<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Hotword problem with Black Screen]]></title><description><![CDATA[<p dir="auto">Hi, I’ve instaled MMM-AssistantMk2 and it seems to be working fine.   I had a problem with blackscreen on that but used <a href="https://forum.magicmirror.builders/topic/8929/mmm-assistantmk2-problem-with-blackscreen/2">this post from a couple days ago to fix it</a>.<br />
Now I’ve installed MMM-Hotword and am getting a black screen when i try to start my mirror with it configured.    I believe snowboy is not installing, there isn’t a folder for it in “node_modules” (which, from my reading, I <em>think</em> there is supposed to be).    I’ve run the “save snowboy” command a bunch of times but get the same errors every time.</p>
<p dir="auto">Any help would be appreciated.</p>
<p dir="auto">–edit--  I just realized i posted this in the main troubleshooting forum instead of the module troubleshooting.   Should i delete and repost? Or can the Mods move it?</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy
npm WARN deprecated hoek@2.16.3: The major version is no longer supported. Please update to 4.x or newer
&gt; snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
&gt; node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.11.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
internal/modules/cjs/loader.js:583
    throw err;
Error: Cannot find module 'nan'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
    at Function.Module._load (internal/modules/cjs/loader.js:507:25)
    at Module.require (internal/modules/cjs/loader.js:637:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at [eval]:1:1
    at Script.runInThisContext (vm.js:96:20)
    at Object.runInThisContext (vm.js:303:38)
    at Object.&lt;anonymous&gt; ([eval]-wrapper:6:22)
    at Module._compile (internal/modules/cjs/loader.js:689:30)
    at evalScript (internal/bootstrap/node.js:576:27)
gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    throw err;
    at [eval]:1:1
gypgyp ERR!  configure error
gyp ERR! gypstack Error: `gyp` failed with exit code: 1
gyp  ERR!ERR!  stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
stackgyp Error: `gyp` failed with exit code: 1
 gypERR!  stackERR!     at ChildProcess.emit (events.js:182:13)
 stackgyp     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
 ERR!gyp  stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
ERR! stack     at ChildProcess.emit (events.js:182:13)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
gyp ERR! System Linux 4.14.50-v7+
gyp ERR! Systemgyp Linux 4.14.50-v7+
 ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
gyp gypERR! node -v  v10.11.0
ERR! gypcommand  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
ERR! node-gyp -v v3.8.0
gyp ERR! not okgyp
gyp ERR! node -v v10.11.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm' (1)
node-pre-gyp ERR! stack     at ChildProcess.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:962:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
node-pre-gyp ERR! System Linux 4.14.50-v7+
node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
node-pre-gyp ERR! node -v v10.11.0
node-pre-gyp ERR! node-pre-gyp -v v0.6.39
node-pre-gyp ERR! not ok
npm WARN MMM-Hotword@1.0.0 No repository field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the snowboy@1.3.1 install script.
npm ERR!     /home/pi/.npm/_logs/2018-10-21T03_32_36_367Z-debug.log
]]></description><link>https://forum.magicmirror.builders/topic/8949/mmm-hotword-problem-with-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 03:48:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8949.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Oct 2018 03:48:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Hotword problem with Black Screen on Thu, 25 Oct 2018 15:52:27 GMT]]></title><description><![CDATA[<p dir="auto">I’m going to call this solved, kinda.   I restarted from scratch and got it to work.       Snowboy was not installing for some reason.     Possibly my raspbian was not up to date.   But we’ll never know.</p>
]]></description><link>https://forum.magicmirror.builders/post/45882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45882</guid><dc:creator><![CDATA[eggwardo]]></dc:creator><pubDate>Thu, 25 Oct 2018 15:52:27 GMT</pubDate></item></channel></rss>
