<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror not booting up]]></title><description><![CDATA[<p dir="auto">Guys I’m becoming mad, I have spent last two days configuring my smart mirror with google assistant, Spotify and other. Finally today everything was working more or less (just minor adjustment to be done).<br />
Unfortunately now it doesn’t work anymore, it doesn’t even boot. I can guarantee that before booting I changed just two things:</p>
<ul>
<li>I removed this line<br />
display_rotate=1<br />
from<br />
/boot/config.txt</li>
<li>I removed<br />
-nocursor<br />
from<br />
xserver-command=X -s 0 -dpms -nocursor<br />
in<br />
/etc/lightdm/lightdm.conf</li>
</ul>
<p dir="auto">Here is a screenshot:<br />
<img src="/assets/uploads/files/1534119043429-untitled-resized.jpeg" alt="0_1534119041792_Untitled.jpeg" class=" img-fluid img-markdown" /><br />
All I get now is this:<br />
<img src="/assets/uploads/files/1534119639683-untitled2-resized.jpeg" alt="0_1534119637626_Untitled2.jpeg" class=" img-fluid img-markdown" /><br />
Lorenzo</p>
]]></description><link>https://forum.magicmirror.builders/topic/8568/magic-mirror-not-booting-up</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 00:11:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8568.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Aug 2018 00:16:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror not booting up on Mon, 13 Aug 2018 15:39:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks god I solved it!!!<br />
While exiting from /etc/lightdm/lightdm.conf I pressed inadvertently option+x instead control+x and I added “†” in the file without realising it.<br />
Thank you guys for helping me out</p>
]]></description><link>https://forum.magicmirror.builders/post/43359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43359</guid><dc:creator><![CDATA[Lorenzo_Zappa]]></dc:creator><pubDate>Mon, 13 Aug 2018 15:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror not booting up on Mon, 13 Aug 2018 15:26:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lorenzo_zappa" aria-label="Profile: lorenzo_zappa">@<bdi>lorenzo_zappa</bdi></a><br />
Ok, How about your pm2 log?</p>
<pre><code>pm2 logs
]]></description><link>https://forum.magicmirror.builders/post/43358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43358</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 13 Aug 2018 15:26:15 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror not booting up on Mon, 13 Aug 2018 15:24:25 GMT]]></title><description><![CDATA[<p dir="auto">@sean I cannot start magic mirror using npm start dev because it’s like the graphical environment didn’t load.<br />
My config file is ok, I just checked it</p>
]]></description><link>https://forum.magicmirror.builders/post/43357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43357</guid><dc:creator><![CDATA[Lorenzo_Zappa]]></dc:creator><pubDate>Mon, 13 Aug 2018 15:24:25 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror not booting up on Mon, 13 Aug 2018 06:18:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lorenzo_zappa" aria-label="Profile: lorenzo_zappa">@<bdi>lorenzo_zappa</bdi></a><br />
It seems your config.js is missed or have something wrong.</p>
<p dir="auto">stop pm2 and try this and watch which error is shown.</p>
<pre><code>cd ~/MagicMirror
npm start dev
<p dir="auto">you can check your configuration with;</p>
<pre><code>npm run config:check
]]></description><link>https://forum.magicmirror.builders/post/43346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43346</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 13 Aug 2018 06:18:05 GMT</pubDate></item></channel></rss>
