<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using vc4-kms-v3d lost control on tvservice]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">recently using latest 2.4.1 i wanted to use the dtoverlay=<strong>vc4-kms-v3d</strong> to offload rendering effort of electron to GPU. That is working great, CPU usage decreased.</p>
<p dir="auto">However I noticed that my screen blanks sometimes. After a little bit of digging I recon I used the “<strong>tvservice -o</strong>” and “<strong>tv-service -p</strong>” in cron to schedule the LCD monitor off/on. (I’ve old monitor which is not power efficient and heats a lot in the mirror chasis - so when I’m not using it I scheduled cron to turn on/off the monitor for night etc)</p>
<p dir="auto">So now when vc4-kms-v3d is enable I can turn monitor off by using “<strong>tvservice -o</strong>”, but when it’s again time to turn that off the tvservice is thinking there is no monitor at all. As a result i’m not able to resurrect the monitor again. I can do reboot and obviosly it’s fine.<br />
Also notice then commands like “<strong>vcgencmd display_power 0/1</strong>” has also no control of monitor over vc4-kms-v3d .</p>
<p dir="auto">Do you guys know how I can control the monitor ? (it’s not CEC anyhow)</p>
<p dir="auto">If I use f(ake)-kms will that help to control it?</p>
<p dir="auto">some src: <a href="https://www.screenly.io/blog/2017/07/02/how-to-automatically-turn-off-and-on-your-monitor-from-your-raspberry-pi/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.screenly.io/blog/2017/07/02/how-to-automatically-turn-off-and-on-your-monitor-from-your-raspberry-pi/</a></p>
<p dir="auto">BR,<br />
Gregory</p>
]]></description><link>https://forum.magicmirror.builders/topic/8456/using-vc4-kms-v3d-lost-control-on-tvservice</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:40:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8456.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Jul 2018 12:10:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Mon, 13 Aug 2018 17:31:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bradau" aria-label="Profile: bradau">@<bdi>bradau</bdi></a> no sorry, thats not my case</p>
<p dir="auto">if you dont have any problem with the full kms maybe you will have to search of a tvservice alternative, something that works on any linux desktop and not specific to RPI</p>
]]></description><link>https://forum.magicmirror.builders/post/43365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43365</guid><dc:creator><![CDATA[cdelaorden]]></dc:creator><pubDate>Mon, 13 Aug 2018 17:31:42 GMT</pubDate></item><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Thu, 02 Aug 2018 07:23:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cdelaorden" aria-label="Profile: cdelaorden">@<bdi>cdelaorden</bdi></a> I’ve changed the driver from kms to fkms and tvservice commands are now working as is display_rotate=1 in config.txt which is great, the issue I now have is transitions on the screen, compliments changing, news headlines etc are not smooth at all in fact they are quite jittery, any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/42932</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42932</guid><dc:creator><![CDATA[BradAU]]></dc:creator><pubDate>Thu, 02 Aug 2018 07:23:31 GMT</pubDate></item><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Mon, 30 Jul 2018 12:55:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi Gregory<br />
tvservice isnt compatible with the KMS driver, you need to use fkms to retain that compativility</p>
]]></description><link>https://forum.magicmirror.builders/post/42793</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42793</guid><dc:creator><![CDATA[cdelaorden]]></dc:creator><pubDate>Mon, 30 Jul 2018 12:55:09 GMT</pubDate></item><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Wed, 25 Jul 2018 17:06:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregoryorciuch" aria-label="Profile: gregoryorciuch">@<bdi>gregoryorciuch</bdi></a> I just remembered – are you using a PIR sensor? It seems like that’s been the source of the problem for a lot of people, and <a href="https://github.com/paviro/MMM-PIR-Sensor/issues/39" target="_blank" rel="noopener noreferrer nofollow ugc">there seems to be a fix</a>. Unfortunately, I am <em>not</em> so that doesn’t impact me and I didn’t remember to mention it.</p>
]]></description><link>https://forum.magicmirror.builders/post/42631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42631</guid><dc:creator><![CDATA[pyrosmiley]]></dc:creator><pubDate>Wed, 25 Jul 2018 17:06:33 GMT</pubDate></item><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Wed, 25 Jul 2018 16:57:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregoryorciuch" aria-label="Profile: gregoryorciuch">@<bdi>gregoryorciuch</bdi></a> Yeah, it’s an ugly solution, but it works! I’d do the same, but my screen is blanking after about 25 minutes at most, and I just can’t justify a full reboot ever half hour.</p>
]]></description><link>https://forum.magicmirror.builders/post/42630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42630</guid><dc:creator><![CDATA[pyrosmiley]]></dc:creator><pubDate>Wed, 25 Jul 2018 16:57:51 GMT</pubDate></item><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Tue, 24 Jul 2018 17:06:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pyrosmiley" aria-label="Profile: pyrosmiley">@<bdi>pyrosmiley</bdi></a> thanks for sharing your experience. Actually because I cannot wakup the screen I put /sbin/reboot in crontab, that is nasty solution but works. But it costs the reboot.</p>
]]></description><link>https://forum.magicmirror.builders/post/42594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42594</guid><dc:creator><![CDATA[GregoryOrciuch]]></dc:creator><pubDate>Tue, 24 Jul 2018 17:06:24 GMT</pubDate></item><item><title><![CDATA[Reply to Using vc4-kms-v3d lost control on tvservice on Mon, 23 Jul 2018 19:02:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregoryorciuch" aria-label="Profile: gregoryorciuch">@<bdi>gregoryorciuch</bdi></a> I am in the <em>exact</em> same boat as you, and I have not had any luck as of yet. Tried the normal overlay and the “fake” kms, to no avail. To be honest, I’ve just given up for a little bit until people that know what they’re doing have found a solution or the drivers are more stable. I might just do a fresh raspbian install and start anew, to see if that fixes things.</p>
<p dir="auto">As a side note that doesn’t help much right now, using ‘vcgencmd monitor_on’ (or ‘off’) if you’re able is much, much better than ‘tvservice’.</p>
]]></description><link>https://forum.magicmirror.builders/post/42554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42554</guid><dc:creator><![CDATA[pyrosmiley]]></dc:creator><pubDate>Mon, 23 Jul 2018 19:02:42 GMT</pubDate></item></channel></rss>
