<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[First MagicMirror]]></title><description><![CDATA[<p dir="auto">Finally finished my first maker/raspberryPi project :D</p>
<p dir="auto">Took apart an old 12"x21" monitor and put it in a simple shadowbox frame, and wrote a MagicMirror <a href="https://github.com/delightedCrow/WallberryTheme" target="_blank" rel="noopener noreferrer nofollow ugc">module</a> to give it a digital photo / wall display feel. I’ll probably add more modules later but I like the simplicity of it so far:</p>
<p dir="auto"><img src="/assets/uploads/files/1540954828710-mm-yah.jpg" alt="0_1540954824278_mm-yah.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/9001/first-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 02:34:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9001.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 Oct 2018 03:17:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to First MagicMirror on Mon, 01 Jul 2019 17:34:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayyatali" aria-label="Profile: HayyatAli">@<bdi>HayyatAli</bdi></a> thanks!</p>
<p dir="auto">Breaking the project into small steps is a good idea and <a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> has really good advice in starting with the raspberry pi. If you don’t already have one I recommend taking a look at <a href="https://www.adafruit.com/product/3775" target="_blank" rel="noopener noreferrer nofollow ugc">Adafruit</a>. Once you have your pi set up you can look at getting a monitor, then you can decide how you want to frame it.</p>
]]></description><link>https://forum.magicmirror.builders/post/58401</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58401</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Mon, 01 Jul 2019 17:34:09 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Mon, 01 Jul 2019 15:32:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayyatali" aria-label="Profile: HayyatAli">@<bdi>HayyatAli</bdi></a><br />
In my opinion, get a Pi 3 B+, download the software and follow the instructions to install.  Then play around with some of the modules and see how far you get.  Took me only a few hours to get mine up an running and I explore different modules as often as I can.</p>
]]></description><link>https://forum.magicmirror.builders/post/58398</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58398</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 01 Jul 2019 15:32:34 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Mon, 01 Jul 2019 13:54:33 GMT]]></title><description><![CDATA[<p dir="auto">well done…liked your work…i m interested to build this mirror  but really don’t know how to start???from where should i start???any help???</p>
]]></description><link>https://forum.magicmirror.builders/post/58392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58392</guid><dc:creator><![CDATA[HayyatAli]]></dc:creator><pubDate>Mon, 01 Jul 2019 13:54:33 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Sun, 30 Jun 2019 05:52:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pnobrega" aria-label="Profile: pnobrega">@<bdi>pnobrega</bdi></a> Thanks, I did a couple of blog posts about <a href="https://delightedcrow.tumblr.com/post/176180785204/wallberry-monitor-teardown" target="_blank" rel="noopener noreferrer nofollow ugc">the monitor tear down</a> and the <a href="https://delightedcrow.tumblr.com/post/178159241793/raspberrypi-wall-display-buildup" target="_blank" rel="noopener noreferrer nofollow ugc">framing process</a> which show some pics.</p>
<p dir="auto">This version of Wallberry is mostly a prototype held together with hope and electrical tape, so I don’t know how great a model it will be for you (others have done it much better with better tools), but it’s a fun example of doing a wall display with few resources.</p>
]]></description><link>https://forum.magicmirror.builders/post/58359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58359</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Sun, 30 Jun 2019 05:52:48 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Wed, 19 Jun 2019 13:46:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi. Great look.<br />
By any change you took pics while mounting?<br />
Looking for ideias for the frame and how to put all together and secure…<br />
thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/58075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58075</guid><dc:creator><![CDATA[pnobrega]]></dc:creator><pubDate>Wed, 19 Jun 2019 13:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 09 May 2019 21:39:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/william_wandie" aria-label="Profile: WILLIAM_WANDIE">@<bdi>WILLIAM_WANDIE</bdi></a> Thanks a ton :D</p>
]]></description><link>https://forum.magicmirror.builders/post/56885</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56885</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Thu, 09 May 2019 21:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 09 May 2019 07:44:02 GMT]]></title><description><![CDATA[<p dir="auto">This is really nice…</p>
]]></description><link>https://forum.magicmirror.builders/post/56851</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56851</guid><dc:creator><![CDATA[WILLIAM_WANDIE]]></dc:creator><pubDate>Thu, 09 May 2019 07:44:02 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Wed, 08 May 2019 01:52:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flodus" aria-label="Profile: flodus">@<bdi>flodus</bdi></a> thanks for the comments, sorry for the wait in reply :)</p>
<p dir="auto">I’m using the Weather Icons class names for the DarkSky API (formerly <a href="http://Forecast.io" target="_blank" rel="noopener noreferrer nofollow ugc">Forecast.io</a>), so you can add a CSS color rule for each of these icon classes (<a href="https://erikflowers.github.io/weather-icons/api-list.html" target="_blank" rel="noopener noreferrer nofollow ugc">this listed taken from the API here</a>):</p>
<pre><code>wi-forecast-io-clear-day: day-sunny
wi-forecast-io-clear-night: night-clear
wi-forecast-io-rain: rain
wi-forecast-io-snow: snow
wi-forecast-io-sleet: sleet
wi-forecast-io-wind: strong-wind
wi-forecast-io-fog: fog
wi-forecast-io-cloudy: cloudy
wi-forecast-io-partly-cloudy-day: day-cloudy
wi-forecast-io-partly-cloudy-night: night-cloudy
wi-forecast-io-hail: hail
wi-forecast-io-thunderstorm: thunderstorm
wi-forecast-io-tornado: tornado
<p dir="auto">So for example, if you wanted to change the sunny day icon color you would add the following rule to your custom.css file:</p>
<pre><code>.wi-forecast-io-clear-day {
  color: #ffff00;
<p dir="auto">If you want to target the <strong>forecast</strong> sunny day icon specifically you would add .forecast before the icon class name like this:</p>
<pre><code>.forecast .wi-forecast-io-clear-day {
  color: #ffff00;
<p dir="auto">And if you want to target the <strong>current day’s</strong> sunny day icon specifically you would add .current__temperature before the icon class name like this:</p>
<pre><code>.current__temperature .wi-forecast-io-clear-day {
  color: #ffff00;
<p dir="auto">Hope this helps!</p>
]]></description><link>https://forum.magicmirror.builders/post/56801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56801</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Wed, 08 May 2019 01:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Tue, 23 Apr 2019 09:17:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a><br />
thank you for this reminder :smiling_face_with_open_mouth_cold_sweat:<br />
i’ve edited my post !</p>
]]></description><link>https://forum.magicmirror.builders/post/56335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56335</guid><dc:creator><![CDATA[flodus]]></dc:creator><pubDate>Tue, 23 Apr 2019 09:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Tue, 23 Apr 2019 01:47:18 GMT]]></title><description><![CDATA[<p dir="auto">Please use the <a href="https://commonmark.org/help/" target="_blank" rel="noopener noreferrer nofollow ugc">markdown features of the board</a> when posting code.</p>
]]></description><link>https://forum.magicmirror.builders/post/56325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56325</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 23 Apr 2019 01:47:18 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Tue, 23 Apr 2019 09:16:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello !<br />
Your theme is so beautiful and minimalistic, i love that !<br />
I want to know how can I change css files to have colored icons for the current weather and forecast weather ?</p>
<p dir="auto">I use this custom.css code with the weather an forecast modules</p>
<pre><code>.currentweather .wi-sunrise {
color: #ffd700;
.currentweather .wi-sunset {
color: #ffa500;
.currentweather .wi-day-sunny {
color: #ffff00;
.currentweather .wi-night-showers {
color: #55acee;
.currentweather .wi-degrees {
color: #415;
.currentweather .wi-rain {
color: #55acee;
.currentweather .wi-showers {
color: #55acee;
color: #55acee;
.currentweather .wi-night-alt-cloudy-windy {
color: #aaa;
.currentweather .wi-night-cloudy {
color: #aaa;
.currentweather .wi-cloudy {
color: #aaa;
.currentweather .wi-day-cloudy {
color: #aaa;
color: #aaa;
.currentweather .wi-cloudy-windy {
color: #aaa;
color: #55acee;
.currentweather .wi-thunderstorm {
color: #ff00ff;
.currentweather .wi-snow {
color: #fff;
.currentweather .wi-fog {
color: #999;
.currentweather .wi-night-clear {
color: #fff;
.currentweather .wi-night-rain {
color: #55acee;
.currentweather .wi-night-thunderstorm {
color: #ff00ff;
.currentweather .wi-night-snow {
color: #fff;
.weatherforecast .wi-sunrise {
color: #ffd700;
.weatherforecast .wi-sunset {
color: #ffa500;
.weatherforecast .wi-day-sunny {
color: #ffff00;
.weatherforecast .wi-night-showers {
color: #55acee;
.weatherforecast .wi-degrees {
color: #415;
.weatherforecast .wi-rain {
color: #55acee;
.weatherforecast .wi-showers {
color: #55acee;
color: #55acee;
.weatherforecast .wi-night-alt-cloudy-windy {
color: #aaa;
.weatherforecast .wi-night-cloudy {
color: #aaa;
.weatherforecast .wi-cloudy {
color: #aaa;
.weatherforecast .wi-day-cloudy {
color: #aaa;
color: #aaa;
.weatherforecast .wi-cloudy-windy {
color: #aaa;
color: #55acee;
.weatherforecast .wi-thunderstorm {
color: #ff00ff;
.weatherforecast .wi-snow {
color: #fff;
.weatherforecast .wi-fog {
color: #999;
.weatherforecast .wi-night-clear {
color: #fff;
.weatherforecast .wi-night-rain {
color: #55acee;
.weatherforecast .wi-night-thunderstorm {
color: #ff00ff;
]]></description><link>https://forum.magicmirror.builders/post/56293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56293</guid><dc:creator><![CDATA[flodus]]></dc:creator><pubDate>Tue, 23 Apr 2019 09:16:31 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 06 Dec 2018 21:09:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/community" aria-label="Profile: community">@<bdi>community</bdi></a> I would like to recommend black&amp;white pictures or slidly darker pictures. Otherwise you will have some difficulties with the original font. The standard MM font throws shadows on light wallpapers.</p>
<p dir="auto">Kind regards from hamburg :)</p>
]]></description><link>https://forum.magicmirror.builders/post/47800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47800</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Thu, 06 Dec 2018 21:09:52 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 06 Dec 2018 21:04:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delightedcrow" aria-label="Profile: delightedCrow">@<bdi>delightedCrow</bdi></a>  seriously… this is the most awesome module I 've come across until now.</p>
<p dir="auto">I installed it this morning and it brings me so much joy.</p>
<p dir="auto">delightedCrow thank you very much for sharing this. It’s super cool :)</p>
]]></description><link>https://forum.magicmirror.builders/post/47799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47799</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Thu, 06 Dec 2018 21:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 06 Dec 2018 09:52:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delightedcrow" aria-label="Profile: delightedCrow">@<bdi>delightedCrow</bdi></a> Thank you for your fast response. :)<br />
I will try Method 1 as suggested.</p>
<p dir="auto">Seriously, this module enables you to have your own art gallery at home. How awesome is that?! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/47780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47780</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Thu, 06 Dec 2018 09:52:30 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 06 Dec 2018 00:41:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paulb" aria-label="Profile: paulb">@<bdi>paulb</bdi></a> Thanks for the kind comments!<br />
As for your question, there are two different ways I can think of to solve your question using the WallberryTheme:</p>
<h3>Method 1:</h3>
<p dir="auto">Create your own Unsplash collection and add all of the pictures of your village that you want displayed to this collection. Then all you have to do is add this Unsplash collection ID to the module config section for the WallberryTheme (<a href="https://github.com/delightedCrow/WallberryTheme#configuration-options" target="_blank" rel="noopener noreferrer nofollow ugc">see the module docs here for an example of how to set up the config file with collections</a>).</p>
<p dir="auto">Doing it this way means you’d have to curate your own photos instead of doing a keyword search, but you wouldn’t have to edit the WallberryTheme module code.</p>
<h3>Method 2:</h3>
<p dir="auto">Edit the WallberryTheme module code so that when it sends a photo request to Unsplash it uses the <a href="https://unsplash.com/documentation#get-a-random-photo" target="_blank" rel="noopener noreferrer nofollow ugc"><code>query</code> parameter</a> to filter random photos by your search term. So at about the <a href="https://github.com/delightedCrow/WallberryTheme/blob/63ed62acde126dd71669125ddbbea2dc0ca956c1/WallberryTheme.js#L53" target="_blank" rel="noopener noreferrer nofollow ugc">line of code here</a> you’d probably want to change it to something like: <code>"&amp;query=mysearchkeyword"</code> .</p>
<p dir="auto">I haven’t tested this method and the Unsplash docs are light on details, so you’d probably have to do some tinkering to figure out if it’ll work the way you want.</p>
<p dir="auto">Hope one of these helps :)</p>
]]></description><link>https://forum.magicmirror.builders/post/47764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47764</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Thu, 06 Dec 2018 00:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Wed, 05 Dec 2018 22:16:55 GMT]]></title><description><![CDATA[<p dir="auto">for the random, this routine from the MMM-ImagesPhotos module  is an example<br />
the images are in an array. the WallberryTheme gets one pic at a time from the server side…</p>
<pre><code>randomIndex: function(photos) {
		if (photos.length === 1) {
			return 0;
		var generate = function() {
			return Math.floor(Math.random() * photos.length);
		var photoIndex = generate();
		this.lastPhotoIndex = photoIndex;
		return photoIndex;
]]></description><link>https://forum.magicmirror.builders/post/47760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47760</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 05 Dec 2018 22:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Wed, 05 Dec 2018 22:09:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delightedcrow" aria-label="Profile: delightedCrow">@<bdi>delightedCrow</bdi></a>  I would really like to know how you got the API. The description is too hard to get for me… I guess.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/community" aria-label="Profile: Community">@<bdi>Community</bdi></a>: Do you guys have any idea?</p>
<p dir="auto">I am planning to show a collection of pictures from the keyword search of my village. Therefore I would really like to know how to implement the modules as well as configuring the module on how to show only images of a certain keyword.</p>
<p dir="auto">Hopefully someone can help. :)</p>
<p dir="auto">Kind regards from hamburg,</p>
<p dir="auto">Paul</p>
]]></description><link>https://forum.magicmirror.builders/post/47759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47759</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Wed, 05 Dec 2018 22:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Wed, 05 Dec 2018 20:46:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delightedcrow" aria-label="Profile: delightedCrow">@<bdi>delightedCrow</bdi></a>  It looks so incredible! Well done :)<br />
I will try that myself. It looks super cool :)</p>
<p dir="auto">Many greetings from hamburg,<br />
Paul</p>
]]></description><link>https://forum.magicmirror.builders/post/47758</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47758</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Wed, 05 Dec 2018 20:46:24 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Sat, 03 Nov 2018 22:11:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delightedcrow" aria-label="Profile: delightedcrow">@<bdi>delightedcrow</bdi></a> Thanks for the quick reply.<br />
I will send them an email to check how the random feature is implemented.</p>
]]></description><link>https://forum.magicmirror.builders/post/46265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46265</guid><dc:creator><![CDATA[rudibarani]]></dc:creator><pubDate>Sat, 03 Nov 2018 22:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Sat, 03 Nov 2018 21:55:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rudibarani" aria-label="Profile: rudibarani">@<bdi>rudibarani</bdi></a> I’m so glad you like it!<br />
I have noticed commonly recurring images with smaller collections, but I’m surprised it would happen so often in huge collections. When I get bored of seeing a certain collection sometimes I’ll leave the collections option blank so it pulls a random site-wide image and I don’t usually see any repeats that way, but maybe I just get lucky?</p>
<p dir="auto">I don’t see anywhere in the unsplash API docs about how it chooses the random images so there’s a good chance it isn’t truly random. I’ll keep an eye out though :D</p>
]]></description><link>https://forum.magicmirror.builders/post/46263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46263</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Sat, 03 Nov 2018 21:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Sat, 03 Nov 2018 19:53:50 GMT]]></title><description><![CDATA[<p dir="auto">Dear <a class="plugin-mentions-user plugin-mentions-a" href="/user/delightedcrow" aria-label="Profile: delightedcrow">@<bdi>delightedcrow</bdi></a>,</p>
<p dir="auto">thank you very much for this beautiful theme. I really like using WallberryTheme to beautify the background of my screen.<br />
What strikes me is that the images do not seem to be truly random. I have linked it up to a bigger collection and keep seeing the same images over and over although statistically, this should not be the case. Did you experienced this as well?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/46260</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46260</guid><dc:creator><![CDATA[rudibarani]]></dc:creator><pubDate>Sat, 03 Nov 2018 19:53:50 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 01 Nov 2018 22:52:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/philreis" aria-label="Profile: philreis">@<bdi>philreis</bdi></a> Thanks! The <a href="https://fonts.google.com/specimen/Rubik" target="_blank" rel="noopener noreferrer nofollow ugc">font is Rubik</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/46210</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46210</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Thu, 01 Nov 2018 22:52:09 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 01 Nov 2018 22:45:03 GMT]]></title><description><![CDATA[<p dir="auto">Nice Mirror!!<br />
Which Font do you use?</p>
]]></description><link>https://forum.magicmirror.builders/post/46209</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46209</guid><dc:creator><![CDATA[PhilReis]]></dc:creator><pubDate>Thu, 01 Nov 2018 22:45:03 GMT</pubDate></item><item><title><![CDATA[Reply to First MagicMirror on Thu, 01 Nov 2018 00:32:36 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!! I would LOVE to be able to embed a mirror in drywall (someday the dream will come true lol).</p>
<p dir="auto">Now that I know what to expect from framing and cable management I’d love to build a super slim version. I’ll be keeping an eye out for deals on laptop screens from now on I think :)</p>
]]></description><link>https://forum.magicmirror.builders/post/46171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46171</guid><dc:creator><![CDATA[delightedCrow]]></dc:creator><pubDate>Thu, 01 Nov 2018 00:32:36 GMT</pubDate></item></channel></rss>
