<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Hotword]]></title><description><![CDATA[<h2>MMM-Hotword</h2>
<p dir="auto">MMM-Hotword is a hotword detector using snowboy.<br />
You can use this module to wake another voice assistant or to give a command to other module.</p>
<h3>Screenshot</h3>
<p dir="auto"><img src="https://github.com/eouia/MMM-Hotword/raw/master/resources/screenshot.png" alt="screenshot" class=" img-fluid img-markdown" /></p>
<h3>UPDATES</h3>
<p dir="auto"><strong>2.0.0 (2019-05-19)</strong></p>
<ul>
<li>Whole new build-up</li>
<li>Some annoying dependencies are removed.</li>
<li>Installer is provided. (<code>installer/install.sh</code>)</li>
<li>Personal model trainer is provided. (<code>trainer/trainer.sh</code>)</li>
<li>Continuous recording after hotword detection is supported (Now you can say like “Computer, volume up” without pausing between <code>Computer</code> and <code>volume up</code>)
<ul>
<li>This feature could be used with <code>MMM-AssistantMk2 ver3.x</code>(Not yet released, but will arrive soon)</li>
<li>Or you can use this feature with other AI or Speech-To-Text program.</li>
</ul>
</li>
<li>Simple standalone commands could be available. (Without any Assistant or Speech-To-Text, you can make own voice commands with this module standalone.). Commands could be combined sequence (You can make “volume-louder” with voice models “volume” and “louder”)</li>
<li>More universal models are added. (<code>computer</code>, <code>subex</code>, <code>hey extreme</code> and more.)</li>
<li>Hotword detected could be displayed on screen of MM.</li>
</ul>
<h2>Download</h2>
<p dir="auto">[card:eouia/MMM-Hotword]</p>
<h3>Last Tested; (2019-05-19)</h3>
<ul>
<li>MagicMirror : v2.7.1</li>
<li>Tested Environment :
<ul>
<li>Raspbian Stretch (Raspbian 3B+) / node v8.16.0 / npm v6.4.1</li>
<li>TinkerOS (TinkerBoard)</li>
<li>Ubuntu 18.04 (NVIDIA Jetson Nano)</li>
<li>OSX 10.14.4 (Apple MacBookPro) / node v11.12.0 / npm v6.7.0</li>
</ul>
</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/8412/mmm-hotword</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 14:33:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8412.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Jul 2018 12:26:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 14:04:29 GMT]]></title><description><![CDATA[<p dir="auto">Ok merci bien ! ( je me disais bien, ton pseudo sonne bon la France! )  ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/78184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78184</guid><dc:creator><![CDATA[cheun]]></dc:creator><pubDate>Tue, 07 Jul 2020 14:04:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 14:02:39 GMT]]></title><description><![CDATA[<p dir="auto">sure ;)</p>
<p dir="auto">Note: et heuresement car je suis français !</p>
]]></description><link>https://forum.magicmirror.builders/post/78183</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78183</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 07 Jul 2020 14:02:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 14:02:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a><br />
thank you very much for putting me on the right way!<br />
last question: is it possible to change language of the assistant to an other (french for exemple)</p>
]]></description><link>https://forum.magicmirror.builders/post/78182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78182</guid><dc:creator><![CDATA[cheun]]></dc:creator><pubDate>Tue, 07 Jul 2020 14:02:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 13:58:54 GMT]]></title><description><![CDATA[<p dir="auto">i code this : MMM-GoogleAssistant and MMM-Assistant2Display (extension and addons) <a href="https://forum.magicmirror.builders/topic/12324/mmm-googleassistant-mmm-assistant2display">there</a></p>
]]></description><link>https://forum.magicmirror.builders/post/78181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78181</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 07 Jul 2020 13:58:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 13:55:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a><br />
Ok,thank you.<br />
So which module(s) do you suggest to make work a Google assistant ?</p>
]]></description><link>https://forum.magicmirror.builders/post/78179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78179</guid><dc:creator><![CDATA[cheun]]></dc:creator><pubDate>Tue, 07 Jul 2020 13:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 13:52:56 GMT]]></title><description><![CDATA[<p dir="auto">humm yes but … outdated installation sources and will never work<br />
I have deprecied MMM-AssistantMk2 too (and it use embed detector)<br />
so MMM-Hotword not needed</p>
]]></description><link>https://forum.magicmirror.builders/post/78178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78178</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 07 Jul 2020 13:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 13:49:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a><br />
Thank you for your answer.<br />
I only want to make a smart mirror with a Google assistant (MMM-AssistantMk2) with a custom hotword.<br />
I followed this tutorial :<br />
<a href="https://github.com/makepluscode/rpi-tutorial-advanced/tree/master/008-raspbian-magicmirror-google-assistant-latest" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/makepluscode/rpi-tutorial-advanced/tree/master/008-raspbian-magicmirror-google-assistant-latest</a><br />
I followed it except I’m running on Buster  (vs Stretch in the tuto).<br />
I guess things have changed since the year of publication of this tutorial.<br />
Hope I answerd your question.</p>
]]></description><link>https://forum.magicmirror.builders/post/78177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78177</guid><dc:creator><![CDATA[cheun]]></dc:creator><pubDate>Tue, 07 Jul 2020 13:49:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 12:45:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayman" aria-label="Profile: hayman">@<bdi>hayman</bdi></a> those are YOUR user Id and password on GitHub, right?</p>
]]></description><link>https://forum.magicmirror.builders/post/78173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78173</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jul 2020 12:45:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 12:32:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cheun" aria-label="Profile: cheun">@<bdi>cheun</bdi></a>: give me a good example of use ? (If you don’t use an assistant)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayman" aria-label="Profile: hayman">@<bdi>hayman</bdi></a> : It seems you are using an assistant so … It’s not needed. You can use ONLY one detector at once</p>
]]></description><link>https://forum.magicmirror.builders/post/78167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78167</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 07 Jul 2020 12:32:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 11:01:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> said in <a href="/post/67265">MMM-Hotword</a>:</p>
<p dir="auto">m happy using the old one, know how hard it was to get i all set up. a qick questien… how do i change the screen size on the M</p>
<p dir="auto">hello ,im trying to update the MMM-Hotword but keep asking the user&amp;pw of the site after entering them i get wrong psww …?<br />
is there any other wat to update it …?<br />
thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/78166</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78166</guid><dc:creator><![CDATA[hayman]]></dc:creator><pubDate>Tue, 07 Jul 2020 11:01:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Tue, 07 Jul 2020 02:56:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> Hello,<br />
I just wanted to use this module to custom my magic mirror hotword détection.</p>
<p dir="auto">Sorry for my numb question but why disable this fantastic module? Or is there a new one updated?<br />
Thank you so much</p>
]]></description><link>https://forum.magicmirror.builders/post/78153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78153</guid><dc:creator><![CDATA[cheun]]></dc:creator><pubDate>Tue, 07 Jul 2020 02:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Mon, 06 Jul 2020 22:10:15 GMT]]></title><description><![CDATA[<p dir="auto">hummm, yes I have disabled it.<br />
but why do you want to use it ?</p>
]]></description><link>https://forum.magicmirror.builders/post/78152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78152</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 06 Jul 2020 22:10:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Mon, 06 Jul 2020 20:38:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello everybody,</p>
<p dir="auto">Today I tried to install MMM-Hotword from <a href="https://github.com/eouia/MMM-Hotword.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-Hotword.git</a> but I get à 404 error.<br />
It seems the page has been moved or disabled.<br />
If so, could someone send me the contents of the git?<br />
Thank you in advance for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/78151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78151</guid><dc:creator><![CDATA[cheun]]></dc:creator><pubDate>Mon, 06 Jul 2020 20:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Fri, 17 Apr 2020 21:11:27 GMT]]></title><description><![CDATA[<p dir="auto">i think yes, MMM-Hotword  should be supported</p>
]]></description><link>https://forum.magicmirror.builders/post/72964</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72964</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 17 Apr 2020 21:11:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Wed, 15 Apr 2020 11:55:27 GMT]]></title><description><![CDATA[<p dir="auto">Does this module support Russian?</p>
]]></description><link>https://forum.magicmirror.builders/post/72820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72820</guid><dc:creator><![CDATA[Mrtrol2013]]></dc:creator><pubDate>Wed, 15 Apr 2020 11:55:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Sun, 05 Jan 2020 17:13:29 GMT]]></title><description><![CDATA[<p dir="auto">@t-architecture99</p>
<pre><code class="language-js">icons: { //https://iconify.design/icon-sets/
      waiting: "uil-comment-message",
      detected: "uil-comment-exclamation",
      finished: "uil-comment-dots",
<p dir="auto"><a href="https://iconify.design/icon-sets/" target="_blank" rel="noopener noreferrer nofollow ugc">https://iconify.design/icon-sets/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/67279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67279</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 05 Jan 2020 17:13:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Sun, 05 Jan 2020 16:22:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> i iam happy using the old one, know how hard it was to get i all set up. a qick questien… how do i change the screen size on the MM? i just geting it in the middel and not full scale</p>
]]></description><link>https://forum.magicmirror.builders/post/67265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67265</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Sun, 05 Jan 2020 16:22:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Sun, 05 Jan 2020 16:14:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> The easiest way is, reinstall freshly.</p>
]]></description><link>https://forum.magicmirror.builders/post/67264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67264</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 05 Jan 2020 16:14:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Sun, 05 Jan 2020 16:11:09 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
running MM v2.8.0<br />
dont running 2.0 on this</p>
]]></description><link>https://forum.magicmirror.builders/post/67263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67263</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Sun, 05 Jan 2020 16:11:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Sun, 05 Jan 2020 16:09:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berne" aria-label="Profile: berne">@<bdi>berne</bdi></a> If you have no issue on your usage, you don’t need to update. Nothing important is not updated.</p>
]]></description><link>https://forum.magicmirror.builders/post/67262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67262</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 05 Jan 2020 16:09:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Sun, 05 Jan 2020 16:08:08 GMT]]></title><description><![CDATA[<p dir="auto">mmm i notis i have a update, how do i get it?</p>
]]></description><link>https://forum.magicmirror.builders/post/67261</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67261</guid><dc:creator><![CDATA[berne]]></dc:creator><pubDate>Sun, 05 Jan 2020 16:08:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword on Fri, 27 Dec 2019 12:30:11 GMT]]></title><description><![CDATA[<p dir="auto">@Sean  at first thank you for your module however I have some difficulties in installing the snowboy library if you or someone else has a procedure I will follow it</p>
]]></description><link>https://forum.magicmirror.builders/post/66638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66638</guid><dc:creator><![CDATA[Artech]]></dc:creator><pubDate>Fri, 27 Dec 2019 12:30:11 GMT</pubDate></item></channel></rss>
