<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Accesing config in node_helper]]></title><description><![CDATA[<p dir="auto">Hello,<br />
first of all thanks for the phantastic MagicMirror and all the modules the comunity provides !<br />
Currently I’m working on a module to use a Phillips hue motion sensor to activate/deactivate the display of my magic  mirror. All works great but i’m wondering if there is an easier method to access config properties in node_helper. Currently i’m “messaging” the config from the module to the helper. Is there a way to acces the config directly in the helper ?</p>
<p dir="auto">Regards,<br />
Rhast</p>
]]></description><link>https://forum.magicmirror.builders/topic/8680/accesing-config-in-node_helper</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 19:34:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8680.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Aug 2018 14:04:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Accesing config in node_helper on Thu, 30 Aug 2018 15:21:06 GMT]]></title><description><![CDATA[<p dir="auto">@sean Yep, thats what i do now. Messaging config around :-)  Thanks for clarifying so i can rest assured not to overlock something obvious :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/43963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43963</guid><dc:creator><![CDATA[Rhast]]></dc:creator><pubDate>Thu, 30 Aug 2018 15:21:06 GMT</pubDate></item><item><title><![CDATA[Reply to Accesing config in node_helper on Thu, 30 Aug 2018 14:43:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rhast" aria-label="Profile: rhast">@<bdi>rhast</bdi></a><br />
The usual way is sending config with <code>.sendSocketNotification()</code> from module main js to node_helper.js.</p>
]]></description><link>https://forum.magicmirror.builders/post/43959</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43959</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 30 Aug 2018 14:43:56 GMT</pubDate></item></channel></rss>
