<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to check version of MM]]></title><description><![CDATA[<p dir="auto">Hi<br />
how can i check the version of my Magic Mirror?</p>
]]></description><link>https://forum.magicmirror.builders/topic/8447/how-to-check-version-of-mm</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 20:39:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8447.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Jul 2018 08:36:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to check version of MM on Sun, 22 Jul 2018 09:32:40 GMT]]></title><description><![CDATA[<p dir="auto">@sean said in <a href="/post/42471">How to check version of MM</a>:</p>
<p dir="auto">Or you can check version from <code>package.json</code> (in MagicMirror directory)</p>
<pre><code>{
  "name": "magicmirror",
  "version": "2.4.1",
  "description": "The open source modular smart mirror platform.",
  "main": "js/electron.js",
  "scripts": {
<p dir="auto">But it could be different with your current running instance.</p>
<p dir="auto">that worked for me thank you !!</p>
]]></description><link>https://forum.magicmirror.builders/post/42474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42474</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Sun, 22 Jul 2018 09:32:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to check version of MM on Sun, 22 Jul 2018 09:02:11 GMT]]></title><description><![CDATA[<p dir="auto">Or you can check version from <code>package.json</code> (in MagicMirror directory)</p>
<pre><code>{
  "version": "2.4.1",
  "scripts": {
]]></description><link>https://forum.magicmirror.builders/post/42471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42471</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 22 Jul 2018 09:02:11 GMT</pubDate></item><item><title><![CDATA[Reply to How to check version of MM on Sun, 22 Jul 2018 08:59:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a><br />
Log will show which version is running, at the start moment.</p>
<pre><code>Starting MagicMirror: v2.4.1
Loading config ...
Loading module helpers ...
]]></description><link>https://forum.magicmirror.builders/post/42469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42469</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 22 Jul 2018 08:59:23 GMT</pubDate></item></channel></rss>
