<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Strange issue]]></title><description><![CDATA[<p dir="auto">Hi all i have my magic mirror running “flawlessly” with all my modules arranged nicely ready for final hardware install.<br />
I have been leaving it running on my Rpi and monitor for a while before the whole final, on the wall install but something strange is happening … I have pm 2 running and MMM-watchdog and all seems to be going perfect until MM gets abruptly restarted and it happens quite often.</p>
<p dir="auto">Where can i look for errors on what’s been causing this??.. also can i change any setting somewhere whether on pm2 or watchdog so it can be more “tolerating” and “forgiving”??</p>
<p dir="auto">Any help will be greatly appreciated<br />
Thank you<br />
Denis</p>
]]></description><link>https://forum.magicmirror.builders/topic/9069/strange-issue</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 21:33:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9069.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Nov 2018 05:11:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Strange issue on Mon, 19 Nov 2018 22:07:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a><br />
Unless someone tells different, from my point of view you do not have any CPU or memory issues.<br />
In fact, it makes me wonder why I am seeing the electron.js processes so high in my output.</p>
<p dir="auto">I do not use MMM-watchdog and I do not know exactly what it is doing.<br />
Do not know what it is pinging, but something on your MM makes it time out and as a cause it restarts mm.<br />
The log only tells you that it failed, but not what exactly failed.<br />
Would be nice to know how you can send this ping manually, then you can observe the behavior yourself.</p>
<p dir="auto">I take it, that you have your monitor connected to your Pi.<br />
So MM not running as server only and the display not on a client.</p>
<p dir="auto">Anyway, good to hear that you potentially have found the issue and you learned a bit of Linux on the side.</p>
]]></description><link>https://forum.magicmirror.builders/post/47043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47043</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Mon, 19 Nov 2018 22:07:16 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Mon, 19 Nov 2018 05:17:42 GMT]]></title><description><![CDATA[<p dir="auto">Its holding better i haven’t seen it restart in the past few hours i think MMM-watchdog was the problem</p>
]]></description><link>https://forum.magicmirror.builders/post/47000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47000</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Mon, 19 Nov 2018 05:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Mon, 19 Nov 2018 01:31:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> here is the rest of the commands you asked me to do :)</p>
<pre><code>pi@SmartMirror:~ $ uname -a
Linux SmartMirror 4.14.52-v7+ #1123 SMP Wed Jun 27 17:35:49 BST 2018 armv7l GNU/Linux
pi@SmartMirror:~ $ swapon -s
Filename				Type		Size	Used	Priority
/dev/zram0                             	partition	237360	15596	5
/dev/zram1                             	partition	237360	15636	5
/dev/zram2                             	partition	237360	15612	5
/dev/zram3                             	partition	237360	15364	5
pi@SmartMirror:~ $  free -h
              total        used        free      shared  buff/cache   available
Mem:           927M        135M        166M         16M        624M        718M
Swap:          927M         60M        866M
pi@SmartMirror:~ $ cat /etc/dphys-swapfile | egrep -v ‘#|^$’
bash: ^$’: command not found
pi@SmartMirror:~ $ sudo service dphys-swapfile status
● dphys-swapfile.service - LSB: Autogenerate and use a swap file
   Loaded: loaded (/etc/init.d/dphys-swapfile; generated; vendor preset: enabled
   Active: active (exited) since Sun 2018-11-18 17:49:07 CST; 1h 36min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 358 ExecStart=/etc/init.d/dphys-swapfile start (code=exited, status=0
   CGroup: /system.slice/dphys-swapfile.service
Nov 18 17:49:06 SmartMirror systemd[1]: Starting LSB: Autogenerate and use a swa
Nov 18 17:49:06 SmartMirror dphys-swapfile[358]: Starting dphys-swapfile swapfil
Nov 18 17:49:07 SmartMirror dphys-swapfile[358]: want /var/swap=100MByte, checki
Nov 18 17:49:07 SmartMirror dphys-swapfile[358]: done.
Nov 18 17:49:07 SmartMirror systemd[1]: Started LSB: Autogenerate and use a swap
lines 1-12/12 (END)
<p dir="auto">And on the top.txt file neither the first 50 nor the last 50 are not saying much about magic mirror but i am going to start it again and tail top.txt again once it crashes.</p>
<p dir="auto">Here is the output any how for the first and last 50 lines of the top.txt  file</p>
<pre><code>pi@SmartMirror:~ $ tail -50 top.txt
  848 pi        20   0   27796   8972   8052 S   0.0  0.9   0:01.61 vncserverui
  809 pi        20   0   42752   8256   8116 S   0.0  0.9   0:00.09 lxpolkit
  890 pi        20   0   74324   7768   7596 S   0.0  0.8   0:00.15 gvfs-udisk+
Sun Nov 18 19:25:01 CST 2018
top - 19:25:01 up  1:25,  1 user,  load average: 0.39, 0.39, 0.37
Tasks: 134 total,   1 running,  88 sleeping,   0 stopped,   1 zombie
%Cpu(s): 12.5 us,  1.5 sy,  0.0 ni, 85.3 id,  0.3 wa,  0.0 hi,  0.3 si,  0.0 st
KiB Mem :   949452 total,   169780 free,   140140 used,   639532 buff/cache
KiB Swap:   949440 total,   887232 free,    62208 used.   734220 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
  553 root      20   0  214532  54136  35564 S   0.0  5.7   3:10.64 Xorg
  719 pi        20   0  120620  28044  15252 S   0.0  3.0   0:06.59 PM2 v3.0.3+
  814 pi        20   0  144716  27976  24560 S   0.0  2.9   0:12.95 pcmanfm
  455 alexapi   20   0  191228  27236  13820 S   5.6  2.9  21:37.81 python
  481 root      20   0   45136  22548  13788 S   0.0  2.4   3:25.82 vncserver-+
 1840 pi        20   0   77044  21280  18496 S   0.0  2.2   0:08.20 leafpad
  812 pi        20   0  138632  20484  18116 S   0.0  2.2   0:21.17 lxpanel
 1656 pi        20   0   49308  20328  16408 S   0.0  2.1   0:40.59 lxterminal
  868 pi        20   0   27820  14160  12840 S   0.0  1.5   0:00.35 vncserverui
  806 pi        20   0   53684  13080  10916 S   0.0  1.4   0:02.33 openbox
  557 root      20   0   15416  10640  10312 S   5.6  1.1   0:29.86 vncagent
  673 pi        20   0   52180  10472  10140 S   0.0  1.1   0:00.85 lxsession
KiB Mem :   949452 total,   170032 free,   139888 used,   639532 buff/cache
KiB Swap:   949440 total,   887232 free,    62208 used.   734472 avail Mem
  814 pi        20   0  144716  27976  24560 S   0.0  2.9   0:12.96 pcmanfm
  455 alexapi   20   0  191228  27236  13820 S   0.0  2.9  21:37.81 python
  557 root      20   0   15416  10640  10312 S   0.0  1.1   0:29.86 vncagent
pi@SmartMirror:~ $ head -50 top.txt
Fri Nov 16 22:55:01 CST 2018
top - 22:55:02 up 3 days,  2:58,  1 user,  load average: 0.18, 0.31, 0.21
Tasks: 132 total,   1 running,  88 sleeping,   0 stopped,   1 zombie
%Cpu(s): 18.3 us,  4.2 sy,  0.0 ni, 74.3 id,  2.0 wa,  0.0 hi,  1.2 si,  0.0 st
KiB Mem :   949452 total,   276412 free,   169288 used,   503752 buff/cache
KiB Swap:   949440 total,   825760 free,   123680 used.   687104 avail Mem
  582 root      20   0  219092  34684  17284 S   0.0  3.7 302:37.78 Xorg
  457 alexapi   20   0  210684  27312  13416 S   0.0  2.9 799:59.04 python
  834 pi        20   0  152648  26352  11692 S   0.0  2.8  19:11.56 lxpanel
  502 root      20   0   45188  23764  14620 S   0.0  2.5  26:30.86 vncserver-+
  835 pi        20   0  154056  17252  14084 S   0.0  1.8   0:33.17 pcmanfm
  721 pi        20   0  127960  16648   7700 S   0.0  1.8   6:21.25 PM2 v3.0.3+
 2011 pi        20   0   48208  12352  10328 S   0.0  1.3   0:10.66 lxterminal
  100 root      20   0   35220   9068   8840 S   0.0  1.0   2:10.19 systemd-jo+
  636 root      20   0   15416   9048   8840 S   0.0  1.0   3:51.37 vncagent
  829 pi        20   0   53536   6128   4664 S   0.0  0.6   0:09.74 openbox
  953 pi        20   0   27236   4904   4428 S   0.0  0.5   0:02.30 vncserverui
  873 pi        20   0   27816   4280   3616 S   0.0  0.5   0:32.84 vncserverui
    1 root      20   0   27024   3680   2972 S   0.0  0.4   0:12.38 systemd
  598 root      20   0    7272   3464   3192 S   0.0  0.4   0:01.09 bluetoothd
  979 raspoti+  20   0   18924   3432   3036 S   0.0  0.4   1:10.74 librespot
KiB Mem :   949452 total,   276684 free,   168980 used,   503788 buff/cache
KiB Swap:   949440 total,   825760 free,   123680 used.   687416 avail Mem
  457 alexapi   20   0  210684  27312  13416 S   5.9  2.9 799:59.05 python
  835 pi        20   0  154056  17252  14084 S   0.0  1.8   0:33.18 pcmanfm
Fri Nov 16 23:00:01 CST 2018
top - 23:00:01 up 3 days,  3:03,  1 user,  load average: 3.02, 1.49, 0.69
Tasks: 138 total,   4 running,  91 sleeping,   0 stopped,   1 zombie
%Cpu(s): 18.4 us,  4.2 sy,  0.0 ni, 74.3 id,  2.0 wa,  0.0 hi,  1.2 si,  0.0 st
<p dir="auto">Thank you<br />
D</p>
]]></description><link>https://forum.magicmirror.builders/post/46987</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46987</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Mon, 19 Nov 2018 01:31:14 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Mon, 19 Nov 2018 00:47:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> I appologise on the delay at answering i was at work during the weekend</p>
<p dir="auto">here is the autput from</p>
<pre><code>pi@MagicPi:~ $ grep -i watchdog /home/pi/.pm2/logs/mm-out.log
pi@MagicPi:~ $ grep -i watchdog /home/pi/.pm2/logs/mm-error.log
<p dir="auto">a bunch of these almost every 10-15 minutes</p>
<pre><code>Fri Nov 09 2018 09:52:50 GMT-0600 (CST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
Fri Nov 09 2018 10:06:24 GMT-0600 (CST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
<pre><code>WatchDog started. Maximum timeout: 20s.
Module helper loaded: MMM-WatchDog
Connecting socket for: MMM-WatchDog
Starting module helper: MMM-WatchDog
<p dir="auto">Here is some sysstat output from the following commands</p>
<pre><code>vmstat 10 10
iostat 10 10
sar 10 10
<pre><code>r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
 1  0  63744 209036  34364 567792    0    6    82    12  778  312 18  3 78  1  0
 0  0  63744 209036  34372 567824    0    0     0     2 2431  278  4  0 96  0  0
<pre><code>avg-cpu:  %user   %nice %system %iowait  %steal   %idle
          17.75    0.00    3.32    0.57    0.00   78.36
Device:            tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
mmcblk0          13.75       311.58        45.87     821628     120969
zram0             1.77         0.95         6.13       2504      16164
zram1             1.73         0.78         6.12       2068      16132
zram2             1.70         0.74         6.08       1952      16028
zram3             1.74         0.94         6.02       2480      15880
<pre><code>06:44:46 PM     all      3.17      0.00      0.08      0.00      0.00     96.76
06:44:56 PM     all      4.12      0.00      0.25      0.03      0.00     95.60
]]></description><link>https://forum.magicmirror.builders/post/46986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46986</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Mon, 19 Nov 2018 00:47:38 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sun, 18 Nov 2018 02:18:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a> The BIGGEST problem that nobody either wants to admit or doesn’t realize is that the pi wasn’t made to be pounded on this hard.</p>
<p dir="auto">It’s a simple computer…when you start adding constant pulls for data and scrolling text, etc it over heats and overloads the pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/46931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46931</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 18 Nov 2018 02:18:31 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 20:14:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a><br />
Concerning your top.txt, was that the output on the moment that MM was restarted ?<br />
I do not see obvious memory issues.<br />
Only that vncserver and python are CPU hungry, but within limits.<br />
And I do not see any electron processes.</p>
]]></description><link>https://forum.magicmirror.builders/post/46922</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46922</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 17 Nov 2018 20:14:07 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 20:07:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a><br />
On pm2 and restarting I cannot say many.<br />
On using ctrl+q neither, as I only access my MM via ssh.</p>
<p dir="auto">Can you send the output of the following commands:</p>
<p dir="auto">$ uname -a<br />
$ swapon -s<br />
$ free -h<br />
$ cat /etc/dphys-swapfile | egrep -v ‘#|^$’<br />
$ sudo service dphys-swapfile status</p>
<p dir="auto">I just learned that swap is handled as a service.<br />
Being old-school, this is something new to me :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/46921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46921</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 17 Nov 2018 20:07:27 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 19:45:28 GMT]]></title><description><![CDATA[<p dir="auto">To disable MMM-WatchDog, edit the config.js file.<br />
Locate:</p>
<pre><code>module: 'MMM-WatchDog',
<p dir="auto">Edit this like this:</p>
disabled: true,
<p dir="auto">and restart MM:</p>
<pre><code>$ pm2 restart mm
<p dir="auto">Use</p>
<pre><code>pm2 list
<p dir="auto">to check if your application name actually is mm, or something else.</p>
<p dir="auto">Later you can enable it again by updating config.js like this:</p>
<pre><code>disabled: false,
<p dir="auto">This works for all modules.<br />
When I test modules I normally leave the config lines and disable a module in this fashion.</p>
]]></description><link>https://forum.magicmirror.builders/post/46920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46920</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 17 Nov 2018 19:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 19:38:28 GMT]]></title><description><![CDATA[<p dir="auto">Okay, this calls for some more basics.</p>
<p dir="auto">Print the whole file:<br />
$ cat top.txt</p>
<p dir="auto">Load the file in an editor:<br />
$ nano top.txt<br />
$ vi top.txt</p>
<p dir="auto">I am old-school, so I use vi, but nano is more Word-like.</p>
<p dir="auto">To show the last 50 lines:<br />
$ tail -50 top.txt</p>
<p dir="auto">To show the first 50 lines:<br />
$ head -50 top.txt</p>
<p dir="auto">Where of course 50 is just an example.</p>
<p dir="auto">To show text that is appending:<br />
$ tail -f top.txt</p>
<p dir="auto">To show text that is appending and re-open the file when necessary (useful for rotating log files):<br />
$ tail -F top.txt</p>
<p dir="auto">On disabling a module see the next reply.</p>
]]></description><link>https://forum.magicmirror.builders/post/46919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46919</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 17 Nov 2018 19:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 17:34:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> Ok so here is whats writen on that top.txt file</p>
<pre><code>pi@SmartMirror:~ $ tail -F top.txt
  834 pi        20   0  155396  17884   8104 S   0.0  1.9  23:20.77 lxpanel
  582 root      20   0  211836  13576   2440 S   0.0  1.4 418:48.14 Xorg
  457 alexapi   20   0  218108  10768   4772 S  47.4  1.1 878:20.67 python
  721 pi        20   0  122032  10600   4792 S   0.0  1.1   8:34.40 PM2 v3.0.3+
  835 pi        20   0  154056   5184   4016 S   0.0  0.5   0:43.57 pcmanfm
18753 pi        20   0   47692   4896   3996 S   0.0  0.5   0:03.94 lxterminal
  829 pi        20   0   53536   4432   3556 S   0.0  0.5   0:13.22 openbox
  100 root      20   0   35220   3140   2980 S   0.0  0.3   2:16.35 systemd-jo+
 7236 pi        20   0    8112   3140   2712 R  15.8  0.3   0:00.07 top
Sat Nov 17 11:25:01 CST 2018
top - 11:25:01 up 3 days, 15:28,  1 user,  load average: 0.56, 2.88, 4.35
Tasks: 135 total,   1 running,  89 sleeping,   0 stopped,   1 zombie
%Cpu(s): 21.4 us,  5.5 sy,  0.0 ni, 69.4 id,  2.3 wa,  0.0 hi,  1.5 si,  0.0 st
KiB Mem :   949452 total,   493928 free,   157456 used,   298068 buff/cache
KiB Swap:   949440 total,   777124 free,   172316 used.   727276 avail Mem
  582 root      20   0  218840  24540  12364 S  10.5  2.6 419:19.31 Xorg
  502 root      20   0   45188  23400  14452 S  36.8  2.5  27:20.07 vncserver-+
  834 pi        20   0  155396  21680  10616 S   0.0  2.3  23:23.35 lxpanel
 7558 pi        20   0   77052  21140  18404 S   0.0  2.2   0:03.37 leafpad
  835 pi        20   0  154156  16420  13232 S   0.0  1.7   0:46.57 pcmanfm
  721 pi        20   0  122032  14004   7360 S   0.0  1.5   8:34.81 PM2 v3.0.3+
  457 alexapi   20   0  218108  10772   4772 S  36.8  1.1 880:07.93 python
  636 root      20   0   15416   9020   8820 S   0.0  1.0   3:55.73 vncagent
18753 pi        20   0   47692   8484   7164 S   0.0  0.9   0:04.22 lxterminal
  829 pi        20   0   53724   5888   4220 S   0.0  0.6   0:13.49 openbox
  953 pi        20   0   27236   5312   4812 S   0.0  0.6   0:03.05 vncserverui
  873 pi        20   0   27816   4328   3676 S   0.0  0.5   0:40.96 vncserverui
  804 pi        20   0   39468   3288   3000 S   0.0  0.3   0:02.79 gvfsd
  100 root      20   0   35220   3196   3036 S   0.0  0.3   2:16.50 systemd-jo+
 7603 pi        20   0    8112   3180   2752 R  10.5  0.3   0:00.05 top
KiB Mem :   949452 total,   493776 free,   157600 used,   298076 buff/cache
KiB Swap:   949440 total,   777124 free,   172316 used.   727128 avail Mem
  582 root      20   0  218840  24540  12364 S  11.1  2.6 419:19.33 Xorg
  502 root      20   0   45188  23400  14452 S  50.0  2.5  27:20.16 vncserver-+
  834 pi        20   0  155396  21680  10616 S   0.0  2.3  23:23.36 lxpanel
  457 alexapi   20   0  218108  10772   4772 S  61.1  1.1 880:08.05 python
18753 pi        20   0   47692   8484   7164 S   0.0  0.9   0:04.24 lxterminal
 7608 pi        20   0    8112   3180   2752 R  22.2  0.3   0:00.07 top
<p dir="auto">I use the command</p>
<pre><code>tail -F top.txt
<p dir="auto">right?? i dont know how to read the above file so let me know if you see anything strange …i have increased the swap file to install opencv a while back for facial recognition to install rapidly but i do not use a usb …i could if i have to.</p>
<p dir="auto">As far as taking out the watchdog…commenting it out of the config.js should do the trick or do i have to uninstall it form the modules??</p>
<p dir="auto">Will pm2 still restart the MM if it crashes without the watchdog (it does if you do ctrl+q) ??</p>
<p dir="auto">D</p>
]]></description><link>https://forum.magicmirror.builders/post/46916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46916</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Sat, 17 Nov 2018 17:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 11:22:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a><br />
I re-read your first post and your problem is more restarting then actual crashing.<br />
Of course a restart can be caused by a crash …<br />
MMM-WatchDog tends to restart MM, so I too would suggest to remove this module.<br />
In principle all it does is sending a ping and restarting MM using pm2 when a timeout occurs.<br />
I also would expect to see some lines in the pm2 logs on WatchDog.<br />
Can you do ?:</p>
<p dir="auto">What is alo a good package to install is sysstat:</p>
<pre><code>pi@MagicPi:~ $ sudo apt-get install sysstat
<p dir="auto">This allows for commands like iostat and sar.</p>
iostat 10 10
sar 10 10
]]></description><link>https://forum.magicmirror.builders/post/46891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46891</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 17 Nov 2018 11:22:34 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Sat, 17 Nov 2018 03:56:47 GMT]]></title><description><![CDATA[<p dir="auto">If previous suggestions dont help, try removing the MMM-WatchDog module and see if it crashes anymore.</p>
]]></description><link>https://forum.magicmirror.builders/post/46882</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46882</guid><dc:creator><![CDATA[vinp]]></dc:creator><pubDate>Sat, 17 Nov 2018 03:56:47 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Fri, 16 Nov 2018 20:25:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> Mine is not slow it works “fine” it just keeps restarting<br />
I am really curious to see the output of that file and see whats causing this behavior<br />
D</p>
]]></description><link>https://forum.magicmirror.builders/post/46871</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46871</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Fri, 16 Nov 2018 20:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Fri, 16 Nov 2018 20:21:50 GMT]]></title><description><![CDATA[<p dir="auto">Ha ha, not that great, my MM is as slow as a turtle again.<br />
The used swap on my USB stick in the meanwhile is 1GB.<br />
Cannot use any commands to investigate further.<br />
Not very satisfactory. :frowning_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/46870</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46870</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 16 Nov 2018 20:21:50 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Fri, 16 Nov 2018 20:12:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> Ahhh you are a great man<br />
I will set it up as soon as i get home<br />
thanks in advance<br />
Denis</p>
]]></description><link>https://forum.magicmirror.builders/post/46869</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46869</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Fri, 16 Nov 2018 20:12:25 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Fri, 16 Nov 2018 20:05:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a></p>
<p dir="auto">Then let’s give it a try :slightly_smiling_face:</p>
<p dir="auto">First create the script:</p>
<pre><code>pi@MagicPi:~ $ cd
pi@MagicPi:~ $ nano top.sh
<p dir="auto">Copy-paste this:</p>
<pre><code>!/bin/sh
date &gt;&gt; /home/pi/top.txt
top -b -o +%MEM | head -n 22 &gt;&gt; /home/pi/top.txt
echo "=============================================" &gt;&gt; /home/pi/top.txt
<p dir="auto">Make it executable:</p>
<pre><code>pi@MagicPi:~ $ chmod 755 top.sh
<p dir="auto">Perhaps a good idea to prepare the output file in order to be sure the cron user can write in it:</p>
<pre><code>pi@MagicPi:~ $ touch /home/pi/top.txt
pi@MagicPi:~ $ chmod 666 /home/pi/top.txt
<p dir="auto">Now we add a cronjob:</p>
<pre><code>pi@MagicPi:~ $ crontab -e
<p dir="auto">Add this line at the end:</p>
<pre><code>00,05,10,15,20,25,30,35,40,45,50,55 * * * * /home/pi/top.sh &gt;/dev/null 2&gt;&amp;1
<p dir="auto">To verify:</p>
<pre><code>pi@MagicPi:~ $ crontab -l
<p dir="auto">To verify if the cronjob is actually running:</p>
<pre><code>pi@MagicPi:~ $ tail -F /var/log/syslog
<p dir="auto">To check if something comes in your output file:</p>
<pre><code>pi@MagicPi:~ $ tail -F top.txt
<p dir="auto">The script will run every 5 minutes, every hour, every day.<br />
It will output the top 15 MEMory usage and the top 15 CPU usage.</p>
<p dir="auto">In your case, it will be interesting to look at the last entries before the crash.<br />
Need to identify first if it is an CPU or MEM issue, or both.<br />
Then we can modify the script.</p>
<p dir="auto">Please do not post lengthy output.<br />
Better we minimise the output by grepping and sorting, etc.</p>
<p dir="auto">Success!</p>
]]></description><link>https://forum.magicmirror.builders/post/46868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46868</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 16 Nov 2018 20:05:54 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Fri, 16 Nov 2018 18:58:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> Hahah dont’ worry about coming out the wrong way … i know a little bit and i do know what nano and vi does …i use nano.<br />
I am not familiar with cats and tails etc but i am a fast learner and i have set up quite a bit of MM modules some stubborn ones as well but i am no expert by all means.</p>
<p dir="auto">I couldn’t read your first response at the beginning for some reason it wasn’t structured properly or my browser wasn’t reading it right now its a bit better but i still need some guidance</p>
<p dir="auto">So i need to set up a script called “top” and make it executable right??<br />
Than i have no idea what to do with cron :) !!!</p>
<p dir="auto">Lets start somewhere :)</p>
<p dir="auto">Denis</p>
]]></description><link>https://forum.magicmirror.builders/post/46867</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46867</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Fri, 16 Nov 2018 18:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Thu, 15 Nov 2018 16:19:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a><br />
Since you managed to setup MM to the point that it is running, but crashing, I take it you know a little bit of Linux.<br />
Otherwise it will be more like a Linux workshop.</p>
<p dir="auto">Do you know how to use nano and/or vi to edit files?<br />
Know what for example cat,  tail and head does?<br />
Just some Linux basics.</p>
<p dir="auto">I do not want to sound like a smartarse and knowitall, am a hobbyist just like you.<br />
Just to know the level of describing that is needed.</p>
]]></description><link>https://forum.magicmirror.builders/post/46807</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46807</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Thu, 15 Nov 2018 16:19:44 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Thu, 15 Nov 2018 05:15:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> Thank you for your reply and i want to try all that you have written as i really feel it may help my case … but i am having a hard time decoding your steps.</p>
<p dir="auto">Please walk me through it, on a step by step all the way to the end on how to even increase the swap file, and what to put on my scrip and make it executable and what is a cron job?? that will be my first one actually :)</p>
]]></description><link>https://forum.magicmirror.builders/post/46780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46780</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Thu, 15 Nov 2018 05:15:23 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Thu, 15 Nov 2018 14:15:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Investigating crashes and freezes, etc, can be very difficult.<br />
When everything is running fine and you collect data, you will see that everything is more or less okay.<br />
When it crashed or is frozen, you are too late.</p>
<p dir="auto">Since a few weeks I had the problem that my MM was frozen and I could not enter any commands or a command took painstakingly long to return output.<br />
A command like top was out of the question for example.<br />
Using a script running as a cron job, I was able to identify a memory issue with electron.js.<br />
I then decide to use a usb stick on which I created a swap device.<br />
Since then my MM is not freezing anymore.<br />
And I am able to see electron.js using up my memory and sometimes I see spikes in CPU usage.</p>
<p dir="auto">Mind you, that crashing is something different then freezing, but the tools to use are more or less the same, provided the MM application or a MM module is not the culprit.</p>
<p dir="auto">My script to check memory usage, very basic and simple:</p>
<pre><code>pi@MagicPi:~ $ cat top.sh
#!/bin/sh
<p dir="auto">The cron job:</p>
<p dir="auto">%CPU will sort on CPU usage.</p>
<p dir="auto">Concerning swap space, top will show the usage, but this gives a quick view:</p>
<pre><code>$ free -h
<p dir="auto">Swap details via:</p>
<pre><code>$ swapon -s
<p dir="auto">There are many more commands and settings to look at, but one has to start somewhere :-)</p>
<p dir="auto">Good luck.</p>
]]></description><link>https://forum.magicmirror.builders/post/46760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46760</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Thu, 15 Nov 2018 14:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Wed, 14 Nov 2018 13:13:19 GMT]]></title><description><![CDATA[<p dir="auto">Incrase the swapfile?</p>
]]></description><link>https://forum.magicmirror.builders/post/46742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46742</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Wed, 14 Nov 2018 13:13:19 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Wed, 14 Nov 2018 05:46:57 GMT]]></title><description><![CDATA[<p dir="auto">Please some help!!! anybody!!<br />
Where and how do i check for errors and whats casuing them and what module is the hardest and most tasking.<br />
The strange thing is that my cpu usage is never more than 30%  with 10 -20 % of free ram at all times!!</p>
<p dir="auto">D</p>
]]></description><link>https://forum.magicmirror.builders/post/46736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46736</guid><dc:creator><![CDATA[richland007]]></dc:creator><pubDate>Wed, 14 Nov 2018 05:46:57 GMT</pubDate></item><item><title><![CDATA[Reply to Strange issue on Mon, 12 Nov 2018 06:36:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richland007" aria-label="Profile: richland007">@<bdi>richland007</bdi></a></p>
<p dir="auto">Hey mate!</p>
<p dir="auto">Same issue here. I might suspect that the pi gets overloaded somehow. If I run less modules it’s not restarting.</p>
<p dir="auto">I’m going to try a Intel NUC see what’s happening</p>
]]></description><link>https://forum.magicmirror.builders/post/46644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46644</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Mon, 12 Nov 2018 06:36:03 GMT</pubDate></item></channel></rss>
