<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] Standard calendar displays the time incorrectly]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I have an problem with the standard calendar.</p>
<p dir="auto">The calendar should show only the beginning times of the appointments. But the calendar shows the beginning and end time of the appointments.</p>
<p dir="auto">I configured my calendar like this</p>
<pre><code>{^M
                        module: 'calendar',^M
                        header: 'Kalender',^M
                        position: 'top_left',^M
                        config: {^M
                                timeFormat: 'absolute', ^M
                                urgency: 0,^M
                                maxTitleLength: 15,
                                dateFormat: "dd, DD. MMM HH:mm",
                                fullDayEventDateFormat: "dd, DD MMM",
                                getRelative: 0, ^M
                                calendars: [^M
                                        {^M
                                                symbol: 'calendar-check-o ',^M
                                                url: 'https://calendar.google.com/calendar/ical/XXXXXXXX.ics'^M
                                        },^M
                                        {^M
                                        url: 'https://calendar.google.com/calendar/ical/XXXXXXXXXX.ics'^M
                                        }^M
<p dir="auto">I would be very grateful if someone could help me.</p>
<p dir="auto">Thank you in advance.</p>
<p dir="auto">Lars</p>
]]></description><link>https://forum.magicmirror.builders/topic/9041/solved-standard-calendar-displays-the-time-incorrectly</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 15:43:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9041.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Nov 2018 08:01:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] Standard calendar displays the time incorrectly on Tue, 06 Nov 2018 14:11:20 GMT]]></title><description><![CDATA[<p dir="auto">Yes, that´s it.</p>
<p dir="auto">Thank your for this great tip.</p>
]]></description><link>https://forum.magicmirror.builders/post/46375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46375</guid><dc:creator><![CDATA[Klinge]]></dc:creator><pubDate>Tue, 06 Nov 2018 14:11:20 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] Standard calendar displays the time incorrectly on Tue, 06 Nov 2018 12:32:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello! in config write ‘showEnd: false’. see this link: <a href="https://forum.magicmirror.builders/topic/8856/calendar-module-1-day-error">https://forum.magicmirror.builders/topic/8856/calendar-module-1-day-error</a>. Hope it helps you. Nisse</p>
]]></description><link>https://forum.magicmirror.builders/post/46370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46370</guid><dc:creator><![CDATA[Nilnik]]></dc:creator><pubDate>Tue, 06 Nov 2018 12:32:03 GMT</pubDate></item></channel></rss>
