<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nest Thermostat &amp; Protect]]></title><description><![CDATA[<p dir="auto">Is there somebody who can/will make a module for these products?</p>
<p dir="auto">So we can see the temperature etc. on our MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/topic/87/nest-thermostat-protect</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 01:04:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/87.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 May 2016 14:40:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sun, 24 Jul 2016 18:05:11 GMT]]></title><description><![CDATA[<p dir="auto">Here’s what it should look like for you.<br />
<img src="/uploads/files/1469383479468-nest.png" alt="Nest Module" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/2866</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2866</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Sun, 24 Jul 2016 18:05:11 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sun, 24 Jul 2016 17:43:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pugsly" aria-label="Profile: pugsly">@<bdi>pugsly</bdi></a> It should work as requested now.  I merged the branch with the master so you can just update the master now.  If the text looks weird it’s probably because I don’t know css and just made up stuff until it worked on my screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/2863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2863</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Sun, 24 Jul 2016 17:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Fri, 22 Jul 2016 14:58:57 GMT]]></title><description><![CDATA[<p dir="auto">Its a little better, its now showing what my HEAT temp is set to, but not the COOL.  Ideally it would show both with the dot in the middle as in the screen shot above, or if that’s not possible show the COOL setting when cooling, and the HEAT setting when heating and have the circle change colors.</p>
]]></description><link>https://forum.magicmirror.builders/post/2814</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2814</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Fri, 22 Jul 2016 14:58:57 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Mon, 04 Jul 2016 14:41:25 GMT]]></title><description><![CDATA[<p dir="auto">It shouldn’t be that difficult.  Can you add <a href="https://github.com/mochman/MMM-Nest/issues" target="_blank" rel="noopener noreferrer nofollow ugc">an issue</a> to the repo and I’ll mess around with the code.</p>
]]></description><link>https://forum.magicmirror.builders/post/2216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2216</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Mon, 04 Jul 2016 14:41:25 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Mon, 04 Jul 2016 01:19:00 GMT]]></title><description><![CDATA[<p dir="auto">ah yes, that was it.  I like keeping it in heat/cool mode and I have a program all setup, don’t really want to change it.</p>
<p dir="auto">How hard would it be for you to code it that way?</p>
]]></description><link>https://forum.magicmirror.builders/post/2208</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2208</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Mon, 04 Jul 2016 01:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Mon, 04 Jul 2016 00:58:01 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, it looks like you have it set up to heat/cool.  I haven’t programmed that function so I don’t know if the data the Nest API sends is correct.  Can you switch it over to cooling only and see if that fixes your temp?</p>
]]></description><link>https://forum.magicmirror.builders/post/2207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2207</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Mon, 04 Jul 2016 00:58:01 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Mon, 04 Jul 2016 00:00:27 GMT]]></title><description><![CDATA[<p dir="auto">Doesn’t matter what the thermostat says the inside temp is, the mirror always says its 68 deg.</p>
]]></description><link>https://forum.magicmirror.builders/post/2205</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2205</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Mon, 04 Jul 2016 00:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sun, 03 Jul 2016 23:59:44 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/uploads/files/1467590302746-settings.png" alt="0_1467589958801_settings.PNG" class=" img-fluid img-markdown" /> <img src="/uploads/files/1467590380996-mirror-s.jpg" alt="0_1467590036578_Mirror-s.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/2204</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2204</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Sun, 03 Jul 2016 23:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sun, 03 Jul 2016 16:46:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pugsly" aria-label="Profile: pugsly">@<bdi>pugsly</bdi></a> Can you take a screenshot and post it along with what it should be showing?  The way I have it configured, the small number is your current temp and the big number is the target temp.</p>
]]></description><link>https://forum.magicmirror.builders/post/2199</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2199</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Sun, 03 Jul 2016 16:46:15 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sun, 03 Jul 2016 07:51:23 GMT]]></title><description><![CDATA[<p dir="auto">maybe it’s a problem with the unit? °C and  °F</p>
]]></description><link>https://forum.magicmirror.builders/post/2194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2194</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 03 Jul 2016 07:51:23 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sun, 03 Jul 2016 00:05:54 GMT]]></title><description><![CDATA[<p dir="auto">ok, rebooted everything and its now showing the set temp, and turning blue while running but the number inside the circle showing the current temp never changes, stays at 68 even though the thermostat is showing the correct room temperature.</p>
<p dir="auto">Humidity % also seems correct now.</p>
]]></description><link>https://forum.magicmirror.builders/post/2193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2193</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Sun, 03 Jul 2016 00:05:54 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sat, 02 Jul 2016 22:42:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aartsie" aria-label="Profile: Aartsie">@<bdi>Aartsie</bdi></a> Any help would be great.  I’ve been in the process of moving so all my stuff is still scattered around the house.</p>
]]></description><link>https://forum.magicmirror.builders/post/2192</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2192</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Sat, 02 Jul 2016 22:42:59 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sat, 02 Jul 2016 22:42:11 GMT]]></title><description><![CDATA[<p dir="auto">Can you take a screenshot of what it is showing you and what it should be showing?</p>
]]></description><link>https://forum.magicmirror.builders/post/2191</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2191</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Sat, 02 Jul 2016 22:42:11 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Sat, 02 Jul 2016 19:10:23 GMT]]></title><description><![CDATA[<p dir="auto">So I got around to setting this up today, got my product ID, the secret, and even the PIN code.  Put it into the <a href="http://gettoken.sh" target="_blank" rel="noopener noreferrer nofollow ugc">gettoken.sh</a> and it spit out my token.  I added it into my config.js and I see the little circle on my mirror, but the temp is different then what the nest shows.  I’m also guessing that the % at the bottom is the inside humidity which also is not what the thermostat shows.</p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/post/2190</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2190</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Sat, 02 Jul 2016 19:10:23 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Fri, 01 Jul 2016 10:18:25 GMT]]></title><description><![CDATA[<p dir="auto">Nice job <a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> i was working on it as well before i saw yours just on time.<br />
Maybe it is better to put the Nest API pin code on the config file and let the module get the auth code from the API.</p>
<p dir="auto">This because the auth code has a expire date so you will replace it every year and it makes it easyer to install.<br />
If you need some help… maybe i can help you with it.</p>
]]></description><link>https://forum.magicmirror.builders/post/2144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2144</guid><dc:creator><![CDATA[Aartsie]]></dc:creator><pubDate>Fri, 01 Jul 2016 10:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Tue, 21 Jun 2016 15:43:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> Awesome, thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/1828</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1828</guid><dc:creator><![CDATA[Sachin]]></dc:creator><pubDate>Tue, 21 Jun 2016 15:43:20 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Tue, 21 Jun 2016 12:55:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sachin" aria-label="Profile: Sachin">@<bdi>Sachin</bdi></a> Sure.  I’m in the middle of a move right now, but once I get settled in I take a look at it.  It should be pretty straightforward.</p>
]]></description><link>https://forum.magicmirror.builders/post/1823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1823</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Tue, 21 Jun 2016 12:55:18 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Tue, 21 Jun 2016 12:46:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> Works like a charm! The only thing I would like to see is the fan icon if the fan is running without the AC or Heat on.</p>
]]></description><link>https://forum.magicmirror.builders/post/1822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1822</guid><dc:creator><![CDATA[Sachin]]></dc:creator><pubDate>Tue, 21 Jun 2016 12:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Fri, 27 May 2016 06:55:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> i will look in it asap, i’m really busy atm.</p>
]]></description><link>https://forum.magicmirror.builders/post/1125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1125</guid><dc:creator><![CDATA[Wilco89]]></dc:creator><pubDate>Fri, 27 May 2016 06:55:38 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Fri, 27 May 2016 00:45:40 GMT]]></title><description><![CDATA[<p dir="auto">I just took a wack at making a <a href="https://github.com/mochman/MMM-Nest" target="_blank" rel="noopener noreferrer nofollow ugc">Nest Module</a>.  It works, but it’s a pain to set up.  Nest has you walk through a bunch of hoops to get an account so you can get a token for your nest.  I made a simple script that walks you through it in the root folder.  The Module is very basic right now.  It just displays your current temp, requested temp, and humidity.  I will try to change it in a little bit to make it look like the Nest (Have a blue background around your Temp to indicate it’s cooling, etc…).  If you want to take a hand at making it look better, please go right ahead.</p>
<p dir="auto">I am using the REST format to get all the data.  If someone knows how to use firebase, that’s what Nest prefers you use to get all the info.</p>
]]></description><link>https://forum.magicmirror.builders/post/1120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1120</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Fri, 27 May 2016 00:45:40 GMT</pubDate></item><item><title><![CDATA[Reply to Nest Thermostat &amp; Protect on Fri, 13 May 2016 21:04:40 GMT]]></title><description><![CDATA[<p dir="auto">I will 2nd this one, I would love to be able to see my inside temp, and maybe some thermostat settings,  or alert if there is smoke.</p>
]]></description><link>https://forum.magicmirror.builders/post/652</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/652</guid><dc:creator><![CDATA[pugsly]]></dc:creator><pubDate>Fri, 13 May 2016 21:04:40 GMT</pubDate></item></channel></rss>
