<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[npm install error help...]]></title><description><![CDATA[<p dir="auto">We are going to make Magic Mirror 2 using Artik710 hardware. The OS is fedora24, the node version is v10.6.0 and the npm version is v6.1.0. An error occurred from npm install. Is there a way to solve this part?<img src="/assets/uploads/files/1533137842165-141415.jpg" alt="0_1533137840081_141415.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/8502/npm-install-error-help</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 13:56:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8502.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Aug 2018 15:37:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to npm install error help... on Thu, 02 Aug 2018 02:42:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a><br />
I ran it the way you told me, but again I got an error.<img src="/assets/uploads/files/1533177739188-253522.jpg" alt="0_1533177737702_253522.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/42924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42924</guid><dc:creator><![CDATA[kyeongzze]]></dc:creator><pubDate>Thu, 02 Aug 2018 02:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to npm install error help... on Thu, 02 Aug 2018 02:25:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kyeongzze" aria-label="Profile: kyeongzze">@<bdi>kyeongzze</bdi></a></p>
<p dir="auto">Another user had this same error and this solved it for him…</p>
<p dir="auto"><code>sudo apt-get install libgconf-2-4</code></p>
]]></description><link>https://forum.magicmirror.builders/post/42921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42921</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 02 Aug 2018 02:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to npm install error help... on Thu, 02 Aug 2018 02:15:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a></p>
<p dir="auto">After running ‘npm install -g npm’, it was processed normally. But when I did ‘npm start’, I got an error again. ‘libgconf-2.so.4’ was not shared, do you know how to fix this?<br />
<img src="/assets/uploads/files/1533176119041-2563.jpg" alt="0_1533176117301_2563.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/42919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42919</guid><dc:creator><![CDATA[kyeongzze]]></dc:creator><pubDate>Thu, 02 Aug 2018 02:15:27 GMT</pubDate></item><item><title><![CDATA[Reply to npm install error help... on Thu, 02 Aug 2018 01:30:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kyeongzze" aria-label="Profile: kyeongzze">@<bdi>kyeongzze</bdi></a> - That doesn’t appear to be an actual error, merely an informational alert that there is a new version of npm available. So give it a whirl. Run the <code>npm install -g npm</code> to update your version of npm to the latest version and then run <code>npm install</code> again to apply the changes to your Magic Mirror framework.</p>
<p dir="auto">Please report back here to let us know how it goes.</p>
]]></description><link>https://forum.magicmirror.builders/post/42911</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42911</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 02 Aug 2018 01:30:39 GMT</pubDate></item></channel></rss>
