<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AssistantMk2: error on authentication test]]></title><description><![CDATA[<p dir="auto">I cannot seem to get th MMM-AssistantMk2 module to work. I’m stuck at “In your SBC, you can run auth-tool for authentification. (not via SSH)”</p>
<p dir="auto">I tried npm rebuild without success.</p>
<p dir="auto">The error I get is</p>
<pre><code>Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v59-linux-arm-glibc/grpc_node.node)
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:683:18)
    at Module.load (internal/modules/cjs/loader.js:566:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
    at Function.Module._load (internal/modules/cjs/loader.js:498:3)
    at Module.require (internal/modules/cjs/loader.js:598:17)
    at require (internal/modules/cjs/helpers.js:11:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:32:13)
    at Module._compile (internal/modules/cjs/loader.js:654:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
]]></description><link>https://forum.magicmirror.builders/topic/8551/mmm-assistantmk2-error-on-authentication-test</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 16:41:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8551.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Aug 2018 18:19:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AssistantMk2: error on authentication test on Fri, 10 Aug 2018 07:10:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mc_landin" aria-label="Profile: mc_landin">@<bdi>mc_landin</bdi></a><br />
Try these;</p>
<pre><code>sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
<p dir="auto">Then, try again.</p>
]]></description><link>https://forum.magicmirror.builders/post/43253</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43253</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 10 Aug 2018 07:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2: error on authentication test on Fri, 10 Aug 2018 07:10:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mc_landin" aria-label="Profile: mc_landin">@<bdi>mc_landin</bdi></a><br />
First, in your previous step, was there no error?</p>
<p dir="auto">Second,</p>
<pre><code>cd ~/MagicMirror/modules/MMM-AssistantMk2
npm install --save-dev electron-rebuild
./node_modules/.bin/electron-rebuild
<p dir="auto">Doesn’t work? You’d got error?</p>
]]></description><link>https://forum.magicmirror.builders/post/43252</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43252</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 10 Aug 2018 07:10:34 GMT</pubDate></item></channel></rss>
