<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Buttons update node error installed 48 need 57]]></title><description><![CDATA[<p dir="auto">I recently updated my MagicMirror to the most recent version using</p>
<pre><code>git pull &amp;&amp; npm install
<p dir="auto">after a long 10 minutes due to 1 year worth of never updating. I did a</p>
<pre><code>sudo reboot
<p dir="auto">and was welcomed to a black screen.  So i dug through the logs</p>
<pre><code>pi@Magic_Mirror:~/MagicMirror $ pm2 show 0
 Describing process with id 0 - name MagicMirror
│ status            │ online                                     │
│ name              │ MagicMirror                                │
│ restarts          │ 0                                          │
│ uptime            │ 21m                                        │
│ script path       │ /home/pi/MagicMirror/installers/mm.sh      │
│ script args       │ N/A                                        │
│ error log path    │ /home/pi/.pm2/logs/MagicMirror-error-0.log │
│ out log path      │ /home/pi/.pm2/logs/MagicMirror-out-0.log   │
│ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid       │
│ interpreter       │ bash                                       │
│ interpreter args  │ N/A                                        │
│ script id         │ 0                                          │
│ exec cwd          │ /home/pi/MagicMirror                       │
│ exec mode         │ fork_mode                                  │
│ node.js version   │ N/A                                        │
│ watch &amp; reload    │ ✔                                          │
│ unstable restarts │ 0                                          │
│ created at        │ 2018-02-20T06:18:41.419Z                   │
 Revision control metadata
│ revision control │ git                                            │
│ remote url       │ https://github.com/MichMich/MagicMirror.git    │
│ repository root  │ /home/pi/MagicMirror                           │
│ last update      │ 2018-08-12T18:38:47.286Z                       │
│ revision         │ 6aa156d95667b230264fd99c5df877b25759e710       │
│ comment          │ Merge pull request #1343 from MichMich/develop │
│ branch           │ master                                         │
 Add your own code metrics: http://bit.ly/code-metrics
 Use `pm2 logs MagicMirror [--lines 1000]` to display logs
 Use `pm2 monit` to monitor CPU and Memory usage MagicMirror
pi@Magic_Mirror:~/MagicMirror $ pm2 logs MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-error-0.log last 15 lines:
0|MagicMir | Error: The module '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/Release/epoll.node'
0|MagicMir | was compiled against a different Node.js version using
0|MagicMir | NODE_MODULE_VERSION 50. This version of Node.js requires
0|MagicMir | NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
0|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
0|MagicMir |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
0|MagicMir |     at Object.Module._extensions..node (module.js:671:18)
0|MagicMir |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
0|MagicMir |     at Module.load (module.js:561:32)
0|MagicMir |     at tryModuleLoad (module.js:504:12)
0|MagicMir |     at Function.Module._load (module.js:496:3)
0|MagicMir |     at Module.require (module.js:586:17)
0|MagicMir |     at require (internal/module.js:11:18)
0|MagicMir |     at bindings (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bindings/bindings.js:81:44)
0|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/epoll.js:1:192)
/home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
0|MagicMir |
0|MagicMir | Starting MagicMirror: v2.4.1
0|MagicMir | Loading config ...
0|MagicMir | Loading module helpers ...
0|MagicMir | No helper found for module: MMM-ModuleToggle.
0|MagicMir | Initializing new module helper ...
0|MagicMir | Module helper loaded: MMM-DropboxWallpaper
0|MagicMir | Whoops! There was an uncaught exception...
0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|MagicMir | Launching application.
^X^C
<p dir="auto">I went ahead and did what it suggested with the <code>npm rebuild</code> and just lowered the node error to 48 instead of 50.</p>
<p dir="auto">I’m confused as to what this means and how to fix this, since before the update it was working.</p>
<p dir="auto">(MMM-Buttons is used to swap between modules,<br />
1- Blank screen only background<br />
2-Calendar (custom sized)<br />
3-Weather (custom sized)<br />
4-Wunderlist (custom sized))</p>
]]></description><link>https://forum.magicmirror.builders/topic/8565/mmm-buttons-update-node-error-installed-48-need-57</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:26:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8565.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Aug 2018 19:30:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Buttons update node error installed 48 need 57 on Tue, 28 Aug 2018 21:43:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glitchgod" aria-label="Profile: glitchgod">@<bdi>glitchgod</bdi></a><br />
I had the same problem, here is the solution which worked for me.</p>
<p dir="auto">Change into the modules directory</p>
<pre><code>cd MagicMirror/modules/MMM-Buttons
<p dir="auto">Rebuild module for the correct elecron version</p>
<pre><code>npm rebuild --runtime=electron --target=$(../../node_modules/electron/cli.js --version) --disturl=https://atom.io/download/atom-shell --build-from-source
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/43899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43899</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Tue, 28 Aug 2018 21:43:27 GMT</pubDate></item></channel></rss>
