<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ubuntu and magicmirror]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">I have lates ubuntu on intel NUC maschine. could someone please help me installing magicmirror. Getting allot of errors when I try to install. How do I start? and what do I need?</p>
<p dir="auto">git<br />
curl<br />
nodejs</p>
<p dir="auto">how do I install electron?</p>
<p dir="auto">regards K</p>
]]></description><link>https://forum.magicmirror.builders/topic/9085/ubuntu-and-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 20:20:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9085.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Nov 2018 20:24:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ubuntu and magicmirror on Tue, 13 Nov 2018 01:31:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a></p>
<p dir="auto">I use ubuntu 16.04 LTS exclusively. I wipe the machine so that there is nothing on it except ubuntu. I fully update ubuntu and then install node like this:</p>
<p dir="auto"><code>curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -</code></p>
<p dir="auto">The OS should ask you if you want to install curl at this point. Do so. If you have to repeat the curl command above, do so. Now on to the installation of MM.</p>
<p dir="auto">I like to do manual installations, meaning, I download the MM zip file instead of using the install command. I drag the MM folder to home and remove the “-master” from the name of the folder, leaving only MagicMirror as the name. Then, in the terminal, <code>cd MagicMirror</code> and then <code>npm install</code></p>
<p dir="auto">I’ve never had a problem doing it this way. Good luck.</p>
]]></description><link>https://forum.magicmirror.builders/post/46693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46693</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 13 Nov 2018 01:31:23 GMT</pubDate></item><item><title><![CDATA[Reply to ubuntu and magicmirror on Sun, 30 Dec 2018 04:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a></p>
<p dir="auto">Thanks for this. I will give this a shot tonight.</p>
<p dir="auto">cheers!</p>
]]></description><link>https://forum.magicmirror.builders/post/48850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48850</guid><dc:creator><![CDATA[maykesplana]]></dc:creator><pubDate>Sun, 30 Dec 2018 04:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to ubuntu and magicmirror on Sat, 17 Nov 2018 13:53:23 GMT]]></title><description><![CDATA[<p dir="auto">Thanx Mate! that did it!</p>
<p dir="auto">my monitor is 2560 x 1440. But in ubuntu I can only choose max 1920x1080, any suggestions howto fix that?<a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/46900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46900</guid><dc:creator><![CDATA[OceanK]]></dc:creator><pubDate>Sat, 17 Nov 2018 13:53:23 GMT</pubDate></item><item><title><![CDATA[Reply to ubuntu and magicmirror on Tue, 13 Nov 2018 01:31:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oceank" aria-label="Profile: oceank">@<bdi>oceank</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/46693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46693</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 13 Nov 2018 01:31:23 GMT</pubDate></item><item><title><![CDATA[Reply to ubuntu and magicmirror on Mon, 12 Nov 2018 22:02:44 GMT]]></title><description><![CDATA[<p dir="auto">I had the same issue trying to install on the latest Ubuntu, I could not get it to work, I would install 16.04. 16.04 works great for me.<br />
See<br />
<a href="https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other">https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other</a></p>
]]></description><link>https://forum.magicmirror.builders/post/46692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46692</guid><dc:creator><![CDATA[jasondreher]]></dc:creator><pubDate>Mon, 12 Nov 2018 22:02:44 GMT</pubDate></item><item><title><![CDATA[Reply to ubuntu and magicmirror on Mon, 12 Nov 2018 21:46:51 GMT]]></title><description><![CDATA[<p dir="auto">When you clone the mm repo, you then run npm install in the mm folder.</p>
<p dir="auto">What processor is that nuk machine?</p>
<p dir="auto">I just did the install on an odroid sbc without any problems on Ubuntu 18.04</p>
]]></description><link>https://forum.magicmirror.builders/post/46691</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46691</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 12 Nov 2018 21:46:51 GMT</pubDate></item></channel></rss>
