<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a module to display webpage widgets?]]></title><description><![CDATA[<p dir="auto">I’ve struggled with configuring the default Weatherforecast module to look like I wanted, when I realised that there already is a webpage widget which shows the weather just as I want it.</p>
<p dir="auto">So before I create one, is there any existing module that already does this?</p>
<p dir="auto">The widget looks like this:<br />
<img src="http://i66.tinypic.com/votueu.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The code for the widget:</p>
<div id="c_5e649d272a176286200b1ecbe070ab52" class="completo">
<h2 style="color:#ffffff;margin:0 0 3px;padding:2px;font:bold 13px/1.2 Verdana;text-align:center">Väder Stockholm</h2>
</div>]]></description><link>https://forum.magicmirror.builders/topic/900/is-there-a-module-to-display-webpage-widgets</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 08:01:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/900.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Oct 2016 10:15:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a module to display webpage widgets? on Sat, 29 Oct 2016 14:42:46 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the tip, I’ll try and see if that works.</p>
]]></description><link>https://forum.magicmirror.builders/post/7266</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7266</guid><dc:creator><![CDATA[GooMagic]]></dc:creator><pubDate>Sat, 29 Oct 2016 14:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a module to display webpage widgets? on Sat, 29 Oct 2016 14:07:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> then he will have the Same Problem of an unevaluated script tag</p>
]]></description><link>https://forum.magicmirror.builders/post/7264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7264</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 29 Oct 2016 14:07:14 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a module to display webpage widgets? on Sat, 29 Oct 2016 13:52:50 GMT]]></title><description><![CDATA[<p dir="auto">The HelloWorld module may be able to do it. If you check out <a href="https://forum.magicmirror.builders/topic/706/halloween-mirror-ghouls-anyone/35">the Halloween Video</a> thread, you’ll see that we’re dropping all sorts of HTML onto the UI. Just replace the <code>&lt;VIDEO&gt;</code> tag stuff we’re doing with your embed code. It may take some fine tuning.</p>
]]></description><link>https://forum.magicmirror.builders/post/7262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7262</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sat, 29 Oct 2016 13:52:50 GMT</pubDate></item></channel></rss>
