<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[not working]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/9094/not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 01:05:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9094.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Nov 2018 16:45:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to not working on Fri, 16 Nov 2018 10:07:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/branchi" aria-label="Profile: branchi">@<bdi>branchi</bdi></a> It’s going too far off topic but a hint:<br />
If your Pi is not booting, look at what the LED’s do. They may be blinking at the beginning. That resembles a code which you can look up with google.</p>
<p dir="auto">However, If it’s not too much work a completely new install is advisable.</p>
]]></description><link>https://forum.magicmirror.builders/post/46856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46856</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 16 Nov 2018 10:07:13 GMT</pubDate></item><item><title><![CDATA[Reply to not working on Thu, 15 Nov 2018 13:52:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/branchi" aria-label="Profile: branchi">@<bdi>branchi</bdi></a> - Let’s see if you have pm2 monitoring the mirror.</p>
<p dir="auto">Start your pi.<br />
SSH into your pi.<br />
Run <code>pm2 status all</code> and see if you get a listing for the Magic Mirror process. If you get an error message, then you likely didn’t install pm2 properly.</p>
<p dir="auto">Report back and let us know your results.</p>
]]></description><link>https://forum.magicmirror.builders/post/46790</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46790</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 15 Nov 2018 13:52:47 GMT</pubDate></item></channel></rss>
