<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Monitor saying 'No Signal']]></title><description><![CDATA[<p dir="auto">Ok gents a bit of a ramble here.</p>
<p dir="auto">The other night I finished everything I wanted module wise so i was going to start on hardware (i.e taking monitor out of frame etc) After I took the monitor out of the frame and plugged it in to my Pi I noticed the screen was saying ‘no signal.’ I started to panic as the control for the monitor popped out of the socket so I was worried I just pissed a $150 monitor down the drain. I decide to try my PC monitor and lo and behold I get the same thing… I plug in my future MagicMirror Monitor to my PC and guess what… It works like a charm.<br />
This obviously means something else is wrong…I am literally not at all a computer guy. I took my SD card out and plugged into my computer and I see all the files so that means that is not corrupted/dead right? So it must be the R Pi3 itself? The Pi lights up when I put power to it and everyhting…I tried using both the DVI and HDMI port on the R Pi3</p>
<p dir="auto">Help would be greatly appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/896/monitor-saying-no-signal</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 17:00:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/896.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Oct 2016 00:21:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Monitor saying 'No Signal' on Sat, 29 Oct 2016 18:26:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cato" aria-label="Profile: Cato">@<bdi>Cato</bdi></a></p>
<p dir="auto">I will look into this thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/7285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7285</guid><dc:creator><![CDATA[Officeglen]]></dc:creator><pubDate>Sat, 29 Oct 2016 18:26:16 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor saying 'No Signal' on Sat, 29 Oct 2016 17:10:22 GMT]]></title><description><![CDATA[<p dir="auto">Maybe I remember wrong, but I think SSH is turned on as default when you set up the RPi (Jessey)…?</p>
]]></description><link>https://forum.magicmirror.builders/post/7283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7283</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Sat, 29 Oct 2016 17:10:22 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor saying 'No Signal' on Sat, 29 Oct 2016 17:07:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> I dont think i set that up when i installed everything because I didnt think I would ever use that…</p>
]]></description><link>https://forum.magicmirror.builders/post/7282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7282</guid><dc:creator><![CDATA[Officeglen]]></dc:creator><pubDate>Sat, 29 Oct 2016 17:07:44 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor saying 'No Signal' on Sat, 29 Oct 2016 13:49:07 GMT]]></title><description><![CDATA[<p dir="auto">When the Pi is plugged in, can you SSH to it?</p>
]]></description><link>https://forum.magicmirror.builders/post/7261</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7261</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 29 Oct 2016 13:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to Monitor saying 'No Signal' on Sat, 29 Oct 2016 05:58:38 GMT]]></title><description><![CDATA[<p dir="auto">You’ve probably already checked it, but be sure the SD card really is inserted in the Pi. It happened to me a couple of times…</p>
]]></description><link>https://forum.magicmirror.builders/post/7234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7234</guid><dc:creator><![CDATA[Cato]]></dc:creator><pubDate>Sat, 29 Oct 2016 05:58:38 GMT</pubDate></item></channel></rss>
