<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GroveGestures]]></title><description><![CDATA[<h1>MMM-GroveGestures</h1>
<p dir="auto">MagicMirror Module - detecting 3D gesture with GroveGesture Sensor(PAJ7620u2)</p>
<h2>Video Clip</h2>
<p dir="auto"><a href="https://youtu.be/BcpZvkcrfHU" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="https://img.youtube.com/vi/BcpZvkcrfHU/0.jpg" alt="2.1.0 demo" class=" img-fluid img-markdown" /></a></p>
<h2>Hardware</h2>
<p dir="auto"><img src="/assets/uploads/files/1542300397132-gesture_sensor_3.png" alt="0_1542300396812_Gesture_sensor_3.png" class=" img-fluid img-markdown" /></p>
<ul>
<li>Grove Gesture Sensor (PAJ7620u2)
<ul>
<li>The sensor on Grove - Gesture is PAJ7620U2 that integrates gesture recognition function with general I2C interface into a single chip. It can recognize 9 basic gestures, and these gestures information can be simply accessed via the I2C bus.</li>
<li>price: $10~20USD</li>
<li>gestures : Up / Down / Left / Right / Forward / Backward / Clockwise / Count Clockwise / Wave</li>
<li>detection range : 5 ~ 10cm / non-touch</li>
<li>size : 20mm X 20mm</li>
</ul>
</li>
</ul>
<p dir="auto">Unfortunately, due to it’s short range and theory of electro-magnetic field, this sensor will not be used beneath Spymirror. But under the thin wooden, plastic or normal glass, it will work.<br />
It works as 3D gesture sensor similar with <code>Skywriter</code> or <code>Flick!</code>, but definitely small, flat, and non-HAT. It could fit for bezel-frame of MagicMirror. Soldering is not needed.</p>
<h3>Comparison</h3>
<ul>
<li>vs. PIR sensor, ultrasonic sensor, CAM motion detection
<ul>
<li><strong>PROS</strong>: more gestures</li>
<li><strong>CONS</strong>: short range</li>
</ul>
</li>
<li>vs. Skywriter, Flick!
<ul>
<li><strong>PROS</strong>: small</li>
<li><strong>CONS</strong>: touch, tap gestures are not supported</li>
</ul>
</li>
<li>vs. CAM gesture recognition
<ul>
<li><strong>PROS</strong>: light, easy, low CPU</li>
<li><strong>CONS</strong>: short range, not so COOL</li>
</ul>
</li>
</ul>
<h3>REQUIREMENT</h3>
<ul>
<li>1 x Grove Gesture Sensor (or PAJ7620u2 compatible)</li>
<li>1 x 4pin Female jumper cable</li>
</ul>
<h3>Pin Connect (I2C 1)</h3>
<ul>
<li>5V (GPIO PIN 4)	: VCC</li>
<li>GND	(GPIO PIN 6) : GND</li>
<li>SDA	(GPIO PIN 3) : SDA</li>
<li>SCL	(GPIO PIN 5) : SCL<br />
<img src="https://raw.githubusercontent.com/eouia/MMM-GroveGestures/master/IMG_0747.jpg" alt="" class=" img-fluid img-markdown" /></li>
</ul>
<h2>Install &amp; Details</h2>
<p dir="auto">[card:eouia/MMM-GroveGestures]</p>
]]></description><link>https://forum.magicmirror.builders/topic/9098/mmm-grovegestures</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 04:16:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9098.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Nov 2018 16:48:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GroveGestures on Sun, 20 Sep 2020 12:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
Not tested, so not sure. The issue relies on the thickness of the glass.</p>
]]></description><link>https://forum.magicmirror.builders/post/82089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82089</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 20 Sep 2020 12:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Sat, 19 Sep 2020 09:49:17 GMT]]></title><description><![CDATA[<p dir="auto">in the readme file it says it doesnt work behind spy glass, does that include regular glass with a reflective film?</p>
<p dir="auto">im guessing that it wont work but hoping that it will! :)</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/82030</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82030</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Sat, 19 Sep 2020 09:49:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 02 Jan 2020 23:25:20 GMT]]></title><description><![CDATA[<p dir="auto">@Sean You know what, I think I understood that mate. Thank you. I guess I’m gonna have to learn a little bit of python. Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/67052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67052</guid><dc:creator><![CDATA[jim.dw]]></dc:creator><pubDate>Thu, 02 Jan 2020 23:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 02 Jan 2020 14:03:14 GMT]]></title><description><![CDATA[<p dir="auto">@Sean hide()  technically turns into a suspend function call in the module<br />
show() turns into resume()</p>
]]></description><link>https://forum.magicmirror.builders/post/66993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66993</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Jan 2020 14:03:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 02 Jan 2020 13:52:29 GMT]]></title><description><![CDATA[<p dir="auto">@jim-dw<br />
right. “.hide()” is a common method of every module should have. Usually, module developer need to implement that method by his own or just leave it as inheritance from parent class. So, every module will have that “hide()” method definitely.<br />
Now, let’s see your needs.<br />
For example;<br />
If MMM-Carousel has specific method like “changePage(pageNo)”(IDK whether really it exists o not), you can call that method with “moduleExec”<br />
However I’m not the author of MMM-Carousel, so don’t know it supports or not. Ask to the author.</p>
]]></description><link>https://forum.magicmirror.builders/post/66990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66990</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 02 Jan 2020 13:52:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 02 Jan 2020 12:20:50 GMT]]></title><description><![CDATA[<p dir="auto">@Sean lol. Good point.</p>
<p dir="auto">I guess what confused me is this code below. I understand ‘clock’ or ‘newsfeed’ can be swapped out for ‘mmm-ceccontrol’ or ‘mmm-carousel’ it’s just figuring out how I send the command.</p>
<p dir="auto">Is it “module.hide()” that needs to be replaced?</p>
<p dir="auto">Sorry for this. Still learning</p>
<p dir="auto">moduleExec: {<br />
module: [“clock”, “newsfeed”], // <code>[]</code> will be all modules.<br />
exec: (module, gestures) =&gt; {<br />
module.hide()<br />
}<br />
}</p>
]]></description><link>https://forum.magicmirror.builders/post/66977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66977</guid><dc:creator><![CDATA[jim.dw]]></dc:creator><pubDate>Thu, 02 Jan 2020 12:20:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 02 Jan 2020 11:40:17 GMT]]></title><description><![CDATA[<p dir="auto">@jim-dw<br />
Well, I’m not the author of  those modules, so Ask these to the creator of MMM-Carousel / MMM-CECControl ;(Or need to check by yourself)</p>
<ul>
<li>Are there notifications for that purpose?</li>
<li>Or Are there method of module class for that purpose?</li>
<li>Or controllable by external shell script or HTTP API?</li>
</ul>
<p dir="auto">At least one of them possible, it could.</p>
]]></description><link>https://forum.magicmirror.builders/post/66973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66973</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 02 Jan 2020 11:40:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 02 Jan 2020 11:27:02 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Hi mate, just dipping my toe in to the whole Magic Mirror world and loving it. Was just wondering if there’s any way to control MMM-Carousel and MMM-CECControl using the output from MMM-GroveGestures?</p>
<p dir="auto">I’m thinking</p>
<ul>
<li>Clockwise for next slide</li>
<li>Anti clockwise for previous slide</li>
<li>UP to send the wake up signal on HDMI</li>
<li>Down to send the sleep signal on HDMI</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/66971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66971</guid><dc:creator><![CDATA[jim.dw]]></dc:creator><pubDate>Thu, 02 Jan 2020 11:27:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Tue, 25 Jun 2019 17:13:08 GMT]]></title><description><![CDATA[<p dir="auto">@Sean thanks for your answer it was a H/W failure I2C was not activate and i don’t know why ? I enabled I2c with raspi-config and shutdown the pi. I pluged my sensor again and it works</p>
]]></description><link>https://forum.magicmirror.builders/post/58218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58218</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Tue, 25 Jun 2019 17:13:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Mon, 24 Jun 2019 17:55:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mistert" aria-label="Profile: MisterT">@<bdi>MisterT</bdi></a><br />
<img src="/assets/uploads/files/1561398753931-gx90ukr.png" alt="0_1561398753466_GX90uKR.png" class=" img-fluid img-markdown" /><br />
If you get one similar with this (All address are shown), It would be something wrong.<br />
Only 73 should be shown. There might be dead pin or H/W failure.</p>
]]></description><link>https://forum.magicmirror.builders/post/58181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58181</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 24 Jun 2019 17:55:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Mon, 24 Jun 2019 17:11:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi everybody,@Sean  and <a class="plugin-mentions-user plugin-mentions-a" href="/user/benjaminh86" aria-label="Profile: Benjaminh86">@<bdi>Benjaminh86</bdi></a><br />
I use this module just for change pages with MMM-Pages and MMM-Pages indicator but after a while, my sensor is unknown.<br />
when i just want to test the sensor with “python gesture_print.py”, i have:</p>
<p dir="auto">Error with sensor<br />
Paj7620 initialize register finished.</p>
<p dir="auto">my matrix is good i think:</p>
<p dir="auto">sudo i2cdetect -y 1<br />
0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f<br />
00:          03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f<br />
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f<br />
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f<br />
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f<br />
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f<br />
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f<br />
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f<br />
70: 70 71 72 73 74 75 76 77</p>
<p dir="auto">and i have 5 file in /home/pi/MagicMirror/modules/MMM-GroveGestures/py<br />
I restart Raspberry but the result is the same</p>
<p dir="auto">Can aybody help me please ?</p>
]]></description><link>https://forum.magicmirror.builders/post/58180</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58180</guid><dc:creator><![CDATA[MisterT]]></dc:creator><pubDate>Mon, 24 Jun 2019 17:11:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 28 Mar 2019 11:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/benjaminh86" aria-label="Profile: Benjaminh86">@<bdi>Benjaminh86</bdi></a><br />
If you have those files, you don’t need to execute any manual commands o n MM running</p>
]]></description><link>https://forum.magicmirror.builders/post/55013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55013</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 28 Mar 2019 11:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 28 Mar 2019 11:37:34 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
That’s what happens :<br />
pi@raspberrypi:~ $ ls ~/MagicMirror/modules/MMM-GroveGestures/py<br />
gesture_print.py             grove_gesture_sensor.pyc<br />
grove_gesture_sensor.py      grove_gesture_sensor.py.RPI<br />
grove_gesture_sensor.py.ATB</p>
]]></description><link>https://forum.magicmirror.builders/post/55012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55012</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Thu, 28 Mar 2019 11:37:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 28 Mar 2019 10:27:25 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
I have to make this command every start of the pi, knowing that I do not start the MM automatically (pmm2) time to set everything (npm start).<br />
I’ll be watching tonight with<br />
ls ~ / MagicMirror / modules / MMM-GroveGestures / py</p>
]]></description><link>https://forum.magicmirror.builders/post/55007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55007</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Thu, 28 Mar 2019 10:27:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 28 Mar 2019 10:23:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/benjaminh86" aria-label="Profile: Benjaminh86">@<bdi>Benjaminh86</bdi></a><br />
Can’t understand.<br />
Do you need to do that shell command per every execution of MM? Have you reinstalled it?<br />
That commands just need to be done once when you install this module.</p>
<p dir="auto">And that command isn’t related with <code>chmod + x .sh</code> at all.</p>
<p dir="auto">Check this.</p>
<pre><code class="language-sh">ls ~/MagicMirror/modules/MMM-GroveGestures/py
<p dir="auto">There should be <code>grove_gesture_sensor.py</code> besides <code>grove_gesture_sensor.py.RPI</code> and <code>grove_gesture_sensor.py.ATB</code>.<br />
Are those files there?</p>
]]></description><link>https://forum.magicmirror.builders/post/55006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55006</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 28 Mar 2019 10:23:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 28 Mar 2019 10:23:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bolish" aria-label="Profile: bolish">@<bdi>bolish</bdi></a><br />
it works!<br />
thanks for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/55005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55005</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Thu, 28 Mar 2019 10:23:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Thu, 28 Mar 2019 10:17:17 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
it’s weird; the sensor is not active if I do not order:</p>
<p dir="auto">cd ~ / MagicMirror / modules / MMM-GroveGestures / py<br />
cp grove_gesture_sensor.py.RPI grove_gesture_sensor.py</p>
<p dir="auto">would not it come from “chmod + x * .sh” where I hurt something? …</p>
]]></description><link>https://forum.magicmirror.builders/post/55003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55003</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Thu, 28 Mar 2019 10:17:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Wed, 27 Mar 2019 08:35:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bolish" aria-label="Profile: bolish">@<bdi>bolish</bdi></a><br />
I will explore this track.<br />
Thanks to you ; you already helped me a lot!</p>
]]></description><link>https://forum.magicmirror.builders/post/54957</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54957</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Wed, 27 Mar 2019 08:35:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Wed, 27 Mar 2019 08:29:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello @Sean,<br />
I will look at this in more detail in the module.<br />
Thank you again for your work.</p>
]]></description><link>https://forum.magicmirror.builders/post/54954</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54954</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Wed, 27 Mar 2019 08:29:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Wed, 27 Mar 2019 08:22:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/benjaminh86" aria-label="Profile: Benjaminh86">@<bdi>Benjaminh86</bdi></a><br />
You have to search a bit on the forum.<br />
One idea could be to create 2 calendars instances.<br />
See below <a href="https://forum.magicmirror.builders/topic/9584/default-calendar-multiple-caldendar-instances-overwritting-each-other-maximumnumberofdays/3">post</a> extract :</p>
<pre><code>well… I believe it’s far from being perfect…but at least it seems to do the job…
I created a “new” module which does exactly same / has the same code as the one I want to use, but has a different name (folder named “MMM-Calendar2” -&gt; file named “MMM-Calendar2.js” -&gt; within the line Module.register(‘MMM_Calendar2’)).
Not in the default module folder but into the 3rd party module folder…
<p dir="auto">And put instance 1 on page 1 and isntance 2 on page 2.</p>
]]></description><link>https://forum.magicmirror.builders/post/54953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54953</guid><dc:creator><![CDATA[bolish]]></dc:creator><pubDate>Wed, 27 Mar 2019 08:22:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Wed, 27 Mar 2019 08:08:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/benjaminh86" aria-label="Profile: Benjaminh86">@<bdi>Benjaminh86</bdi></a> said in <a href="/post/54951">MMM-GroveGestures</a>:</p>
<p dir="auto">It is described on instruction for installation. And that command is not for activation. I provide 2 scripts for each of Raspberry Pi and Asus TinkerBoard. you need to select one for your device.  You don’t need to do that job again after once you did.</p>
<p dir="auto">The real activation would be performed in the module itself on every running of MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/54952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54952</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 27 Mar 2019 08:08:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Wed, 27 Mar 2019 07:55:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bolish" aria-label="Profile: bolish">@<bdi>bolish</bdi></a>,</p>
<p dir="auto">thanks to you! everything is working!<br />
however, I thought Grove Gestures would activate automatically, but I have to make the command line for the sensor to be active:<br />
cp grove_gesture_sensor.py.RPI grove_gesture_sensor.py<br />
Is this normal?<br />
Another question about MMM-Pages; I would like to display the Google Calendar calendar on page 1 and the holiday calendar on page 2, but I do not know how to differentiate and name them on MMM-Pages …<br />
Do you have an idea?</p>
]]></description><link>https://forum.magicmirror.builders/post/54951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54951</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Wed, 27 Mar 2019 07:55:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Tue, 26 Mar 2019 10:46:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bolish" aria-label="Profile: bolish">@<bdi>bolish</bdi></a></p>
<p dir="auto">Great!<br />
I will try tonight the adaptation I made of your script.<br />
I put the action “MONITOROFF” in the “Default_Mode” part of Grove Gestures, that’s it?</p>
]]></description><link>https://forum.magicmirror.builders/post/54921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54921</guid><dc:creator><![CDATA[Benjaminh86]]></dc:creator><pubDate>Tue, 26 Mar 2019 10:46:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GroveGestures on Tue, 26 Mar 2019 10:41:41 GMT]]></title><description><![CDATA[<p dir="auto">No, if it’s works by sending the request, it should work with Gesture also!</p>
]]></description><link>https://forum.magicmirror.builders/post/54919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54919</guid><dc:creator><![CDATA[bolish]]></dc:creator><pubDate>Tue, 26 Mar 2019 10:41:41 GMT</pubDate></item></channel></rss>
