<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror will not start]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1542313124488-mmnostart.png" alt="0_1542313127413_MMnostart.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Trying to create a magic mirror with google home integration through the use of the voice kit (1.0).  I had issues with npm not being present at first, thought i fixed that, got pm2 installed and tried to get everything running, but it wont start at all.  Now i’m pretty lost.  Thanks for the help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9099/magic-mirror-will-not-start</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 19:29:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9099.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Nov 2018 20:29:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 21:48:13 GMT]]></title><description><![CDATA[<p dir="auto">Huh, it appears the work i did before deleting and reinstalling the MagicMirror directory for the auto-start held over and it is working now.  Thanks for dealing with me!</p>
]]></description><link>https://forum.magicmirror.builders/post/46827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46827</guid><dc:creator><![CDATA[elporcho]]></dc:creator><pubDate>Thu, 15 Nov 2018 21:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 21:38:32 GMT]]></title><description><![CDATA[<p dir="auto">I was going to follow the instructions here for auto-starting magic mirror:<br />
<a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/46826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46826</guid><dc:creator><![CDATA[elporcho]]></dc:creator><pubDate>Thu, 15 Nov 2018 21:38:32 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 21:35:04 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1542317686290-mmnostart2.png" alt="0_1542317689142_MMnostart2.PNG" class=" img-fluid img-markdown" /><br />
Seems that I’ve got it re-installed, but now npm install still does nothing.</p>
]]></description><link>https://forum.magicmirror.builders/post/46825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46825</guid><dc:creator><![CDATA[elporcho]]></dc:creator><pubDate>Thu, 15 Nov 2018 21:35:04 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 21:20:15 GMT]]></title><description><![CDATA[<p dir="auto">I appreciate the help.  I did sudo -rf rm MagicMirror and it gave the the following error:<br />
rm: cannot remove ‘MagicMirror’: Is a directory<br />
I also tried rmdir, but it says Directory not empty.</p>
]]></description><link>https://forum.magicmirror.builders/post/46824</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46824</guid><dc:creator><![CDATA[elporcho]]></dc:creator><pubDate>Thu, 15 Nov 2018 21:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 21:11:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elporcho" aria-label="Profile: elporcho">@<bdi>elporcho</bdi></a> from the  home folder ( cd ~ ), do sudo -rf rm MagicMirror</p>
<p dir="auto">Then clone the mm repo again, then cd MagicMirror, then npm install</p>
]]></description><link>https://forum.magicmirror.builders/post/46823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46823</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Nov 2018 21:11:49 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 20:59:50 GMT]]></title><description><![CDATA[<p dir="auto">Sorry i’m pretty much a complete noob with linux.  Should i be re-imaging the SD card, or is there a simpler way to clear out the installs i did wrong.</p>
<p dir="auto">Also, what should i do instead of “sudo npm install”?  I just followed instructions as I saw them, so I’m not even sure which installation you’re referring to.  Sorry for my ignorance.</p>
]]></description><link>https://forum.magicmirror.builders/post/46822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46822</guid><dc:creator><![CDATA[elporcho]]></dc:creator><pubDate>Thu, 15 Nov 2018 20:59:50 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not start on Thu, 15 Nov 2018 20:49:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elporcho" aria-label="Profile: elporcho">@<bdi>elporcho</bdi></a> ‘permission denied’ sounds like you used <code>sudo npm install</code>, which leaves files owned by root, not the normal pi user.</p>
<p dir="auto">Best to erase and start again</p>
]]></description><link>https://forum.magicmirror.builders/post/46819</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46819</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 15 Nov 2018 20:49:59 GMT</pubDate></item></channel></rss>
