<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SSH startup]]></title><description><![CDATA[<p dir="auto">I’ve set it up and it all works however i am unable to start the service via ssh and get the message in the screenshot attached</p>
<p dir="auto"><img src="/uploads/files/1477305053555-screenshot_3.png" alt="0_1477305065662_Screenshot_3.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/863/ssh-startup</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 10:00:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/863.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Oct 2016 10:30:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SSH startup on Fri, 25 Nov 2016 19:31:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stehman07" aria-label="Profile: Stehman07">@<bdi>Stehman07</bdi></a><br />
you need to edit the file as <code>root</code>, the normal user <code>pi</code> does not have sufficient rights.</p>
<p dir="auto">Run <code>sudo nano /boot/config.txt</code> instead</p>
]]></description><link>https://forum.magicmirror.builders/post/8490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8490</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Fri, 25 Nov 2016 19:31:19 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Fri, 25 Nov 2016 19:23:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a>  I try to enter ‘display_rotate=1’ in the config.txt file in the boot folder.  I try to save the file and overwrite the previous version of the file to only get the message “can’t open file to write”.  Where am I going wrong on this?</p>
]]></description><link>https://forum.magicmirror.builders/post/8487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8487</guid><dc:creator><![CDATA[Stehman07]]></dc:creator><pubDate>Fri, 25 Nov 2016 19:23:51 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 20:07:07 GMT]]></title><description><![CDATA[<p dir="auto">There’s a glaring instruction right there on the screen that you did not follow. When you typed in <code>pm2 startup</code> it clearly told you what you need to do, which I don’t see anywhere in your command log. I’m sorry, but if you can’t follow directions given to you, there is really not a whole lot anyone can do to help you. The instructions are there for you to follow, please do that.</p>
]]></description><link>https://forum.magicmirror.builders/post/6999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6999</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 26 Oct 2016 20:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 19:58:42 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.bilder-upload.eu/show.php?file=e77336-1477512295.png" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.bilder-upload.eu/show.php?file=e77336-1477512295.png</a></p>
<p dir="auto">i only did it</p>
]]></description><link>https://forum.magicmirror.builders/post/6997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6997</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Wed, 26 Oct 2016 19:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 19:30:35 GMT]]></title><description><![CDATA[<p dir="auto">Then you didn’t do it correctly. Did you launch it, then save the task? You have to follow the steps one by one. Please go back and start from the top and do it again.</p>
]]></description><link>https://forum.magicmirror.builders/post/6996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6996</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 26 Oct 2016 19:30:35 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 19:17:33 GMT]]></title><description><![CDATA[<p dir="auto">thanks, but they don’t work<br />
i create the script, and i saved it in the pm2<br />
but if i restart my magic mirror they begin in the desktop<br />
and if i use ‘pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>’<br />
they go to the mirror</p>
<p dir="auto">with the command ‘pm2 show mm’ i see that is a x in the field “watch &amp; reload”<br />
what now ?</p>
]]></description><link>https://forum.magicmirror.builders/post/6994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6994</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Wed, 26 Oct 2016 19:17:33 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 19:06:54 GMT]]></title><description><![CDATA[<p dir="auto">You can’t. You need the desktop to run electron which is what displays the mirror. What you can do, is run an automatic (re)start of the mirror. For instructions, please visit <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/6993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6993</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 26 Oct 2016 19:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 19:05:23 GMT]]></title><description><![CDATA[<p dir="auto">a little question:<br />
how i can delete my “desktop” and start with my npm (so i wanna after a restart direct to my npm not on my desktop)?</p>
]]></description><link>https://forum.magicmirror.builders/post/6991</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6991</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Wed, 26 Oct 2016 19:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 18:49:08 GMT]]></title><description><![CDATA[<p dir="auto">The ‘<code>DISPLAY=:0</code>’ bit is simply telling the system (in this case the rpi), which monitor it should use, in this case, the attached one.</p>
<p dir="auto">For rotation, using ‘<code>display_rotate</code>’ you can tell the OS how to rotate the output:</p>
<pre><code>display_rotate=0           Normal
display_rotate=1           90 degrees
display_rotate=2          180 degrees
display_rotate=3          270 degrees
display_rotate=0x10000    horizontal flip
display_rotate=0x20000    vertical flip
]]></description><link>https://forum.magicmirror.builders/post/6990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6990</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 26 Oct 2016 18:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 17:07:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geeflaxx" aria-label="Profile: geeflaxx">@<bdi>geeflaxx</bdi></a> The <code>display=:0</code> parameter is to send the output of the electron process to the monitor attached to your Raspberry Pi.</p>
<p dir="auto">Rotating the display is done by editing the <code>/boot/config.txt</code> file and adding the line <code>display_rotate=1</code></p>
]]></description><link>https://forum.magicmirror.builders/post/6961</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6961</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 26 Oct 2016 17:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Wed, 26 Oct 2016 15:36:10 GMT]]></title><description><![CDATA[<p dir="auto">i could you say that i don’t have the electron order.</p>
<p dir="auto">and display=:0 isn’t it for vertical view?</p>
<p dir="auto"><a href="http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png</a></p>
<p dir="auto"><a href="http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png</a></p>
]]></description><link>https://forum.magicmirror.builders/post/6950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6950</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Wed, 26 Oct 2016 15:36:10 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Tue, 25 Oct 2016 04:24:52 GMT]]></title><description><![CDATA[<p dir="auto"><code>DISPLAY=:0</code> is a must when attempting to start MM through an SSH connection, otherwise it simply doesn’t have a clue what display to use, the one you’re sitting at, or the one on the rpi?<br />
X-Forwarding is not required nor necessary for a simple ssh login, startup, and exit.</p>
]]></description><link>https://forum.magicmirror.builders/post/6832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6832</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 25 Oct 2016 04:24:52 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Mon, 24 Oct 2016 19:36:48 GMT]]></title><description><![CDATA[<p dir="auto">Also make sure that you enable X forwarding in the ssh call, e.g. <strong>ssh -X user@host</strong>.</p>
]]></description><link>https://forum.magicmirror.builders/post/6816</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6816</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Mon, 24 Oct 2016 19:36:48 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Mon, 24 Oct 2016 19:33:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djbenny07" aria-label="Profile: djbenny07">@<bdi>djbenny07</bdi></a> Try to add "DISPLAY=:0’ in front of your command. Do you really need “sudo”?</p>
]]></description><link>https://forum.magicmirror.builders/post/6815</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6815</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Mon, 24 Oct 2016 19:33:36 GMT</pubDate></item><item><title><![CDATA[Reply to SSH startup on Mon, 24 Oct 2016 19:00:15 GMT]]></title><description><![CDATA[<p dir="auto">i think a lots of beginners have the same error</p>
]]></description><link>https://forum.magicmirror.builders/post/6810</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6810</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Mon, 24 Oct 2016 19:00:15 GMT</pubDate></item></channel></rss>
