<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google Assistant Virtual Output problem]]></title><description><![CDATA[<p dir="auto">Everything seems in normal working condition, But when I check my Google cloud console in the API request monitor section, it shows  the message below with red color highlight.</p>
<p dir="auto">Also, when I say" Give me a direction to xxx"<br />
and It respond just like what it suppose to(Voice respond with virtual text output “Ok, getting you direction to xxxx”), but then I was expecting there should be some sort of Map pop out beside the text, IT DID NOT.  It shows only text,    Other than this, everything looks normal, video output etc.<br />
Any idea what’s the  problem?</p>
<p dir="auto">api/request_count:consumed_api:REDUCE_SUM(mirror-mirror-assistant-216006): 0.033</p>
]]></description><link>https://forum.magicmirror.builders/topic/8739/google-assistant-virtual-output-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 18:09:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8739.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Sep 2018 19:46:57 GMT</pubDate><ttl>60</ttl></channel></rss>
