<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NOAA3 - user defined lat & lon values]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I stopped using NOAA due to the wunderground issue.<br />
Luckily NOAA3 now has been issued and that works like a charm, but for one issue.</p>
<p dir="auto">It uses <a href="http://ip-api.com/json" target="_blank" rel="noopener noreferrer nofollow ugc">http://ip-api.com/json</a> to determine latitude and longitude.<br />
After (re)starting MM, a file called latlon.json it being created, with the info provided by <a href="http://ip-api.com" target="_blank" rel="noopener noreferrer nofollow ugc">ip-api.com</a>.<br />
As I mentioned before in another thread, in my case the location is of by 67 km’s, which is quite a bit.<br />
And some users are interested in other locations (rotating through different locations would be anoher feature request).</p>
<p dir="auto">As a work-around I updated the providers/wb.js file and adopted the line with “var text = fs.readFileSync(‘modules/MMM-NOAA3/latlon.json’,‘utf8’)” and provided my own latlon.nuremberg.json file.</p>
<p dir="auto">But it would be nice to have a config option to do so.<br />
Something like:</p>
<p dir="auto">userLatlonJson: “latlon.nuremberg.json”</p>
<p dir="auto">When empty or not present, then to the <a href="http://ip-api.com/json" target="_blank" rel="noopener noreferrer nofollow ugc">http://ip-api.com/json</a> routine, when present, then use userLatlonJson file.</p>
<p dir="auto">The work-around works for me, but it would be nice to do without.</p>
]]></description><link>https://forum.magicmirror.builders/topic/8451/mmm-noaa3-user-defined-lat-lon-values</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 15:32:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8451.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Jul 2018 15:03:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NOAA3 - user defined lat & lon values on Tue, 31 Jul 2018 01:44:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> You are reading my mind…working on it … instead of having it read a json file it would be easier to just allow users to add their own lat and lon…</p>
]]></description><link>https://forum.magicmirror.builders/post/42821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42821</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 31 Jul 2018 01:44:29 GMT</pubDate></item></channel></rss>
