<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror and RetroPie]]></title><description><![CDATA[<p dir="auto">apologize for my noob experience…I’m trying to make mm into Retropie ports I’ve read their <a href="https://github.com/RetroPie/RetroPie-Setup/wiki/Ports" target="_blank" rel="noopener noreferrer nofollow ugc">wiki</a> and <a href="https://www.reddit.com/r/RetroPie/comments/5og071/how_do_you_add_custom_applications_to_the_ports/" target="_blank" rel="noopener noreferrer nofollow ugc">This</a> and made mm shell but still no succes…any help please</p>
]]></description><link>https://forum.magicmirror.builders/topic/8708/magicmirror-and-retropie</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 12:41:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8708.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Sep 2018 19:58:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror and RetroPie on Thu, 06 Sep 2018 07:51:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ramez" aria-label="Profile: ramez">@<bdi>ramez</bdi></a> I’ve made a  script that runs MM from RetroPie but when try to run it didn’t start here is the npm log file…</p>
<pre><code class="language-0">1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using npm@5.6.0
3 info using node@v9.11.2
5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
6 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
7 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
8 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
9 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/pi/MagicMirror
10 silly lifecycle magicmirror@2.4.1~start: Args: [ '-c', 'sh run-start.sh' ]
11 silly lifecycle magicmirror@2.4.1~start: Returned: code: 1  signal: null
12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
13 verbose stack Error: magicmirror@2.4.1 start: `sh run-start.sh`
13 verbose stack Exit status 1
13 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:285:16)
13 verbose stack     at EventEmitter.emit (events.js:180:13)
13 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack     at ChildProcess.emit (events.js:180:13)
13 verbose stack     at maybeClose (internal/child_process.js:936:16)
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
14 verbose pkgid magicmirror@2.4.1
15 verbose cwd /home/pi/MagicMirror
16 verbose Linux 4.14.62-v7+
17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
18 verbose node v9.11.2
19 verbose npm  v5.6.0
20 error code ELIFECYCLE
21 error errno 1
22 error magicmirror@2.4.1 start: `sh run-start.sh`
22 error Exit status 1
23 error Failed at the magicmirror@2.4.1 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
<p dir="auto">any help please?</p>
]]></description><link>https://forum.magicmirror.builders/post/44190</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44190</guid><dc:creator><![CDATA[Ramez]]></dc:creator><pubDate>Thu, 06 Sep 2018 07:51:13 GMT</pubDate></item></channel></rss>
