<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My IKEA Ribba based 50x50 Mirror]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">i nearly finished my mirror.</p>
<p dir="auto">Shopping List:<br />
Frame 10€?<br />
Mirror 100€<br />
RaspberryPi 2<br />
Wireless Stick 5€<br />
Display Controller and powersupply from ebay ~30€<br />
Display 1280x800 from old notebook 0€<br />
Step Down Regulator from ebay 2€<br />
PIR Sensor from ebay 2€<br />
50cm HDMI cable 3€<br />
some little stuff ~5€</p>
<p dir="auto">I build this mirror on a CLAA154WB05AN display out of a Sony VAIO VGN-FZ31J notebook. Unfortunately it’s a glare display, which is not the brightest, but its working so far.  For  powering the raspberry i used a step down regulator, which is regulating the 12v input power from the display powersupply to 5v for the rasp.</p>
<p dir="auto">For the controller switches i drilled some holes in to the frame and extended the switches with m4 plastic screws to reach out of the frame.</p>
<p dir="auto">Some pics:<br />
<img src="https://abload.de/img/img_0259mqeqt.jpg" alt="" class=" img-fluid img-markdown" /><br />
<img src="https://abload.de/img/img_0260nyfj8.jpg" alt="" class=" img-fluid img-markdown" /><br />
<img src="https://abload.de/img/9f91517e-2537-47bc-bdspia8.jpgg" alt="" class=" img-fluid img-markdown" /><br />
<img src="https://abload.de/img/img_0261crd4i.jpg" alt="" class=" img-fluid img-markdown" /><br />
<img src="https://abload.de/img/img_0262fbihv.jpg" alt="" class=" img-fluid img-markdown" /><br />
<img src="https://abload.de/img/img_02635di26.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Regards<br />
Alex</p>
]]></description><link>https://forum.magicmirror.builders/topic/8688/my-ikea-ribba-based-50x50-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 05:06:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8688.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Aug 2018 12:50:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My IKEA Ribba based 50x50 Mirror on Fri, 31 Aug 2018 18:10:50 GMT]]></title><description><![CDATA[<p dir="auto">Thank you :) i mean depth of the frame after mirror is installed<br />
I want to know if everything from my setup will have enough space</p>
]]></description><link>https://forum.magicmirror.builders/post/44014</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44014</guid><dc:creator><![CDATA[Maros]]></dc:creator><pubDate>Fri, 31 Aug 2018 18:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to My IKEA Ribba based 50x50 Mirror on Fri, 31 Aug 2018 16:04:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">the glas is 4mm.</p>
<p dir="auto">Inside of the ribba frame is a kind of a subframe, which you can see on the seconds picture.</p>
<p dir="auto">I removed the subframe, inserted the glas and readded the subframe. Glas + Subframe then have the same height as the preinstalled metal clips to fix the backpanel.</p>
]]></description><link>https://forum.magicmirror.builders/post/44011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44011</guid><dc:creator><![CDATA[Seratio]]></dc:creator><pubDate>Fri, 31 Aug 2018 16:04:01 GMT</pubDate></item><item><title><![CDATA[Reply to My IKEA Ribba based 50x50 Mirror on Fri, 31 Aug 2018 15:20:24 GMT]]></title><description><![CDATA[<p dir="auto">looks great :) can you please tell me how thick is your mirror ?<br />
And also the frame itself on ikea page i found it’s 4,5cm but after you put there glass how much real space left ?</p>
]]></description><link>https://forum.magicmirror.builders/post/44009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44009</guid><dc:creator><![CDATA[Maros]]></dc:creator><pubDate>Fri, 31 Aug 2018 15:20:24 GMT</pubDate></item></channel></rss>
