I can't get any information on screen
  • Re: MMM-NOAA - Another Weather Module
    Hello i was using your previous module on my MM dashboard. I installed your new module (great one) but i got an empty board showing up (no informations display). I have tested your new module with the weathermap key and weatherbit. The API key for weathermap works on the default weather module and the API key for weatherbit + the airKey works on your previous module version.
    Here is my config (i think i did it correctly)
    			module: 'MMM-NOAA3',
    				provider: "openweather",
    				apikey: "XXXXX",
    				airKey: "XXXXX",
    				css: "NOAA1",   // THIS MUST CONTAIN A CSS STYLE NAME
    				updateInterval: 15 * 60 * 1000, // every 15 minutes or whatever you choose but make sure you have an api that will allow that many calls per day!!!
    				userlat: "49.357470", //MUST HAVE BOTH
    				userlon: "6.168040"  //MUST HAVE BOTH
    Am i doing something wrong?
    Thanks a lot for your help
