<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to run MagicMirror step by step on Raspberry pi zero]]></title><description><![CDATA[<p dir="auto">Hey guys, I’m all new to this stuff. I have just bought a raspberry pi zero w and don’t know how to set it up with magic mirror and serveronly mode. Can someone please guide me on how to do it. I’m only 14 and really want to make something cool. can someone please help me step my step to get this working.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/8442/how-to-run-magicmirror-step-by-step-on-raspberry-pi-zero</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 08:41:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8442.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Jul 2018 13:35:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to run MagicMirror step by step on Raspberry pi zero on Fri, 07 Sep 2018 16:04:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jctj" aria-label="Profile: jctj">@<bdi>jctj</bdi></a></p>
<p dir="auto">I followed your document line by line while sshing into the pi but after step 5 i get message<br />
“Sorry, your Raspberry Pi is not supported.<br />
Please run MagicMirror on a Raspberry Pi 2 or 3.<br />
If this is a Pi Zero, you are in the same boat as the original Raspberry Pi. You must run in server only mode.”</p>
<p dir="auto">How to go ahead of this ?</p>
]]></description><link>https://forum.magicmirror.builders/post/44227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44227</guid><dc:creator><![CDATA[asaxena11]]></dc:creator><pubDate>Fri, 07 Sep 2018 16:04:36 GMT</pubDate></item><item><title><![CDATA[Reply to How to run MagicMirror step by step on Raspberry pi zero on Sun, 22 Jul 2018 00:54:10 GMT]]></title><description><![CDATA[<p dir="auto">Thanks i’ll try now</p>
]]></description><link>https://forum.magicmirror.builders/post/42456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42456</guid><dc:creator><![CDATA[alessandroiacovella]]></dc:creator><pubDate>Sun, 22 Jul 2018 00:54:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to run MagicMirror step by step on Raspberry pi zero on Sat, 21 Jul 2018 16:25:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alessandroiacovella" aria-label="Profile: alessandroiacovella">@<bdi>alessandroiacovella</bdi></a> After trying a number of things I finally starting writing down <em>all</em> of my steps and I worked out this. These are the instructions for installing MM2 onto a Raspberry Pi - I used a Pi 3 B+ but the instructions should be exactly the same for a Zero. I am also using a Mac to flash a brand spanking new OS (Raspbian) onto the SD card. You can find lots of instructions on the internet for doing this step and I assume you already know how. I used Etcher after downloading the OS and it was a piece of cake… Here are the instructions - but keep in mind that you do NOT type in the prompt (‘$’ or ‘#’) when the prompt is shown, just the text after the prompt. Things that should not be typed I tried to make bold or italic, so that it was clear they were just notes to you, not something to type into the Pi.</p>
<p dir="auto">Rather than re-format this, here is the link for the Google Doc: <a href="https://docs.google.com/document/d/1IdEf_XKwheHGJcRYj2b2oE64_Q2xs5LkauwRRr2M2vg/edit?usp=sharing" target="_blank" rel="noopener noreferrer nofollow ugc">How to Install MagicMirror onto a Raspberry Pi</a></p>
<p dir="auto">Hope this helps!</p>
<p dir="auto">(note: in step 5.j you have a long line to type, not 2 lines. You should type, at the “#” prompt, "bash -c “$(curl -sL https://…)” as a single line.)</p>
]]></description><link>https://forum.magicmirror.builders/post/42445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42445</guid><dc:creator><![CDATA[JCTJ]]></dc:creator><pubDate>Sat, 21 Jul 2018 16:25:12 GMT</pubDate></item></channel></rss>
