<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Segmentation Fault]]></title><description><![CDATA[<p dir="auto">Evening viewers,</p>
<p dir="auto">I had MM running fine on the 3B+, have got myself a Zero W and assume I have shot myself in the foot…</p>
<p dir="auto">I took the SD card out of the 3 and put it into the Zero. Initially I had issues getting the keyboard and mouse to work, after much research I added a USB hub with it’s own power supply but this brought with it boot issues. I still am not sure of the why.<br />
Ultimately it booted into Raspbian. I opened a terminal, changed directories to the Magic Mirror but when I typed npm start I got a Segmentation fault.</p>
<p dir="auto">Am I right in thinking there’s a difference between the code for the Zero vs the 3?</p>
<p dir="auto">Any and all help gratefully accepted.</p>
<p dir="auto">Cheers,<br />
Rob</p>
]]></description><link>https://forum.magicmirror.builders/topic/8544/segmentation-fault</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 15:23:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8544.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Aug 2018 12:02:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Segmentation Fault on Sat, 11 Aug 2018 03:26:35 GMT]]></title><description><![CDATA[<p dir="auto">Editing the Config file is pretty simple once you’ve done it once and shouldn’t take 5 minutes, depending upon how many and how complex you get with the modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/43280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43280</guid><dc:creator><![CDATA[AussieRob]]></dc:creator><pubDate>Sat, 11 Aug 2018 03:26:35 GMT</pubDate></item><item><title><![CDATA[Reply to Segmentation Fault on Fri, 10 Aug 2018 14:55:36 GMT]]></title><description><![CDATA[<p dir="auto">As I’ve yet to install Magic mirror I’m not sure if there is a backup option.<br />
(still in the research stage)<br />
If there is this would make importing Magic mirror setups to another device. Simply install MM on the new device and then restore a backup.</p>
]]></description><link>https://forum.magicmirror.builders/post/43266</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43266</guid><dc:creator><![CDATA[Tuicemen]]></dc:creator><pubDate>Fri, 10 Aug 2018 14:55:36 GMT</pubDate></item><item><title><![CDATA[Reply to Segmentation Fault on Fri, 10 Aug 2018 01:49:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Tuiceman,</p>
<p dir="auto">I spent much of yesterday afternoon and evening online, looking for an answer and didn’t come up with anything but a reinstall. I like to know the why for next time and the answer just may help someone else out in the same situation.</p>
<p dir="auto">I’ll put this card back into the 3B+ and start with a fresh card/install then report back in this thread.</p>
Rob</p>
]]></description><link>https://forum.magicmirror.builders/post/43258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43258</guid><dc:creator><![CDATA[AussieRob]]></dc:creator><pubDate>Fri, 10 Aug 2018 01:49:00 GMT</pubDate></item><item><title><![CDATA[Reply to Segmentation Fault on Thu, 09 Aug 2018 15:58:26 GMT]]></title><description><![CDATA[<p dir="auto">The drivers in the 3B+ OS are not compatible with older PIs<br />
Thus the SD card or image from the 3B+ will not work in the Zero W</p>
]]></description><link>https://forum.magicmirror.builders/post/43242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43242</guid><dc:creator><![CDATA[Tuicemen]]></dc:creator><pubDate>Thu, 09 Aug 2018 15:58:26 GMT</pubDate></item></channel></rss>
