<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Auto populate events from MyCalendar to MyCommute?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’m playing around with a dashboard style setup. I’m using MyCalendar and MyCommute (both great modules - thanks J.E.F.F.) and trying to work out how to use MyCalendar’s event broadcast feature to send that information to MyCommute so it can automattically add new ‘commute events’ so I don’t have to go into config.js for one-off events.</p>
<p dir="auto"><img src="/assets/uploads/files/1541116734652-mirror.png" alt="0_1541116725914_Mirror.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Is this possible to do?</p>
<p dir="auto">Thanks in advance.</p>
<p dir="auto">Mark.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9016/auto-populate-events-from-mycalendar-to-mycommute</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 11:47:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9016.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Nov 2018 23:58:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Auto populate events from MyCalendar to MyCommute? on Mon, 12 Nov 2018 10:43:55 GMT]]></title><description><![CDATA[<p dir="auto">So it seems that this already exists with <a href="https://github.com/RedNax67/MMM-TrafficCal" target="_blank" rel="noopener noreferrer nofollow ugc">this module</a>. Forum thread <a href="https://forum.magicmirror.builders/topic/831/mmm-trafficcal-dynamically-display-commutes-based-on-calendar-entries">here</a>.</p>
<p dir="auto">However I can’t get it to work. Have configured everything correctly. Have MMM-Notifications showing my calendar is broadcasting events and tested with a couple different ‘trip keys’.</p>
<p dir="auto">Anyone else get it working?</p>
<p dir="auto">Edit - TrafficCal also seems to break the calendar modules (both default calendar and MMM-MyCalendar).</p>
]]></description><link>https://forum.magicmirror.builders/post/46649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46649</guid><dc:creator><![CDATA[krouton]]></dc:creator><pubDate>Mon, 12 Nov 2018 10:43:55 GMT</pubDate></item><item><title><![CDATA[Reply to Auto populate events from MyCalendar to MyCommute? on Fri, 02 Nov 2018 21:59:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/groops" aria-label="Profile: groops">@<bdi>groops</bdi></a></p>
<p dir="auto">A ‘Google Free API’?</p>
<p dir="auto">You mean a free API from Google?</p>
<p dir="auto">Then, yes.</p>
]]></description><link>https://forum.magicmirror.builders/post/46236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46236</guid><dc:creator><![CDATA[krouton]]></dc:creator><pubDate>Fri, 02 Nov 2018 21:59:50 GMT</pubDate></item><item><title><![CDATA[Reply to Auto populate events from MyCalendar to MyCommute? on Fri, 02 Nov 2018 12:53:04 GMT]]></title><description><![CDATA[<p dir="auto">That’s a great idea. I’d roughly propose the following workflow:</p>
<ul>
<li>MyCalendar sends a notification with an array of events with defined addresses in the payload</li>
<li>My Commute displays next 1/2/3 events (configurable)</li>
<li>in the config you should be able to configure which travel modes you want to have displayed (transport, driving, walking,…). Maybe even with thresholds (walking &lt;2km, transport: &gt;1km, &lt;10km, driving &gt;8km, …)</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/46219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46219</guid><dc:creator><![CDATA[Aries1984]]></dc:creator><pubDate>Fri, 02 Nov 2018 12:53:04 GMT</pubDate></item><item><title><![CDATA[Reply to Auto populate events from MyCalendar to MyCommute? on Fri, 02 Nov 2018 08:11:24 GMT]]></title><description><![CDATA[<p dir="auto">You have a Google Free API?</p>
]]></description><link>https://forum.magicmirror.builders/post/46215</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46215</guid><dc:creator><![CDATA[Groops]]></dc:creator><pubDate>Fri, 02 Nov 2018 08:11:24 GMT</pubDate></item></channel></rss>
