<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Google Assistant - which one to use!]]></title><description><![CDATA[<p dir="auto">Hi Everyone!</p>
<p dir="auto">I want to include in my future smart mirror the ability to use it as a Google Assistant. I have a few of them in my home, but not where my mirror is going to be placed to it will be a great feature!</p>
<p dir="auto">However I’m somewhere stuck now. Which Google Assistant module should I use?<br />
<a href="https://github.com/eouia/MMM-AssistantMk2" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-AssistantMk2</a> or<br />
<a href="https://github.com/gauravsacc/MMM-GoogleAssistant" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-GoogleAssistantt</a></p>
<p dir="auto">What I want to achive is:</p>
<ul>
<li>Use as a regular Google Home device, Ok Google hotword, etc…</li>
<li>User identification (like on the regular Google Home device, so it knows whos playlist should play, whos settings should use when answering)</li>
<li>Reply via speaker and via the screen (Maybe a notification with the response)</li>
</ul>
<p dir="auto">So which one should I use?</p>
<p dir="auto">Thanks for the help in advance!</p>
]]></description><link>https://forum.magicmirror.builders/topic/8958/google-assistant-which-one-to-use</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 16:25:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/8958.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Oct 2018 21:06:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Google Assistant - which one to use! on Sat, 02 Feb 2019 23:09:05 GMT]]></title><description><![CDATA[<p dir="auto">Thanks to share your experience. I Will see that.</p>
]]></description><link>https://forum.magicmirror.builders/post/51361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51361</guid><dc:creator><![CDATA[bleusswissbless]]></dc:creator><pubDate>Sat, 02 Feb 2019 23:09:05 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant - which one to use! on Sat, 02 Feb 2019 17:47:07 GMT]]></title><description><![CDATA[<p dir="auto">tried both of them but at least for me none is stable.After some hours they crash and mm needs restart.Instead i use <a href="https://github.com/shivasiddharth/GassistPi" target="_blank" rel="noopener noreferrer nofollow ugc">Gassistpi</a> project outside MM (installed at the same Rpi) and its working fine plus its has many extra features .It only lucks the visual at MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/51337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51337</guid><dc:creator><![CDATA[costascontis]]></dc:creator><pubDate>Sat, 02 Feb 2019 17:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to Google Assistant - which one to use! on Fri, 01 Feb 2019 21:01:31 GMT]]></title><description><![CDATA[<p dir="auto">I ask myself this exact question :D<br />
What is the big difference between this two modules ?<br />
thnak you guys in adavance ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/51274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/51274</guid><dc:creator><![CDATA[bleusswissbless]]></dc:creator><pubDate>Fri, 01 Feb 2019 21:01:31 GMT</pubDate></item></channel></rss>
