<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error when installing please help!]]></title><description><![CDATA[<p dir="auto">Need help！<br />
When I installing magicmirror using</p>
<p dir="auto"><code>bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"</code></p>
<p dir="auto">things go wrong like:</p>
<pre><code>Downloading electron-v2.0.0-linux-arm.zip
Error: read ECONNRESET
/home/pi/MagicMirror/node_modules/electron/install.js:47
  throw err
    at TLSWrap.onread (net.js:602:25)
npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! electron@2.0.0 postinstall: `node install.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the electron@2.0.0 postinstall script.
npm ERR!     /home/pi/.npm/_logs/2018-10-15T15_53_36_040Z-debug.log
Delete MagicMirror folder to install again, still like this.
I have notice that other people are also getting trouble like this:
https://github.com/MichMich/MagicMirror/issues/1281
<p dir="auto">Please help!<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/8927/error-when-installing-please-help</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 08:26:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8927.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Oct 2018 23:08:48 GMT</pubDate><ttl>60</ttl></channel></rss>
