<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MirrorMirrorOnTheWall installation issue]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/1828/mirror-mirror-on-the-wall-alexa-skill">Mirror mirror on the wall alexa skill</a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joanaz" aria-label="Profile: joanaz">@<bdi>joanaz</bdi></a>  Hi there i am stuck at the testing of the Alexa skill part.<br />
I did follow the instruction step by step and to the T (great documentation work y the way … wow thank you) and when i got the the testing part and inputting “on the wall” on the Alexa Developer Console all i get is  “There was a problem with requested skills response” and on the “json output” window all i get is “null”.<br />
I tried to backtrack my steps and see where i might have made a mistake and i cant seem to find where!!</p>
<p dir="auto">Where should i start troubleshooting any ideas?? All help will be greatly appreciated</p>
<p dir="auto">Thank you<br />
Denis</p>
]]></description><link>https://forum.magicmirror.builders/topic/8569/mmm-mirrormirroronthewall-installation-issue</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 14:49:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8569.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Aug 2018 01:26:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Fri, 19 Jul 2019 21:52:23 GMT]]></title><description><![CDATA[<p dir="auto">So after going through the thread again, i am still stuck on the policy issue. i have tried  <a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpanda" aria-label="Profile: blackpanda">@<bdi>blackpanda</bdi></a> code for the policy change while also changing the client ID to “MagicMirror” on both the pi/MirrorMirrorOnTheWallSkill/src/MirrorMirror.js and pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/MirrorMirror.js</p>
<p dir="auto">With this i still get Attempt to connect to AWS. my cloudwatch logs show</p>
<pre><code>2019-07-19T20:27:06.893Z 100e7185-039f-42ce-be95-07ea3a83c847 Task timed out after 3.00 seconds
<p dir="auto">which might mean its still a policy security issue or its just not connecting to Iot core.</p>
<p dir="auto">When Prompted with intent, Alexa responds with the usual Hello my Queen, but when given a command i continue to get the classic “there was a problem with requested skill response”. Although the logs do show that the youtube video is requested then it times out.</p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/post/59178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59178</guid><dc:creator><![CDATA[mauparra80]]></dc:creator><pubDate>Fri, 19 Jul 2019 21:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Wed, 17 Jul 2019 19:15:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sbrundage85" aria-label="Profile: sbrundage85">@<bdi>sbrundage85</bdi></a>  Same Same. Started several months ago, went through this thread and still was not working. Just started to look at it again with a fresh install and go through the thread again. having the same issue. ill post more if i find something. Maybe the more attention we bring back to the thread the bigger the possibility of it getting fixed</p>
]]></description><link>https://forum.magicmirror.builders/post/59096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59096</guid><dc:creator><![CDATA[mauparra80]]></dc:creator><pubDate>Wed, 17 Jul 2019 19:15:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Wed, 17 Jul 2019 15:39:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parsons12" aria-label="Profile: parsons12">@<bdi>parsons12</bdi></a> I’m at the same point you are.  Trying to read through this thread to get a better idea of what I still have to do. I wish someone took the time to compile all the info into a nice doc.  Have you figured this out yet?  I get the Hello Queen response but then “unable to handle request” error whenever I try to show text, images, etc.  I’m working through how to enable google search</p>
]]></description><link>https://forum.magicmirror.builders/post/59090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59090</guid><dc:creator><![CDATA[sbrundage85]]></dc:creator><pubDate>Wed, 17 Jul 2019 15:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Fri, 17 May 2019 08:41:42 GMT]]></title><description><![CDATA[<p dir="auto">All the info is in the thread for this to work</p>
]]></description><link>https://forum.magicmirror.builders/post/57122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57122</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Fri, 17 May 2019 08:41:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Tue, 07 May 2019 20:52:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/diep-trung" aria-label="Profile: Diep-Trung">@<bdi>Diep-Trung</bdi></a> how did you get the skill to start working? The only thing that seems to work for me is the start up. Any command after that just says “there was a problem with the selected skills response”.</p>
<p dir="auto">Thanks for any help</p>
]]></description><link>https://forum.magicmirror.builders/post/56794</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56794</guid><dc:creator><![CDATA[parsons12]]></dc:creator><pubDate>Tue, 07 May 2019 20:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Tue, 07 May 2019 20:20:51 GMT]]></title><description><![CDATA[<p dir="auto">I have followed the tutorial very closely to get the Alexa skill working but it doesn’t seem to work quite right. Right now my skill will start up and respond accordingly with “Hello my Queen” but when I asked it to display an image it says “there was a problem with requested skills response“.</p>
<p dir="auto">When I checked my custom google search it is being hit with my request and it also says there were no errors.</p>
<p dir="auto">Does anybody know what I could be missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/56791</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56791</guid><dc:creator><![CDATA[parsons12]]></dc:creator><pubDate>Tue, 07 May 2019 20:20:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Fri, 01 Mar 2019 13:02:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: OceanK">@<bdi>OceanK</bdi></a> Thank you for respond me. I’m very close! Amazon Developer Console Skill work perfect, Rpi already connect to AWS IoT, but can’t receive any command.<br />
After very long process work with MirrorMirrorOnTheWall module, I finally got the skill work perfect. When I say “open on the wall”, the Alexa respond to me, and I ask to close all modules, It also respond “Yes my king, closing all Modules”.<img src="/assets/uploads/files/1551445160778-screenshot-11.png" alt="0_1551445152844_Screenshot (11).png" class=" img-fluid img-markdown" /> And also, when I “pm2 logs mm” I see “Connected to AWS IoT, Subscribed :MagicMirror: new-text, new-images, change-module, new-video,…”.![0_1551445327440_Screenshot (13).png](Uploading 100%)   But for some reason, the command doesn’t make any change in the magicmirror, It look like something stop the exchange data between AWS IoT and Rpi. I read a lot of post but can not find out how to fix that. Does any one have the solution?<br />
Thank you so much.</p>
]]></description><link>https://forum.magicmirror.builders/post/53463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53463</guid><dc:creator><![CDATA[Diep Trung]]></dc:creator><pubDate>Fri, 01 Mar 2019 13:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Fri, 01 Mar 2019 09:57:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> hey brah! I will sort it out for you. Im not home right now.</p>
]]></description><link>https://forum.magicmirror.builders/post/53457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53457</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Fri, 01 Mar 2019 09:57:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Sun, 24 Feb 2019 15:49:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: OceanK">@<bdi>OceanK</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpanda" aria-label="Profile: blackpanda">@<bdi>blackpanda</bdi></a>  hello, Can you help me for a while?<br />
The story is that I follow the tutorial for the Mirrormirroronthewall installation and also fixed all the issues I face in the process by follow a few forum guide. And now my Lambda is completely success<img src="/assets/uploads/files/1551022926650-screenshot-9.png" alt="0_1551022914211_Screenshot (9).png" class=" img-fluid img-markdown" /><br />
But for some reasons, The Alexa Developer Console always say that “There was a problem with the requested skill’s response”.<img src="/assets/uploads/files/1551023082752-screenshot-10.png" alt="0_1551023075514_Screenshot (10).png" class=" img-fluid img-markdown" />  Can you help me, please. I don’t know where I put it wrong. I also put the policy in the IoT Core like Blackpanda said. Can you write a full tutorial for this module installation.</p>
]]></description><link>https://forum.magicmirror.builders/post/53085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53085</guid><dc:creator><![CDATA[Diep Trung]]></dc:creator><pubDate>Sun, 24 Feb 2019 15:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Wed, 06 Feb 2019 04:15:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpanda" aria-label="Profile: blackpanda">@<bdi>blackpanda</bdi></a> I deleted my Alexa skill and started from the beginning on the developers.alexa i also deleted my Lambda function and built it from the beginning still the same result.<br />
IoT connects and Lambda gets hit i can see it in the metrics when i invoke the skill i can hear “Hello my queen how can i help etc…” but when i ask about anything else it says “There was a problem with your skills response”.<br />
I went and checked the API keys on Google and they have never been hit, at the same time the MM modules do not turn on or off just in case the keys are off!!!<br />
So what is causing it?? is it the interaction model ?? Cause i am sure it is not the certs because the IoT is connecting I can see that on startup the Connected to AWS IoT Subscribed for new-text, new-images, new-video, change-module…and and it is not the keys (although they have never been hit, but i am not 100% percent sure that they are right either) but than why is it not doing anything with the Magic Mirror such as turning On and Off modules and than saying there is nothing coming form the searches so that would tell us that it is the keys.<br />
I think the next step will do to redo my interaction model since it is pretty big and just use someones that i know its working just to test, but other than that i am fresh out of ideas and i would love to hear form the experts if you will please… so i can get this going as well cause it is driving me nuts LOL :)</p>
]]></description><link>https://forum.magicmirror.builders/post/51646</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51646</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Wed, 06 Feb 2019 04:15:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Thu, 10 Jan 2019 09:54:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> pm me I know how to get this done!</p>
]]></description><link>https://forum.magicmirror.builders/post/49891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49891</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Thu, 10 Jan 2019 09:54:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Thu, 10 Jan 2019 05:30:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> Hey buddy… no wit won’t work with turning on and off modules either it just says “there was a problem with requested skills response” here are my Lamda errors<br />
<img src="/assets/uploads/files/1547097780698-lambdaerror.png" alt="0_1547097782898_lambdaError.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1547097795309-lamdaerror2.png" alt="0_1547097798877_LamdaError2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1547098081497-cloudwatch.png" alt="0_1547098084539_cloudWatch.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1547098097537-iotcore.png" alt="0_1547098101131_IoTcore.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">And MM says connected to AWS IoT obviously for all text, video, images, modules.</p>
<p dir="auto">What the heck is going on where should i start troubleshooting<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpanda" aria-label="Profile: blackpanda">@<bdi>blackpanda</bdi></a> please help me :) i will greatly appreciate it<br />
D</p>
]]></description><link>https://forum.magicmirror.builders/post/49875</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49875</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Thu, 10 Jan 2019 05:30:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Wed, 09 Jan 2019 10:43:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> can you close and open the modules? does any of the magic mirror skill work? if you can close and open modules, there might be something with the API for google and youtube.</p>
<p dir="auto">I do get labda error when I try to set up a test so I dont know why its like that. But all functions are working for me now. close, open all modues, find pictures, autostart youtube clip, clearing it etc.</p>
<p dir="auto">What you can do is start the mirror with development option then you can see exactly what happens.</p>
<p dir="auto">at the google console you can see both youtube and google search hits if they are succesfull or not.</p>
<p dir="auto">At cloudwatch you can check the logs if it finds video or pictures…</p>
]]></description><link>https://forum.magicmirror.builders/post/49792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49792</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Wed, 09 Jan 2019 10:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Wed, 09 Jan 2019 05:23:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/blackpanda" aria-label="Profile: blackpanda">@<bdi>blackpanda</bdi></a> OK well i have triple checked my appID and pasted on the index.js file i have triple checked the endpoint and pasted on the mirrormirror.js file.<br />
Went and checked my API keys on Google i had like 8 of them, however none of them were what i had on keys.json file (so wired) so i picked 2 from the list and wrote them there along with my custom search ID uploaded to Lambda and copied over to the MMM-MirrorMirrorOnTheWall folder as well.<br />
I can see the MagicMirror: Connected to AWS IoT Subscribed for new-text, new-images, new-video, change-module also on Lambda i see the invocations getting posted on the logs all the time when i test from the developer.alexa with the invocation “magic mirror” i get the response “hello my queen blah blah blah…” but when i type show pictures of dwarfs i still get “there was a problem with requested skills response”<br />
What am i doing wrong???<br />
Is it the API keys form google ?? Where i can i see if they are getting hit with requests?<br />
…and do you all get any errors on Lambda logs when you test Lambda (how do you test Lamda) i still get the appId not unique when it is absolutely mine!!!</p>
<p dir="auto">It is an ass whooping this module :) i am gonna throw a party when its done LOL<br />
D</p>
]]></description><link>https://forum.magicmirror.builders/post/49778</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49778</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Wed, 09 Jan 2019 05:23:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Tue, 08 Jan 2019 06:03:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> im available today so just send me a chat!</p>
]]></description><link>https://forum.magicmirror.builders/post/49681</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49681</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Tue, 08 Jan 2019 06:03:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Tue, 08 Jan 2019 02:26:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> Dang it man i am the only one who hasn’t gotten around to finish it up. I will try tonight but i might need your help my man :)</p>
]]></description><link>https://forum.magicmirror.builders/post/49675</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49675</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Tue, 08 Jan 2019 02:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 19:54:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a> its all done man =)</p>
]]></description><link>https://forum.magicmirror.builders/post/49654</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49654</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Mon, 07 Jan 2019 19:54:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 16:42:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> I start with Alexa, start magic mirror, which works just fine. Then Search image of apples, find image of apple or any other possible way of saying I want an image of an apple results in:</p>
<p dir="auto">Amazon Photos is not supported on this device. View your photos using the Amazon Photos app or website, or on devices like Fire TV or Echo Show.</p>
<p dir="auto">for videos I get:</p>
<p dir="auto">I couldn’t find any enabled video skills that can find that. Go to the Alexa app to manage your video skills and devices.</p>
<p dir="auto">#Solved. Forgot to modify the app ID line pointed out a few pages ago. Waiting for my echo dot to arrive to play around.</p>
]]></description><link>https://forum.magicmirror.builders/post/49603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49603</guid><dc:creator><![CDATA[Radu_Stancu]]></dc:creator><pubDate>Mon, 07 Jan 2019 16:42:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 12:47:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/radu_stancu" aria-label="Profile: Radu_Stancu">@<bdi>Radu_Stancu</bdi></a></p>
<p dir="auto">so how do you trigger the search for videos or pictures?</p>
<p dir="auto">seems that its not triggering the magic mirror module, seems that its trying to use some amazon service?</p>
<p dir="auto">Are you saying this to alexa?</p>
<p dir="auto">alexa…magic mirror…and then the whole hello my queen is going on. and then you say “find pictures of apples”</p>
<p dir="auto">or how do you trigger the syntax?</p>
]]></description><link>https://forum.magicmirror.builders/post/49602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49602</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Mon, 07 Jan 2019 12:47:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 12:33:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> I can`t seem to find anything relevant in the logs… I keep getting</p>
<p dir="auto">and similar for videos.</p>
]]></description><link>https://forum.magicmirror.builders/post/49601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49601</guid><dc:creator><![CDATA[Radu_Stancu]]></dc:creator><pubDate>Mon, 07 Jan 2019 12:33:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 12:06:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/radu_stancu" aria-label="Profile: radu_stancu">@<bdi>radu_stancu</bdi></a></p>
<p dir="auto">did you check the cloudwatch logs? see what error you get…</p>
]]></description><link>https://forum.magicmirror.builders/post/49600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49600</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Mon, 07 Jan 2019 12:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 11:03:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> Okay, I`ll try that now. Nothing changed unfortunately…</p>
]]></description><link>https://forum.magicmirror.builders/post/49597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49597</guid><dc:creator><![CDATA[Radu_Stancu]]></dc:creator><pubDate>Mon, 07 Jan 2019 11:03:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MirrorMirrorOnTheWall installation issue on Mon, 07 Jan 2019 10:54:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/radu_stancu" aria-label="Profile: radu_stancu">@<bdi>radu_stancu</bdi></a> well I have read that in some forums that it was required. When I had 1 project with 2 different API it didnt work for me so thats why I tryed the other option with 2 seperate projects and API and then it worked for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/49596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49596</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Mon, 07 Jan 2019 10:54:18 GMT</pubDate></item></channel></rss>
