<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror Blanks Several Hours]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have a magic mirror and after a period of several hours, the screen goes black. The mouse still works as I can move it and see the cursor. Clicking the mouse does nothing nor does hitting random keys. I can hit Ctrl-Q to exit Magic Mirror and I get the desktop back. A few seconds later pm2 kicks in and reloads the magic mirror. I experience this when connecting via VNC as well as locally at the system (obvious but mentioning for thoroughness). I also disabled screen blanking and screensaver per the install instructions.</p>
<p dir="auto">This is a new install on a Pi3B. I would greatly appreciate advice on how to approach this. Thank you in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/8849/magic-mirror-blanks-several-hours</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 19:55:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8849.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Oct 2018 13:25:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Wed, 30 Jan 2019 08:56:48 GMT]]></title><description><![CDATA[<p dir="auto">I had a blank screen for the first time when I got home today. System had been running for a couple of weeks without an issue.</p>
<p dir="auto">I’ve now added a cron job to restart every sunday…</p>
]]></description><link>https://forum.magicmirror.builders/post/51118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51118</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 30 Jan 2019 08:56:48 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 29 Jan 2019 09:41:55 GMT]]></title><description><![CDATA[<p dir="auto">After disabling every single module I found the one which makes trouble: MMM-GoogleMapsTraffic. When it is disabled MagicMirror runs for weeks without problems. I will start a new thread with the errors of the module.</p>
]]></description><link>https://forum.magicmirror.builders/post/51061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51061</guid><dc:creator><![CDATA[MacMirror]]></dc:creator><pubDate>Tue, 29 Jan 2019 09:41:55 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Sun, 13 Jan 2019 13:29:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I have experienced this problem for several months now and tried every hint I got from the forum. Nothing helped. After setting up the Raspberry from scratch with the new Version 2.6.0 the problem still exists. I checked the logs and got this from kernel.log:</p>
<pre><code>Jan  6 19:06:04 MagicMirror kernel: [421204.079652] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan  7 14:46:41 MagicMirror kernel: [492041.343276] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan  8 07:00:54 MagicMirror kernel: [550494.589589] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan  8 15:35:51 MagicMirror kernel: [581391.726824] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan  9 10:45:05 MagicMirror kernel: [650346.316032] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan 10 15:22:19 MagicMirror kernel: [753380.953024] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan 12 05:15:03 MagicMirror kernel: [889746.479924] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
Jan 12 21:06:09 MagicMirror kernel: [946812.909084] Unhandled prefetch abort: breakpoint debug exception (0x002) at 0x01bfc760
<p dir="auto">It looks to me like a bug in MagicMirror. Should I make a bug report with the log?</p>
]]></description><link>https://forum.magicmirror.builders/post/50043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50043</guid><dc:creator><![CDATA[MacMirror]]></dc:creator><pubDate>Sun, 13 Jan 2019 13:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Thu, 10 Jan 2019 09:27:06 GMT]]></title><description><![CDATA[<p dir="auto">Not a solution to the root problem, but you can add the WatchDog module to automatically quit MM when UI freezes:</p>
<p dir="auto"><a href="https://github.com/MichMich/MMM-WatchDog" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MMM-WatchDog</a></p>
]]></description><link>https://forum.magicmirror.builders/post/49889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49889</guid><dc:creator><![CDATA[retroflex]]></dc:creator><pubDate>Thu, 10 Jan 2019 09:27:06 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Thu, 10 Jan 2019 07:46:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> Thx for this now it works perfect</p>
]]></description><link>https://forum.magicmirror.builders/post/49885</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/49885</guid><dc:creator><![CDATA[Skorpionbird]]></dc:creator><pubDate>Thu, 10 Jan 2019 07:46:50 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Thu, 06 Dec 2018 01:20:53 GMT]]></title><description><![CDATA[<p dir="auto">Has anyone found anything interesting in the logs? <code>pm2 status MagicMirror</code>?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/striiker" aria-label="Profile: striiker">@<bdi>striiker</bdi></a> said in <a href="/post/45264">Magic Mirror Blanks Several Hours</a>:</p>
<p dir="auto">When I experience this condition, I see no slowness while connected to ssh.</p>
<p dir="auto">That makes me think it’s an electron problem. If you have no slowness during an SSH session, I would try the pm2 command above and see if something is kicking out error messages. Likewise, try the <code>top</code> command and see what your processor utilization level is, plus see if something is taking up an inordinate amount of resources.</p>
]]></description><link>https://forum.magicmirror.builders/post/47767</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47767</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 06 Dec 2018 01:20:53 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 04 Dec 2018 16:02:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrjmsh" aria-label="Profile: hrjmsh">@<bdi>hrjmsh</bdi></a></p>
<p dir="auto">Same here as well. Would love to hear if anyone got this one sorted.</p>
]]></description><link>https://forum.magicmirror.builders/post/47699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47699</guid><dc:creator><![CDATA[Lexingtonian]]></dc:creator><pubDate>Tue, 04 Dec 2018 16:02:11 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Mon, 15 Oct 2018 17:49:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/striiker" aria-label="Profile: striiker">@<bdi>striiker</bdi></a> I am having the exact same problem. Screen goes black every 6-8 hours with just the pointer showing. I have to reload/restart the Magic Mirror then. This started to happen after upgrade to version 2.4.0<br />
I have upgraded to 2.5.0 but the issue remains the same.<br />
I am still trying to figure out the solution; just wanted to share with you that you are not the only one facing this problem!</p>
]]></description><link>https://forum.magicmirror.builders/post/45442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45442</guid><dc:creator><![CDATA[hrjmsh]]></dc:creator><pubDate>Mon, 15 Oct 2018 17:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Thu, 11 Oct 2018 14:30:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> said in <a href="/post/45249">Magic Mirror Blanks Several Hours</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/striiker" aria-label="Profile: striiker">@<bdi>striiker</bdi></a> Could it be the screensaver? Have you tried updating to 2.5.0 or downgrading to 2.3.x? I am pretty sure I didn’t have the problem with 2.3. In my case it’s enough to reload the MM only once a day. Also I had noticed that my Pi was reeeeeeeaaaaaaallllllyyyyyyy slow when connecting via shh after the screen blanked. Slow to the point I thought it crashed. Pretty sure it was a memory leak or so.</p>
<p dir="auto">I haven’t updated to 2.5 yet as I want to wait and see what problems other users experience :face_with_stuck-out_tongue_winking_eye:</p>
<p dir="auto">Well, I have disabled the screensaver via config settings as advised by several of the tutorials for setting up the mirror. Plus, if it were blanking or a screensaver, it would wake when I move the mouse or type. When I try to type etc, nothing shows, just the black screen. Ctrl-R or CTRL-Q works.<br />
I am on the latest (2.5) and have not tried downgrading. I assume that would require a full wipe and re-install but may be worth trying… When I experience this condition, I see no slowness while connected to ssh. I’m sure this is some odd leak which crashes some aspect of whatever displays the modules over time. I’m just surprised that nobody else (in any significant number) is experiencing this. It happens with a new everything… (Pi3B, latest firmware and latest mirror version)</p>
]]></description><link>https://forum.magicmirror.builders/post/45264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45264</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Thu, 11 Oct 2018 14:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Thu, 11 Oct 2018 05:25:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/striiker" aria-label="Profile: striiker">@<bdi>striiker</bdi></a> Could it be the screensaver? Have you tried updating to 2.5.0 or downgrading to 2.3.x? I am pretty sure I didn’t have the problem with 2.3. In my case it’s enough to reload the MM only once a day. Also I had noticed that my Pi was reeeeeeeaaaaaaallllllyyyyyyy slow when connecting via shh after the screen blanked. Slow to the point I thought it crashed. Pretty sure it was a memory leak or so.</p>
]]></description><link>https://forum.magicmirror.builders/post/45249</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45249</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Thu, 11 Oct 2018 05:25:47 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Wed, 10 Oct 2018 21:07:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chief" aria-label="Profile: chief">@<bdi>chief</bdi></a> said in <a href="/post/45192">Magic Mirror Blanks Several Hours</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> It was always black - if I don’t run with sudo it quits almost immediately. I’m not sure exactly what the issue was, but I went ahead and restored a backup from 2.4.1 and it’s working fine now (removed the update alert on the top bar).</p>
<p dir="auto">If you need to run this as sudo then your installation probably has root as the owner of the files. A simple way to check this is log in as pi and type cd ~  and then ls -al  you should see the list of files and directories and a column of pi pi  (shows owner and group membership of the file or directory). If you see a lot of root root then you ran something which changed ownership of these files and directories…</p>
<pre><code>ls -al
total 221604
drwxr-xr-x  17 pi pi      4096 Oct 10 16:00 .
drwxr-xr-x  27 pi pi      4096 Oct 10 10:33 ..
-rw-r--r--   1 pi pi     24164 Oct  8 18:56 CHANGELOG.md
drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 clientonly
drwxr-xr-x   2 pi pi      4096 Oct  8 19:00 config
-rw-------   1 pi pi 498610176 Oct 10 16:00 core
drwxr-xr-x   3 pi pi      4096 Oct  8 19:16 css
-rw-r--r--   1 pi pi       856 Oct  8 18:56 dangerfile.js
-rw-r--r--   1 pi pi       132 Oct  8 18:56 .eslintignore
-rw-r--r--   1 pi pi       448 Oct  8 18:56 .eslintrc.json
drwxr-xr-x   3 pi pi      4096 Oct  8 19:00 fonts
drwxr-xr-x   8 pi pi      4096 Oct 10 10:33 .git
drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 .github
-rw-r--r--   1 pi pi      1074 Oct  8 18:56 .gitignore
-rw-r--r--   1 pi pi      2385 Oct  8 18:56 Gruntfile.js
-rw-r--r--   1 pi pi      2675 Oct  8 18:56 index.html
drwxr-xr-x   3 pi pi      4096 Oct  8 18:56 installers
drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 js
-rw-r--r--   1 pi pi       271 Oct  8 18:56 jsconfig.json
-rw-r--r--   1 pi pi      1118 Oct  8 18:56 LICENSE.md
drwxr-xr-x   4 pi pi      4096 Oct  8 18:56 modules
-rw-r--r--   1 pi pi      1040 Oct  8 18:56 module-types.ts
drwxr-xr-x 642 pi pi     20480 Oct  8 19:00 node_modules
-rw-r--r--   1 pi pi      2195 Oct  8 18:56 package.json
-rw-r--r--   1 pi pi    271341 Oct  8 19:00 package-lock.json
-rw-r--r--   1 pi pi     14450 Oct  8 18:56 README.md
-rw-r--r--   1 pi pi       142 Oct  8 18:56 run-start.sh
drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 serveronly
-rw-r--r--   1 pi pi       478 Oct  8 18:56 .snyk
drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 splashscreen
-rw-r--r--   1 pi pi       126 Oct  8 18:56 .stylelintrc
drwxr-xr-x   6 pi pi      4096 Oct  8 18:56 tests
drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 translations
-rw-r--r--   1 pi pi       285 Oct  8 18:56 .travis.yml
drwxr-xr-x   3 pi pi      4096 Oct  8 19:00 vendor
<p dir="auto">If you have a permissions issue, you can fix it easily by typing:</p>
<pre><code>sudo chown -R pi:pi /home/pi
<p dir="auto">This will change owner and group membership to pi</p>
]]></description><link>https://forum.magicmirror.builders/post/45238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45238</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Wed, 10 Oct 2018 21:07:30 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Wed, 10 Oct 2018 21:00:21 GMT]]></title><description><![CDATA[<p dir="auto">I’m still having the issue where my screen blanks (modules stop loading) after about 5-6 hours. I perform a Ctrl-r to reload and it continues. Has anyone else figured out a cause or a solution? I’ll have to add several more cron jobs to reload modules periodically. I am not running anything beyond the core modules at present. I even performed a fresh install and still see this happen. I can’t see this being normal or people just tolerating it…</p>
<p dir="auto">Thoughts?</p>
* MIT Licensed.
var config = {
	"port": 8080,
	"language": "en",
	"timeFormat": 24,
	"units": "imperial",
	"modules": [
			"module": "alert"
			"module": "clock",
			"position": "top_left"
			"module": "calendar",
			"header": "Calendar",
			"position": "top_left",
			"config": {
				"calendars": [
						"symbol": "calendar-check-o ",
						"url": "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
						"color": "#FFFFFF"
						"symbol": "calendar ",
						"url": "https://eleted",
						"color": "#04f448",
						"fetchInterval": 30000
                                                "symbol": "birthday-cake ",
                                                "url": "https://deleted                              "color": "#DA70D6",
				"colored": true,
				timeFormat: "absolute",
				showEnd: false,
				fullDayEventDateFormat: 'Do MMM',
			"module": "compliments",
			"position": "lower_third"
			"module": "currentweather",
			"position": "top_right",
			"config": {
				"location": "deleted",
				"locationID": "deleted",
				"appid": "deleted
			"module": "weatherforecast",
			"header": "Weather Forecast",
			"config": {
				"appid": "deleted",
				"colored": "true"
			"module": "newsfeed",
			"position": "bottom_bar",
			"config": {
				"feeds": [
						"title": "New York Times",
						"url": "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
						"title": "BBC World News",
						"url": "http://feeds.bbci.co.uk/news/world/us_and_canada/rss.xml"
						"title": "Reuters Science News",
						"url": "http://feeds.reuters.com/reuters/scienceNews"
				"showSourceTitle": true,
				"showPublishDate": true
			"module": "MMM-Admin-Interface"
	"address": "0.0.0.0",
	"ipWhitelist": [
		"127.0.0.1",
		"::ffff:127.0.0.1",
		"::1",
		"deleted"
]]></description><link>https://forum.magicmirror.builders/post/45237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45237</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Wed, 10 Oct 2018 21:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 20:36:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> It was always black - if I don’t run with sudo it quits almost immediately. I’m not sure exactly what the issue was, but I went ahead and restored a backup from 2.4.1 and it’s working fine now (removed the update alert on the top bar).</p>
]]></description><link>https://forum.magicmirror.builders/post/45192</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45192</guid><dc:creator><![CDATA[chief]]></dc:creator><pubDate>Tue, 09 Oct 2018 20:36:34 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 17:30:32 GMT]]></title><description><![CDATA[<p dir="auto">Why are you running the update command with sudo?<br />
Does your mirror work but it blanks the screen after some hours or is it always black?</p>
]]></description><link>https://forum.magicmirror.builders/post/45180</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45180</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Tue, 09 Oct 2018 17:30:32 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 16:55:20 GMT]]></title><description><![CDATA[<p dir="auto">I’m having trouble with this as well - blank screen for the past day no matter what I try to do. Now when I try to git pull &amp;&amp; npm install, I get the following errors:</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ sudo git pull &amp;&amp; npm install<br />
Already up-to-date.<br />
npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/socket.io-parser/node_modules<br />
npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.</p>
<p dir="auto">npm ERR! path /home/pi/MagicMirror/node_modules/socket.io-parser/node_modules<br />
npm ERR! code EACCES<br />
npm ERR! errno -13<br />
npm ERR! syscall access<br />
npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules’<br />
npm ERR!  { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules’<br />
npm ERR!   stack: ‘Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules'’,<br />
npm ERR!   errno: -13,<br />
npm ERR!   code: ‘EACCES’,<br />
npm ERR!   syscall: ‘access’,<br />
npm ERR!   path: ‘/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules’ }<br />
npm ERR!<br />
npm ERR! The operation was rejected by your operating system.<br />
npm ERR! It is likely you do not have the permissions to access this file as the current user<br />
npm ERR!<br />
npm ERR! If you believe this might be a permissions issue, please double-check the<br />
npm ERR! permissions of the file and its containing directories, or try running<br />
npm ERR! the command again as root/Administrator (though this is not recommended).</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     /home/pi/.npm/_logs/2018-10-09T16_49_46_380Z-debug.log</p>
<p dir="auto">AND if I try to update npm itself, a different error appears:</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ sudo npm update<br />
<p dir="auto">npm ERR! path /home/pi/MagicMirror/node_modules/source-map/build/suffix-utils.jsm<br />
npm ERR! code Unknown system error -117<br />
npm ERR! errno -117<br />
npm ERR! syscall unlink<br />
npm ERR! Unknown system error -117: Unknown system error -117, unlink ‘/home/pi/MagicMirror/node_modules/source-map/build/suffix-utils.jsm’</p>
npm ERR!     /root/.npm/_logs/2018-10-09T16_54_00_820Z-debug.log</p>
<p dir="auto">Any help??</p>
]]></description><link>https://forum.magicmirror.builders/post/45179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45179</guid><dc:creator><![CDATA[chief]]></dc:creator><pubDate>Tue, 09 Oct 2018 16:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 15:56:02 GMT]]></title><description><![CDATA[<p dir="auto">Just run NPM install in the MagicMirror directory and seems to have fixed it.  Was suggestion from NPM audit command<br />
thanks for suggestion tho</p>
]]></description><link>https://forum.magicmirror.builders/post/45177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45177</guid><dc:creator><![CDATA[Graham Rich]]></dc:creator><pubDate>Tue, 09 Oct 2018 15:56:02 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 15:54:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/graham-rich" aria-label="Profile: graham-rich">@<bdi>graham-rich</bdi></a> to update your MM installation you have to enter your MM directory and run <code>git pull &amp;&amp; npm install</code>. Looks like you tried to update npm instead.</p>
]]></description><link>https://forum.magicmirror.builders/post/45176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45176</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Tue, 09 Oct 2018 15:54:41 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 15:31:53 GMT]]></title><description><![CDATA[<p dir="auto">I’m not sure if my issue isnt an update failure.   Im getting this message on upgrade</p>
<p dir="auto">pi@pi:~/MagicMirror $ npm update</p>
<p dir="auto">phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/phantomjs-prebuilt<br />
node install.js</p>
<p dir="auto">PhantomJS not found on PATH<br />
Unexpected platform or architecture: linux/arm<br />
It seems there is no binary available for your platform/architecture<br />
Try to install PhantomJS globally<br />
npm WARN grunt-yamllint@0.3.0 requires a peer of grunt@&gt;=1.0.1 but none is installed. You must install peer dependencies yourself.<br />
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 (node_modules/phantomjs-prebuilt):<br />
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 install: <code>node install.js</code><br />
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1</p>
<ul>
<li>moment@2.22.2</li>
<li>iconv-lite@0.4.24</li>
<li>walk@2.3.14<br />
added 5 packages from 11 contributors and audited 2316 packages in 40.649s<br />
found 5 low severity vulnerabilities<br />
run <code>npm audit fix</code> to fix them, or <code>npm audit</code> for details</li>
</ul>
node install.js</p>
Try to install PhantomJS globally</p>
<p dir="auto">electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver<br />
node ./download-chromedriver.js</p>
<p dir="auto">successfully dowloaded and extracted!<br />
<ul>
<li>spectron@3.8.0<br />
removed 4 packages, updated 2 packages and audited 2311 packages in 42.884s<br />
found 5 low severity vulnerabilities</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/45175</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45175</guid><dc:creator><![CDATA[Graham Rich]]></dc:creator><pubDate>Tue, 09 Oct 2018 15:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 15:18:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  So I’ve updated my MagicMirror today with NPM update and NPM upgrade and my mirror is now black when I load it.  My Mirror is pretty busy with NNOA3, video window from MotionEye and a few of the UK train apps.  I was going to thin it down to see if that fixes it but thought Id check if anyone else found a fix yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/45174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45174</guid><dc:creator><![CDATA[Graham Rich]]></dc:creator><pubDate>Tue, 09 Oct 2018 15:18:54 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 14:35:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/44922">Magic Mirror Blanks Several Hours</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/striiker" aria-label="Profile: striiker">@<bdi>striiker</bdi></a> is this version 2.4.1?</p>
<p dir="auto">The update module was throwing an error causing the black screen.</p>
<p dir="auto">I would comment out that module</p>
<p dir="auto">I’m in the same boat as <a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: MadScientist">@<bdi>MadScientist</bdi></a> in that my module rotation still dies necessitating a restart of the modules. Canceling the update check did improve the situation in that it apparently does not crash out as often.</p>
]]></description><link>https://forum.magicmirror.builders/post/45173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45173</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Tue, 09 Oct 2018 14:35:46 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 14:35:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/striiker" aria-label="Profile: striiker">@<bdi>striiker</bdi></a> <code>0 6 * * * pm2 reload mm</code><br />
It reloads my <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> script every day at 6am. Working perfectly fine for quite some time now.</p>
]]></description><link>https://forum.magicmirror.builders/post/45172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45172</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Tue, 09 Oct 2018 14:35:02 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 09 Oct 2018 14:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> Could you please share what you use in your cronjob to reload the modules? Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/45171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45171</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Tue, 09 Oct 2018 14:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 02 Oct 2018 18:08:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> said in <a href="/post/44924">Magic Mirror Blanks Several Hours</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
That didn’t help in my case, hence the work-around with the cronjob. But it’s true that everybody should first try to disable the update module in their config.</p>
<p dir="auto">I was unaware of the suggestion to kill the update module. I have removed it from my config and will monitor the status. Thank you for the suggestion (and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> )! Any other best practice suggestions which I should consider? I have just done the base install and modified weather icons / details and also installed Alexapi (yet to work on that module as I am still trying to understand if I should also install either MMM-Alexa or MMM-Awesome-Alexa too as I am not clear on how these all work).</p>
]]></description><link>https://forum.magicmirror.builders/post/44926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44926</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Tue, 02 Oct 2018 18:08:33 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror Blanks Several Hours on Tue, 02 Oct 2018 18:05:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/44922">Magic Mirror Blanks Several Hours</a>:</p>
<p dir="auto">I am at the latest build (2.5.0) although I installed Magic Mirror from the previous version and have the update module running.</p>
]]></description><link>https://forum.magicmirror.builders/post/44925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/44925</guid><dc:creator><![CDATA[StrIIker]]></dc:creator><pubDate>Tue, 02 Oct 2018 18:05:31 GMT</pubDate></item></channel></rss>
