="auto">errno: ´EADDRINUSE´,</p>
<p dir="auto">syscall: ´listen´,</p>
<p dir="auto">address: ´127.0.0.1´,</p>
<p dir="auto">port: 8080 }</p>
<p dir="auto">MagicMirror will not quit, but it might be a good Idea to check why this happend. Maybe not internet connection?</p>
<p dir="auto">If you think this really is an issue, please open an issue on …</p>
<p dir="auto">Launching application.</p>
<p dir="auto">After that there was no way for ssh. System hangs on. Mirror doesnt start. There was allready the raspian Desktop also after power off.<br />
Please help. Dont know what I made wrong.</p>
]]></description><link>https://forum.magicmirror.builders/topic/8410/problems-with-installing-the-mirror-new</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 23:33:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8410.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Jul 2018 06:01:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems with installing the Mirror new on Wed, 10 Oct 2018 19:58:38 GMT]]></title><description><![CDATA[<p dir="auto">@sean<br />
Your comment about multiple executions of mm got me thinking.<br />
before the update i started the mirror. “pm2” didn’t worked and the mirror was shutdown, through ctrl+c.</p>
<p dir="auto">So i did a restart of the pi and… now it works :-D</p>
<p dir="auto">So the sollution (for me in this case) was restarting the pi, so it forgets the instance of mm :-D</p>
]]></description><link>https://forum.magicmirror.builders/post/45236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45236</guid><dc:creator><![CDATA[MarkV]]></dc:creator><pubDate>Wed, 10 Oct 2018 19:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with installing the Mirror new on Wed, 10 Oct 2018 19:47:28 GMT]]></title><description><![CDATA[<p dir="auto">@sean<br />
thanks for the reply.<br />
I don’t use pm2, i’m starting the mirror with “DISPLAY=:0 npm start”</p>
<p dir="auto">To be sure i tryed the “pm2 stop mm” but like suspected i’m getting the “bash: pm2: opdracht niet gevonden” message.</p>
]]></description><link>https://forum.magicmirror.builders/post/45235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45235</guid><dc:creator><![CDATA[MarkV]]></dc:creator><pubDate>Wed, 10 Oct 2018 19:47:28 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with installing the Mirror new on Wed, 10 Oct 2018 19:34:01 GMT]]></title><description><![CDATA[<p dir="auto">Usually that case is caused by multiple execution of MM.<br />
“pm2 stop mm” then “pm2 start mm” Or just reboot.</p>
]]></description><link>https://forum.magicmirror.builders/post/45232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45232</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 10 Oct 2018 19:34:01 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with installing the Mirror new on Wed, 10 Oct 2018 19:15:03 GMT]]></title><description><![CDATA[<p dir="auto">I got the same problem.</p>
<p dir="auto">Before the update i had a MM with three extra modules, namely:<br />
MMM-AssistantMk2<br />
MMM-NotificationTrigger<br />
MMM-Hotword</p>
<p dir="auto">I also had teamviewer installed.<br />
Everything worked fine.<br />
I had the update message an i did the git pull &amp;&amp; npm install</p>
<p dir="auto">Didn’t had any updates during the update.<br />
After the update i tried to start the mirror the normal way and i got the error like it’s mentiont at the beginning of this topic.</p>
<p dir="auto">What’s causing this and how to correct it?</p>
]]></description><link>https://forum.magicmirror.builders/post/45231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45231</guid><dc:creator><![CDATA[MarkV]]></dc:creator><pubDate>Wed, 10 Oct 2018 19:15:03 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with installing the Mirror new on Tue, 17 Jul 2018 06:19:04 GMT]]></title><description><![CDATA[<p dir="auto">Thx for the answer. I attempted a little bit and I found the problems.<br />
The biggest problem was the new but cheap 128 GB card. I had also problems while starting. That seems to be also the problem for other Installations.<br />
The error in my first thread is not important. I used another smaller sd card and I got the error too but the mm works allright. So the problem seems to be solved.<br />
Greetings from Hakupapa</p>
]]></description><link>https://forum.magicmirror.builders/post/42314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42314</guid><dc:creator><![CDATA[Hakupapa]]></dc:creator><pubDate>Tue, 17 Jul 2018 06:19:04 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with installing the Mirror new on Mon, 16 Jul 2018 13:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hakupapa" aria-label="Profile: hakupapa">@<bdi>hakupapa</bdi></a> said in <a href="/post/42292">Problems with installing the Mirror new</a>:</p>
<p dir="auto">Error: listen EADDRINUSE 127.0.0.1:8080</p>
<p dir="auto">It would appear that something else is using port 8080 which MM needs</p>
]]></description><link>https://forum.magicmirror.builders/post/42303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42303</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 16 Jul 2018 13:09:39 GMT</pubDate></item></channel></rss>
